BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 328i JB4 **STAGE2** Dyno Testing -- New World Record. :)
      03-04-2013, 12:36 PM   #45
Merlinx1
Italy
Drives: Bmw F20 125i Msport
I own a f20 125i wich share the same n20 engine as the f30 328i. Is there any chance to get the same tune for my car?
      03-04-2013, 01:26 PM   #46
Axxlrod
Dude man
Axxlrod's Avatar
24
Drives: 550 M Sport/MB GL450/Acura NSX
Originally Posted by bnekic View Post
Always pump 93 and you'll never have a problem!
If you can get it.
Here in CA, 91 is the highest we get...
      03-04-2013, 04:13 PM   #47
tricksterr24
Drives: 2012 328i
2009 328 sulev  [0.00]
Originally Posted by Turboedv6 View Post
Its possible that if you go stage 2 with more boost, the engine will start to detonate or pre ignite from using a low octane fuel such as 91 and it will retard the ignition timing to reduce the combustion knock. This will make the car perform slower and could possibly hurt then engine.
Thanks for the info. I've never seen a 93 pump in la. I gotta research it.
      03-04-2013, 04:19 PM   #48
Turboedv6
Drives: '13 Apline White Sportline 328
Probably for some sort of Cali emissions they don't have 93 octane, see what octane booster they have.
2013 Alpine White 328xi Sport Line
2005 Summit White Chevy 2500 CC Duramax (stock F30 killer)
2005 Wicked White Evo 8 11.71 @ 117mph (stock turbo)
      03-07-2013, 02:48 AM   #49
RSXDC5
RSXDC5's Avatar
137
Drives: M3
I literally can't waittt to get the stage 2 on my car, I have an e85 station about 3 min from my house!!!
What excites me the most is potentially having 325whp/390wtq on tap with a turbo back exhaust!!
Having (approx.) +90whp/+135wtq over stock is just nuts
2015 M3 - Alpine White 6Spd
LED's, CCB's, Adaptive Dampers, Swifts, VRSF DP's, GC Camber Plates, 275/305 AD08R, Signature Wheels SV103 19x10.5/11.5
      03-07-2013, 03:47 AM   #50
pkimM3r
pkimM3r's Avatar
-40
Originally Posted by RollingLower420
Great news. I cannot wait to ugrade to stage 2. Stage 1 is already awesome.
I also do not know anywhere to get E85 fuel..But every once and awhile, I fill up about half my tank with 91 and half my tank with 100 octane. The difference is CRAZY! That 100 octane makes a huge difference.
Would the E85 be comparable to mixing a tank with 100 octane?
E85 is drt cheap and is about 110 octane. I used to keep 20 gallons at home because it was literally less than 10 mpg ha.
      03-07-2013, 12:05 PM   #51
DR.Nefario
DR.Nefario's Avatar
64
Drives: 2013 Dakar Yellow M3
More power than the 100 octane tune, nice.
      03-07-2013, 12:57 PM   #52
VANOS
NFS
VANOS's Avatar
Drives: N/A
But I have read and asked terry if you are able to use 91 for the stage 2 tune, he said yes you can. In fact he mentioned on another thread that you can use 91, you may not get as much power with 85, but the power will still definitely be higher than stage 1! They will bring out the dyno results using 91 and 93 pretty soon from what i read. It should be very interesting.
      03-07-2013, 01:13 PM   #53
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
I'm eagerly awaiting 93 octane results, if possible with knock sensor monitoring. We do have 93 octane, a 328i and a dyno if any help is needed. Thanks for isolating the air filter on the dyno. You've saved a lot of people a lot of money. Did you isolate the filter at 23 pounds of boost or at the lower stage one level?
      03-07-2013, 01:13 PM   #54
tdizzle
Drives: 2017 F80 ZCP
Just lurking, nice numbers. My concern is the fact that the cars aren't designed for E85 and what effect does it have? Warranty issues? Premature wear? Anything else?
I know cars that can run E85 like to advertise it prominently. Not sure what changes need to be done to safely support it, but just has me wondering as it's a huge increase in power coupled with decrease in fuel efficiency.
      03-09-2013, 09:56 PM   #55
ixse
Drives: 2015 boxster s
when i had my evo, E85 was also widely used.. only couple parts that req. were larger injectors & high capacity fuel pump. There were no signs of premature wear on fuel lines etc etc.. it's clean fuel.. I'm asuming as long as tuning is within range of our stock fuel supply system, there wouldn't be any contraindications.. i'm def. waiting until they introduce this stg 2 tuning ..
      03-10-2013, 12:14 AM   #56
RPM90
Drives: 340i M-sport AT
The concern with E85 isn't that it's not "clean", it's the alcohol/ethanol used to formulate E85.
But, seems tuners have and are using it with no ill effects.
Still, BMW recommends using no more than 10% ethanol mixed fuel.
E85 is 85% ethanol and 15% gasoline.
Time and mileage will tell if the alcohol has any damaging effects.
Alcohol has a greater cooling effect in the combustion chamber and that results in a higher octane rating.
But, it also has a less thermal energy, which will lower MPG.
Initial cost per gallon may be less, but overall you'll spend more by needing more E85 to cover the same mileage as regular gasoline.
Here is a good article/experiment showing the MPG differences and costs associated with using E85.
The power/accel tests in this article don't really translate directly, but I post this article for the MPG question not power performance comparison.
http://www.edmunds.com/fuel-economy/...ison-test.html
Some people will say there is not point to E85 as it costs more to operate and doesn't save much on emissions.
BUT, the biggest thing to remember about E85 is that it is a RENEWABLE fuel resource, meaning, we have ways to produce more over the long haul compared to the limited amount of oil available. Once we run out of oil we're out of gasoline too.
At that point E85 will look real good, unless we're mostly in electric cars by then.
      03-10-2013, 05:15 PM   #57
VANOS
NFS
VANOS's Avatar
Drives: N/A
What I would like to know is how much power loss do we get using only 91 octane. Personally i still don't feel comfortable enough using E85.
      03-10-2013, 05:26 PM   #58
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I will dyno both ways. I bet 30-35whp from 93, 22-27whp on 91 on a Dynojet. That's my guess.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-10-2013, 05:45 PM   #59
David328M-Sport
Australia
75
Have you set your boost to +4psi yet?
Maybe try dynos at 3 & 4.
Cheers
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-10-2013, 07:49 PM   #60
Jamesons Viggen
Cheers
I have the cable, but no answer on what to raise the 2nd circled number.
I am not in a rush as I am still on snow tires, so it just means more wheelspin. Dyno'ing at 3 and 4psi is what I meant when I said the two power guesstimates.
      03-10-2013, 10:38 PM   #61
David328M-Sport
Australia
75
Tell you what, the butt dyno says it all. It is fantastic and fast. Very aggressive and so much fun. Most of the time my car is in Comfort and when you ask the car to perform, it does so with so much vigour. Sport mode is ballistic, so I can only imagine what stage 2 will present.
Yes, as you certainly would have read, I asked Mike what the second field was about, but so far no answer.
Got it about your weather conditions.
And on our side of the planet, we are experiencing the hottest weather run since records were started in 1856.
Cheers
      03-11-2013, 07:25 AM   #62
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
91-92 octane is pretty bad. Don't expect much over Stage1 tuning with it. Maybe a handful of HP, some additional torque, and less lag.
For the +4psi setting only the 'boost over stock' field is changed.
Mike
      03-11-2013, 10:27 AM   #63
Jamesons Viggen
Mike
Thanks!
Do you have a direct link to the N55 software I need to download to tinker with the boost?
      03-13-2013, 03:33 AM   #64
tricksterr24
Drives: 2012 328i
So when you pump 85 do you pump a few gallons or fill up the tank? Does it cause your engine light to go on?
      03-13-2013, 05:48 PM   #65
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
for california people, do we have to get it shipped to us?
      03-14-2013, 05:29 AM   #66
VANOS
NFS
VANOS's Avatar
Drives: N/A
Thanks man! That will be great, just so we no where it stand between the fuel situation.
