BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMS stage 1 Dyno Results
European Auto Source
      03-18-2013, 12:59 PM   #89
swe328i
Drives: BMW 328i f30
Originally Posted by Jamesons Viggen View Post
I did a stock dyno and one with catback. I hope to dyno soon with catback and stage 1 at 3 and 4psi.
Do you have a 6mt or 8at ?
Also what was your stock whp ?
      03-18-2013, 01:04 PM   #90
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I have a 6mt.
I dynod on a load bearing Super Flo, not a Dynojet which has higher numbers.
I did 213/240tq stock and 220/260 with the catback
Add 7-10% to get an idea of Dynojet numbers.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-18-2013, 01:11 PM   #91
swe328i
I have a 6mt.
Nice, i also have a 6mt .
Did you use 98ron fuel when you did
The dyno? I think it is 93AKI in the U.S.
Do you have the S1 on now? If so is it what you expected it to be ?
      03-18-2013, 01:21 PM   #92
Jamesons Viggen
I had 93 octane in on the dyno.
Have S1 at 3psi, feels great, won't mind a bit mode that 4psi should offer. I run 93 anyway, might as well take advantage of the octane.
      03-18-2013, 01:24 PM   #93
swe328i
What is the default psi when you install the bms S1 ?
      03-18-2013, 02:18 PM   #94
Jamesons Viggen
+3
      03-18-2013, 05:43 PM   #95
swe328i
+3
Ok, thanks for the info.
Please update us when you run on +4 psi.
      03-19-2013, 02:18 AM   #96
XRS
Drives: 335i E92 M-Sport
I did not adjust the boost so I guess I'm on +3psi. Please share your dyno if you have done it with +4psi.
Torque gains seems to be good but HP seems otherwise
      03-19-2013, 09:36 AM   #97
Jamesons Viggen
Anyone have the download link for the n55 software to load on the laptop to adjust for boost? I think I can get my summer wheels done on Friday!
      03-19-2013, 10:33 AM   #98
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Default boost on stage1 out of the box is +3PSI
Mike
      03-19-2013, 11:59 AM   #99
swe328i
Mike
Hello Mike,
Here in Sweden we have shell v-power
98.5 ron + 5% ethanol. My question is,
Can I use shell v-power and set the boost
To +4psi stage 1 ?
I have a 6mt.
      03-19-2013, 12:03 PM   #100
Jamesons Viggen
Hello Mike,
To +4psi stage 1 ?
I have a 6mt.
Hell yeah, your gas is better than ours-so why not?
      03-19-2013, 12:33 PM   #101
brunox2
brunox2's Avatar
Brazil
Drives: BMW ///M3 E92 AW
In the sports meter, on my 320i goes up to 160kWand 320nM.
My car, stock, stops at 141kW (tops) and 270nM. Hopefully after installed I wanna bit those numbers.
It's a good way to see if you have a good upgrade without the dyno right?
In 328i you probably have higher maximum numbers, or doesn't?
08' BMW ///M3 E92 AW
      03-19-2013, 04:56 PM   #102
crazybones
crazybones's Avatar
199
Drives: F36 440i M-Sport
In interesting question which I also considered. If the sports meters do show the higher output of the upgrade, surely this could then be potentially logged by the car and give away the fact that it has been chipped even if the unit is removed prior to a service?
      03-19-2013, 05:03 PM   #103
mhdelarosa
Drives: '12 328i Mineral Grey Metallic
My 328 w the tune doesn't show higher torque readings on the meter, but I can feel the difference when driving.
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
      03-19-2013, 10:25 PM   #104
RJH
Drives: 328i xDrive
Results from this tune, at this point, appear too inconsistent and subjective for my tastes - and at 18ish hp probably too small to notice - even to a well trained butt. Moreover, even the changes "under the line" don't point to more real world / usable performance. Also don't get this learning period thing - sounds like urban legend!
FYI: Some years ago I enjoyed good and bad experience chipping my Audi A4 w/2.0T. First chip promised big numbers and for the first few weeks I thought I felt something. But when others reported their disappointments, it confirmed I was fooling myself. I later replaced the chip with one from GIAC - which had years of well documented (though more modest) gains and had been fully sorted out. With this tune, the difference was very obvious and real; especially in day to day driving.
I appreciate the early adopters, and the minute I'm convinced that this or that other piggy-back with the blue light actually delivers 30+ whp and 50+ torque, and in the meat of the power range...and without surprises...my check is in the mail. Until then I gotta sit on the fence, with crossed fingers.
[u2b], [/u2b]
      03-20-2013, 07:52 AM   #105
brunox2
brunox2's Avatar
Brazil
No torque difference, and the power?
      03-20-2013, 08:45 AM   #106
Erik.klenke
Drives: 2012 328i Sportline
[u2b], [/u2b]
After I installed my BMS Piggy Back, the difference was immediately very noticeable; to my butt and to the stopwatch. My 0-60 time dropped from 5.7 to 4.9; taken right before and right after install. My previous car was 07 GTI with an APR Stage 1, which also advertises around 30 to 40 hp increase. I think the BMS piggy back was even more pronounced than the APR Stage 1. I have no doubt it's adding at least 30 to 40 hp in my car. It does seem that the results people are having are a little inconsistent, but the majority of people seem to be very satisfied. Best option would be to try it for your self. Very easy install and I believe they offer a 14 day money back guarantee.
      03-20-2013, 04:08 PM   #107
David328M-Sport
Australia
75
Seriously? Do you believe the sports meters? They are only a very basic guide and cannot be taken seriously. The main point is you can feel the difference and it is very noticeable.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-20-2013, 04:18 PM   #108
Jamesons Viggen
The meter gets info from the standard sensors data, a piggyback might bypass that info from getting to the meter.
The meter is a silly thing anyway, I would not use it to gauge anything.
      03-20-2013, 08:47 PM   #109
brunox2
brunox2's Avatar
Brazil
It's not a perfect way, of course!
Ans since piggyback bypass that, useless. However is a certain way.
      03-23-2013, 05:32 PM   #110
swe328i
Can I run +6psi on stage 1 if I use
101 or 103 oktan fuel ?
