BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Geneva 2013: Alpina B3 F30 Debuts with Full Specs
      03-05-2013, 11:12 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Lightbulb Geneva 2013: Alpina B3 F30 Debuts with Full Specs
BIMMERPOST NEWS
45
COMMENTS
Alpina has brought two world debuts to showcase at the 2013 Geneva auto show - the B3 F30 and the Alpina XD3 (based off the X3 SAV).
You can find the B3 F30's full official specs and gallery below.
Follow our full 2013 Geneva show coverage updates at BIMMERPOST.com
Name:  Screen Shot 2013-03-05 at 6.56.56 AM.jpg
Name:  Screen Shot 2013-03-05 at 6.56.39 AM.jpg
Alpina B3 Debut at 2013 Geneva Motor Show
Alpina B3 Debuts
THE NEW BMW ALPINA B3 BITURBO
The foundation that Burkard Bovensiepen laid in the 1960s in the form of a performance-enhanced BMW 1500, has since developed into a permanent fixture in the luxury sports car segment. What were then the first technologically and qualitatively relevant products marketed by ALPINA, namely four-cylinder petrol engines with Weber dual carburettors in the BMW Neue Klasse, are now in modern form high-tech automobiles. Equipped from the outset with the best possible genes by BMW, they currently represent the ultimate in perfor- mance, comfort, ‘driving culture’ and efficiency.
The new BMW ALPINA B3 Bi-Turbo combines these characteristics like no other automobile before it. The straight-six 3.0 litre engine equipped with two turbochargers delivers 410hp and a maximum torque of 600Nm. The adaptive ALPINA sport suspension system and the 8-Speed Sport-Automatic transmission with ALPINA SWITCH-TRONIC deliver maximum comfort and im- pressive dynamics. Functional aerodynamics combine well with the trademark 20” ALPINA CLASSIC wheels and together with two elliptical double tailpipes create an elegant appearance. The new BMW ALPINA B3 Bi-Turbo accelerates from 0 to 100km/h (0 - 62mph) in just 4.2 seconds, reaching a top speed of 305km/h (190mph). When driven moderately, it consumes significantly less than 10 litres of Super plus (98 RON) per 100km and achieves a class-leading combined fuel consumption measured to ECE norm of just 7.6l/100km and 177g/km CO2 (Saloon RWD).
These extraordinary performance figures are also available for friends of all-wheel drive. The new BMW ALPINA B3 Bi-Turbo Allrad utilises the proven possibilities of the excellent BMW xDrive system and offers unparalleled levels of traction and driving dynamics.
POWERTRAIN
The 2979cc straight-six cylinder engine with high-precision direct injection, Valvetronic and Bi-Turbo charging delivers an impressive 410hp (301kW) between 5500 and 6250rpm and a maximum torque of 600Nm at only 3000rpm. In fact 550Nm are available across an impressively wide range between 2200 and 5200rpm. All this ‘pulling power’ is mated to the excellent ZF 8-Speed Sport-Automatic transmission and means that the new BMW ALPINA B3 Bi-Turbo is positively playful in every situation – its power can be called upon at all times in order to enjoy that typical ALPINA driving experience. At the same time the engine is eager to rev up to 7000rpm and will spontaneously dial-up a maximum boost pressure of up to 1.2 bar without any lag.
Utilising all the available power and torque will yield explosive performance: the new B3 Bi-Turbo Saloon accelerates from 0 to 100km/h (0 - 62mph) in just 4.2 seconds (Saloon AWD: 4.0s), improving on its predecessor by 12%. On the way to a top speed of 305km/h (190mph) the needle passes the 200km/h (124mph) mark in just 14 seconds!
The powertrain also impresses in terms of efficiency and sets standards in its segment with a consumption of only 7.6 litres per 100 kilometres and 177g/km CO2 (Saloon AWD: 7.9l/100km and 183g/km CO2). This represents a 20% reduction in combined fuel consumption measured to ECE norm over its predecessor, in no small part thanks to Auto Start Stop and Valvetronic.
The prerequisite for these impressive values is a high-tech engine which exhibits its own unique characteristics thanks to a significant number of stand-alone features. The goal of the engineers from Buchloe was to achieve excellent responsiveness, high output across the entire rpm range and an improvement in fuel consumption. The ‘Bi-Turbo’ engine configuration arose not only out of tradition. More to the point, this type of turbocharging has the advantage of providing very good response and pick-up due to the low mass moment inertia of the turbocharger’s running gear and sufficient rate of air-flow for spontaneous power delivery.
The design and construction of the excellent BMW 3.0 litre straight-six cylinder (N55) engine serves as a starting-point for a specially cast aluminium crankcase with Bi-Turbo capable flanges. These enable the mounting of two turbochargers along with required oil and water connections and a close-coupled catalytic converter arrangement. ALPINA specific NGK spark plugs and a forged steel high-strength crankshaft guarantee long-lasting stability.
Always-on power delivery and excellent throttle response are aided by an electronically controlled bypass valve system. Specially constructed and de-throttled, i.e. flow and cross-section optimised, air intake ducts guide the air with minimal losses from the air intake via the air filter housing to the turbochargers. On the fuel side, a high-performance high-pressure fuel pump ensures the right throughput. Optimal utilisation of the output is provided by a high-capacity intercooler with flow-optimised collector boxes made from aluminium. Coolant cooler, addi- tional separate coolant and engine oil coolers as well as a high-performance 850w cooling fan ensure the thermal stability of the cooling system in all conditions.
TRANSMISSION
Inspired by the pleasure that the 8-Speed Sport-Automatic transmission with SWITCH-TRONIC offers in the bigger BMW ALPINA models, the so-called 8HP70 transmission has been extensively adapted to suit the performance characteristics of the new 3 Series from ALPINA.
In actual fact, the high power output and torque of the Bi-Turbo combine so well with this transmission that performance figures usually associated with much larger but less efficient engines are achieved. Furthermore, this transmission excels in disciplines often assumed to be incompatible and offers an optimum driving experience in every situation. To this end, three shift modes are available: Automatic (D), Sport (S) and Manual (M).
In Automatic (D) Shift Mode the focus is strictly on driving comfort. The transmission changes gears quickly and with no noticeable interruption to the delivery of power. The torque of the engine enables consumption-optimised 'surfing‘ in high gears even at very low speeds and in urban driving environments. Even at higher cruising speeds rpms will remain low, for example 2500rpm at 170km/h in 8th gear, increasing long-distance driving comfort significantly.
Sport (S) Shift Mode noticeably shortens the time it takes for the next gear to engage and depending on engine load significantly moves the shift points up the rev range. Accelerator inputs are carried out immediately, full throttle i.e. kick-down will implement multi-simultaneous downshifts and optimal acceleration. When combined with the Sport or Sport+ setting of the Drive Performance Control, which modifies the drive and chassis setup, gearshifts are even quicker and also more acoustic thanks to single-cylinder fade-out. This function interrupts the injection of fuel into a given cylinder for a fraction of a second, creating the required reduction in torque that the automatic transmission requires for super quick and dynamic up-shifts.
Activating the Manual (M) Shift Mode by utilising the SWITCH-TRONIC buttons on the back of the steering wheel, allows the driver to take control and shift gears when suitable or necessary. In this mode the comfort and speed of the gear changes can be influenced by selecting between Eco Pro, Comfort, Sport or Sport+ using the Drive Performance Control. A special feature of the Sport, Sport+ and DSC Off setting is the suppression of automatic up-shift in Manual (M) Shift Mode – hereby the selected gear is held into the rpm limiter and the transmission will not up-shift into a higher gear.
Abundant torque allows the use of a long rear axle ratio which in combination with the 8-Speed Sport Automatic transmission and Auto Start Stop contributes significantly to achieving excellent fuel economy. Top speed is achieved in 7th gear. Additional hardware modifications for dealing with output and torque include reinforced front and rear axle differentials, high-strength output and drive shafts and a high-torque transmission gear unit.
EXHAUST SYSTEM
The stainless steel exhaust system which was developed in collaboration with Akrapovič is 7.5kg lighter in comparison to its predecessor. The two elliptical double tailpipes, which are typical of ALPINA, are elegantly integrated into the rear valence and give a very purposeful look.
The resonant, sporty sound of the exhaust system is controlled by an intelligent exhaust valve. This offers the driver the possibility to influence the sound experience via the Drive Performance Control and facilitates the balancing act between emotional soundtrack and long-distance comfort. In Comfort mode the exhaust valve remains closed up to 2500 rpm, beyond which it opens depending on engine load and rpm. In Sport mode, however, the valve is permanently open and the B3 Bi-Turbo thrills with its distinctive aural character under hard acceleration – when additionally selecting Sport (S) or Manual (M) Shift Mode the exhaust will deliver an occasional burble on the overrun.
CHASSIS
The suspension set-up of the new B3 Bi-Turbo provides great ride-quality and comfort while simultaneously offering sharp and dynamic handling. The adaptive ALPINA sport suspension solves this conflict of interest by means of electronically adjustable dampers in collaboration with performance springs, bump stops and stabilisers. The system allows the driver to use the Drive Performance Control (Eco Pro, Comfort, Sport, Sport+) to select the suspension setting and driving dynamics to match his mood.
The 20“ CLASSIC wheels with low profile MICHELIN Pilot Super Sport tyres, a strut brace and subtle adjustments to camber, toe-in and elastokinematics are responsible for achieving very neutral and predictable handling that is typical of ALPINA.
The Drive Performance Control settings also influence other parameters which effect driving dynamics, such as the electric power steering (Servotronic) and the driving stability control (DSC and DTC) system. The latter is subject to a software coding which takes into account the specifics of the ALPINA suspension and chassis.
The Variable Sports Steering from BMW, which comes as standard, has a progressive steering rack providing steering stability at high speeds but which requires significantly less steering input (turns of the wheel) when manoeuvring and parking.
Deceleration is taken care of by an 18“ high-performance brake system with 370mm discs at the front and 345mm discs at the rear. Aluminium callipers (4-piston on front axle, 2-piston on rear axle) painted in blue and with ALPINA lettering, in conjunction with high-performance pads, ensure fading stability and optimal pedal feedback.
ALL-WHEEL DRIVE
The optional all-wheel drive (not available in RHD markets) system offers even more traction and active safety in every and any driving situation. It exploits the technical potential of BMW’s xDrive system and its intelligent and dynamic distribution of drive power which continuously and fully variable distributes torque between the front and rear axle within milliseconds.
The torque distribution algorithm communicates with the ALPINA DME and the adaptive suspension system to increase driving dynamics and agility, particularly during high lateral acceleration, creating unexpected sporty and neutral handling despite all-wheel drive.
The new BMW ALPINA B3 Bi-Turbo with all-wheel drive is the fastest accelerating car ever to come out of Buchloe, capable of sprinting from 0 to 100km/h in just 4.0 seconds. Besides ensuring optimal traction during acceleration, the system also permanently monitors a wide range of sensory inputs – for example steering angle, lateral acceleration, yaw angle and speed – to distribute torque so as to achieve optimum propulsion and safety for example on snow or to counteract sudden changes in road surface friction.
DESIGN & EQUIPMENT
The 20” ALPINA CLASSIC wheels, used for the first time on a BMW ALPINA 3 Series model, look particularly striking and elegant. Above all, the B3 Bi-Turbo has presence and inherently looks powerful, while the ALPINA aerodynamic components fit perfectly into the modern design of the BMW 3 Series.
The functional design of the front spoiler ensures the effective flow of air to the cooling system and the brake air ducts. In combination with the rear spoiler (Saloon), this achieves excellent aerodynamic properties, considerably reducing uplift almost to zero and contributing significantly to high-speed stability.
The new B3 Bi-Turbo comes with an extensive list of equipment as standard, including leather upholstery, electrically adjustable heated sports seats, automatic climate control and xenon headlights. The interior is dominated by refined materials and offers an exclusive ambience. The door sills, floor mats, emblems in the seatbacks, instrumentation and a hand- stitched sports steering wheel in the finest LAVALINA leather make discreet references to the car’s exclusive origins.
Virtually no limits are placed on the individual design of a BMW ALPINA. From the paintwork to the interior trims and the colour of the upholstery – everything offered by the extensive BMW and ALPINA equipment range is available. Seldom does a BMW ALPINA leave the plant in Buchloe without making use of the virtually limitless personalisation options offered by the ALPINA factory. Our philosophy dictates that the customer can design his or her own entirely individual interior – assembled by skilled craftsmen in our leather workshop.
Availability of all-wheel drive and standard equipment may vary depending on country. For further details please contact the authorised local ALPINA representative or ALPINA head- quarters in Germany.
      03-05-2013, 11:46 AM   #2
leo89810
leo89810's Avatar
China
Drives: E90 M3
nice car, thx for share the info, but i wonder if zf 8hp70 gear box is also equip on normal f30 335i.
      03-05-2013, 11:55 AM   #3
Agamemnon
Drives: 2016 m3 ss2 zcp full leather
I was wondering the same thing about the transmission. If so, it is pretty impressive that the 8 AT can handle the torque. I see the diffs, drive shafts etc have been reinforced but it seems the transmission is what we have in our f30s. Since I was planning on a mild tune from Dinan when it becomes available, its good to know that the transmission can handle far more.
      03-05-2013, 12:12 PM   #4
drob23
drob23's Avatar
Drives: S4
I'm pretty sure the ZF 8 can handle quite a lot of torque, Audi had to use it on the RS7/S8 because the S-Tronic DSG could not handle the torque of the 4.0 TFSI which is around 520 lb-ft in the highest state of factory tune.
I couldn't tell, but does this Alpina offer a LSD? It looks beastly, wonder about the cost.
Edit: According to Wikipedia, there is a variant used in a Bentley capable of handling 900 lb-ft...holy crap that must be one hell of a torque converter!! I'd guess the 3 series shares the 8HP45 with the 1/5 series', which can handle about 450 lb-ft at the crank. Maybe someone has a better source than autoblog.
UNDRSTR
      03-05-2013, 12:57 PM   #5
leo89810
leo89810's Avatar
China
Drives: E90 M3
yea, absolutely same concern here. zf8hp45 is just have no potential to do tuning.
      03-05-2013, 01:44 PM   #6
Disabled Midge
Drives: BMW F30 318d
The Alpina B3 F30 is looking great! Can't wait to test drive it. The Alpina XD3 is certainly an visual improvement over the standard model. Wonder if it drives better as well.
      03-05-2013, 01:59 PM   #7
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
Drives: Audi R8 V10, BMW 530d xDrive
2009 335i  [4.45]
No they don't.
They did on the previous E9x model, where the LSD was available as an option; and the B3 GT3 was equipped with it as a standard.
Unfortunately they seemed to have abandoned this - maybe due to pressure from BMW as they may consider it as an M3-only feature that will serve as a way to differentiate the B3 from the future M3 (which will have a very similar engine setup as it seems).
Alpina_B3_Lux
Audi R8 V10; sold: BMW 335i
      03-05-2013, 02:03 PM   #8
metrathon
Drives: 2012 328i Sport Line
will it b cheaper or more expensive than a M3?
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara
      03-05-2013, 02:22 PM   #9
135iDCT
135iDCT's Avatar
87
Drives: 135I
I wish the 8hp70 in my car it can handle 700 nm
      03-05-2013, 02:31 PM   #10
drob23
drob23's Avatar
Drives: S4
Originally Posted by Alpina_B3_Lux View Post
No they don't.
Alpina_B3_Lux
Thanks for the info. Seems sort of strange, considering this appears to be more of an exotic limited production tuner model while the M3 is mass produced (I could be dead wrong on this). Not to say one wouldn't cross shop them, but wouldn't the alpina be more $$$ and have more refined colors/interior materials while retaining the ability drive seriously fast? With that kind of power, the lack of an LSD seems almost like a design flaw.
The M3 will be harsher, lighter and more visceral IMO.
UNDRSTR
      03-05-2013, 02:43 PM   #11
e92_m3
Drives: 2009 e92 m3
Looking good as always. Wheels need to updated. Alpina have been using the same style wheels for a long long time now...
Anybody know the ballpark price for this bad boy?
Hellaflush? All I could say is "effyo'flush","flushnuff", and Instead of 'illest', I'm calling it "faillest". It's just form over function nowadays...
-END RANT
      03-05-2013, 02:49 PM   #12
Raikkonen
Raikkonen's Avatar
130
Drives: 2017 M3 - DCT
The ZF 8HP70 transmission is the same used for the 2014 Jeep SRT (formerly known as the SRT8). The Jeep has 470 hp and 465 lb. ft.
The ZF transmission in the 335i is no doubt rated lower, hence the different model number.
You have to remember that ZF builds this 8-spd. for 13 manufacturers and countless models, hence there are no doubt several different variants.
If modifying your car to become a torque monster, a manual transmission would be much easier to modify and strengthen for our cars than the automatic.
I must be the only one in the world that thinks the 335i is "fast enough" as-is.
If I wanted an M3, I would have purchased one...
      03-05-2013, 03:36 PM   #13
ORIGIN M.
ORIGIN M.'s Avatar
2658
Drives: ///M
Love that colour a lot.
      03-05-2013, 03:41 PM   #14
positiveions
positiveions's Avatar
Lebanon
366
Drives: 09 MKV JETTA 2.5 & '16 F15 X5
Send a message via MSN to positiveions Send a message via Yahoo to positiveions
Looks so good from the side.
Exhaust designed in collaboration with Akra> This thing might sound so good.
      03-05-2013, 03:49 PM   #15
NAV8TT
NAV8TT's Avatar
Drives: 2013 ///M3 E92 DCT ZCP
So this is how the F80 M3 gonna look like I guess..
      03-05-2013, 03:58 PM   #16
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
Is that a N55 or N54, or something new??
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-05-2013, 04:18 PM   #17
hwelvaar
Belgium
72
Drives: BMW M135i MT
This gives an idea of where the next M3 can/will be headed.
I like it.
I want it... damn.
Can Alpina's be ordered via regular BMW dealerships, or how else ?
      03-05-2013, 04:20 PM   #18
hwelvaar
Belgium
72
N55, but modified, and second turbo added.
It's in the text...
"The design and construction of the excellent BMW 3.0 litre straight-six cylinder (N55) engine serves as a starting-point for a specially cast aluminium crankcase with Bi-Turbo capable flanges. These enable the mounting of two turbochargers along with required oil and water connections and a close-coupled catalytic converter arrangement. ALPINA specific NGK spark plugs and a forged steel high-strength crankshaft guarantee long-lasting stability."
      03-05-2013, 05:08 PM   #19
NICKTENN
NICKTENN's Avatar
It's in the text...
Damnit, I'm "that guy" who doesn't read the whole thing and asks questions already answered!
      03-05-2013, 05:11 PM   #20
Matski
Matski's Avatar
England
97
Drives: A slow BMW
I love Alpina's, this is not an exception
      03-05-2013, 07:42 PM   #21
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
wow its simply amazing. the engine is amazing. Surprised they didnt change the sideskirts at all.
2018 M3 COMPETITION Mineral white, Black,
carbon roof, black 20's, Mperf splitters/Blade, carbon spoiler, mirrors, etc
      03-05-2013, 07:44 PM   #22
metrathon
how much, how much? more than an M3?
