BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Gasoline door
Extreme Power House
      03-05-2013, 02:45 PM   #1
jzcrna
Drives: 2012 BMW 335i Sedan
Gasoline door
Does anyone have a problem with their gasoline door not closing all of the way when locked? It doesn't lock shut at all and looks like it is open even when the doors are locked. Is there a service bulletin or anything for this?
      03-05-2013, 03:08 PM   #2
Jbrock22
Jbrock22's Avatar
80
Drives: 340i
I have a problem with it when its very cold out. The spring does not retract all the way and the door does not close flush to the body.
      03-05-2013, 10:21 PM   #3
kppanic
Drives: 2015 Macan S
I had the same problem when I was picking up my car at the dealer. it was like a 30sec fix but now that the weather is cold it is happening again.
2015 Macan S Sapphire Blue 20" SD Wheels Painted Black SD Kit Sport Black Chrome Exhaust
2012 BMW 328i Sapphire Black Blk Interior Premium Executive
      03-06-2013, 03:53 AM   #4
KellerKiller
KellerKiller's Avatar
Drives: 335i M, EBII, mit alles
you have to open and close it with the doors unlocked, otherwise it won't function properly.
      03-06-2013, 12:58 PM   #5
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
I had the same problem and when I took it to the dealer they told me that the little string that attaches to the cap has to be pointing downwards in order for the door the close properly and lock
Sounded like bs to me considered I never had to care about it in any other car but it does work.
      03-07-2013, 12:33 AM   #6
loosenit2
loosenit2's Avatar
Drives: 12 328i Luxury
you have to open and close it with the doors unlocked, otherwise it won't function properly.[/quote]
+1 this
      03-07-2013, 01:17 AM   #7
AndDown
Just Copacetic!
Drives: 2016 F36 428i GC AlpinWeiss
I don't seem to have a problem with the passenger doors locked and only drivers door unlocked. Plus, the OP is in Florida and it doesn't get cold enough for the spring mechanism to malfunction, so not sure if the cold winter weather has something to do with it.
      03-07-2013, 05:25 AM   #8
KellerKiller
True, mine works after I open only my driver's door to get out and fill up. But if you're of the habit to lock the door after you get out, before you finish filling up, you'll make problems for yourself.
      03-07-2013, 11:24 AM   #9
AndDown
Just Copacetic!
Agreed - the gas cover locks as well with all doors locked, so if one gets out, opens the gas cover, then locks the doors, the cover will not close all the way...hmmm?
      03-07-2013, 11:50 AM   #10
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
problem for us in cold weather...
I had it replaced.
SOLD: 2012 335i Mineral Gray
