BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Smoke from 1 pipe
      03-06-2013, 10:14 AM   #1
Dinh335
Drives: 2004 RX8/2015 M3/2017 X5 35i
Smoke from 1 pipe
Noticed this morning warming up car, that upon startup, smoke only comes out the right tail pipe (335). The right also has noticeably more soot. None out of the left one...of course after a few seconds or a minute they both don't blow any smoke...but wondering why it's just the right? anyone else with this?
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
      03-06-2013, 10:22 AM   #2
BMWforLife
BMWforLife's Avatar
Drives: 2014 335i
The left pipe has a flap that closes off the outlet upon start up, and once the engine is warmed up it will open and both pipes are flowing exhaust.
If you start the car and get out and listen, maybe even peer into the left pipe from a few feet back (don’t inhale the fumes) you can hear/see the flap open.
Also, it isn’t smoke, its water vapor. at least...I hope your car is not smoking lol.
many people disable the flap (known as the “golf tee mod”).
The flap is pretty much there to reduce noise at low RPMS
14' 335i Sport. AW
Prem/Cold/Driver Assist/Tech Packages
CG Precision R-1 Exhaust
      03-06-2013, 10:45 AM   #3
n55x3
Drives: n55 BMWs
This is completely opposite of how our N55 equipped motors and exhaust work.
Ours work exactly as the OP described and is normal.
On cold startup the flap opens until motor reaches a certain temp. I think our flap closes pretty quickly, like within a minute. Then it remains closed in normal MILD driving situations. Under hard throttle or anytime above 4k rpms the flap opens to reduce back pressure which ultimately increases performance and sound.
Totally normal to have one dirty pipe and one 'cleaner' pipe. I do agree on the flap mod though and it is something I've done on all our N55 vehicles, in one way or another. For 1 I like to have my pipes get dirty in symmetry and second, I like the sound of the exhaust when the flap is open all the time.
I haven't confirmed with a 335i (ours is due in a couple weeks) but I suspect this methodology is consistent across all N55 equipped vehicles.
      03-06-2013, 10:49 AM   #4
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [2.83]
It's normal.
      03-06-2013, 03:15 PM   #5
Dinh335
cool- i assumed it was normal, so that's good...always curious on little things i notice on the new ride.
and yes, it's vapor not smoke
thanks guys.
      03-06-2013, 04:36 PM   #6
dcg71
Australia
51
Drives: F15 X5 25d / Ducati Monster
Yes its normal. Disagree on disabling the flap though. Its there for a reason, to balance back pressure between low and high RPMs.
      03-06-2013, 06:03 PM   #7
bcl0328
Drives: 2012 328i
Originally Posted by Teemo Panda View Post
It's normal.
Never underestimate the power of the Scout's code.
      03-06-2013, 11:40 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Agree
SOLD: 2012 335i Mineral Gray
