BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > stick
Extreme Power House
      03-06-2013, 10:34 PM   #1
N-Y
Drives: 2012 BMW 328i
stick
i have a 328i 2012 F30... i've noticed that the people with 335i have the leather base under the stick... is it possible to get that on a 328i?
here is the style i have
i want
      03-06-2013, 10:35 PM   #2
BMWforLife
BMWforLife's Avatar
Drives: 2014 335i
leather base is if you have the Sport auto option(notice the paddle shifters), also the shifter itself differs
I’m sure there is a retrofit somehow, but have not seen anyone do it. And presumably its not that cheap to do.
14' 335i Sport. AW
Prem/Cold/Driver Assist/Tech Packages
CG Precision R-1 Exhaust
      03-06-2013, 10:38 PM   #3
J Tiberius
J Tiberius's Avatar
South Korea
Drives: Imperial Blue Sport Line
That has nothing to do with the 335, it comes with the sport auto transmission. It's available on either 328 or 335 so long as you get the sport line or M sport and opt for it.
2012 F30 328i, Imperial Blue, Sport Line, ZPP, ZPS, ZTP, Sport Auto, Heated Seats, Xenons, H&R Sport Springs, Michelin Pilot Super Sports
      03-06-2013, 10:39 PM   #4
N-Y
ah ok... i see what u mean.. ah well lol
      03-06-2013, 10:39 PM   #5
N-Y
i have the sports line.... but i dont have that leather base
      03-06-2013, 10:43 PM   #6
BMWforLife
BMWforLife's Avatar
Drives: 2014 335i
just because you have the sports line does not mean you get the base...
you have to add the SPORT AUTO option ($500 USD) to the car, not the standard 8 speed option
14' 335i Sport. AW
      03-06-2013, 10:47 PM   #7
N-Y
what does the sport auto option do?
is it possible to add it now?
      03-06-2013, 10:53 PM   #8
BMWforLife
BMWforLife's Avatar
Drives: 2014 335i
from bmws website
"The close spacing gear ratio in the optional 8-speed Sport Automatic Transmission enables maximum use of the optimum rev range, significantly lowering fuel consumption and enhancing shift comfort. "
I believe it gives double clutch performance levels. I doubt you would be able to add it post production, and if you could it would probably be more costly than its worth to get it from a dealer (even though most of it is programming)
14' 335i Sport. AW
