BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > 3 and 4 Series Ordering / Pricing / Order Tracking Forum (and European Delivery) > Must have F30 options?
      03-20-2013, 03:22 PM   #23
Sabo
Drives: F30 330d Msport+
Professional nav is a must have as it's the main focus point of the whole interior, without it looks a bit plain and cheap. For me the sun protection glass also makes the car look a lot better and it's handy when you got your child/children sitting in the back regularly(not a big fan of aftermarket tinting), also electric folding mirrors as you don't want to spend 30k+ on a car and do it by hand when you get out of it.
      04-07-2013, 04:49 PM   #24
Chopi06
Vietnam
Drives: Msport 335i BSM
Definitely go with M-sport package and lighting pack as these two enhance the look of your car greatly. For the interior, I would get Tech pack and heated front seat ( it is too hot in my place to ever need heated front seat '.' ) . Also, if you are not planning to get an after market set of wheels then go with the 403M 19 inch because in my opinion the 18 inch makes it way less agreesive.
      04-07-2013, 10:17 PM   #25
RPM90
Drives: 340i M-sport AT
Originally Posted by colcad View Post
I'm in Germany and also ready to order (US spec) 328ix sportwagon, Msport, EB2, tech , DHP, paddles, alarm. I've driven several demo cars with different options on weekend road trips during my Bavarian blitz because I too am uncertain about the options. My take: Tech(the HUD is awesome and very useful both in the city and when driving fast on the autobahn). DHP-is really good if you want a tight car (especially the x-drive where you CANT get sport suspension) The heated wheel is nice but I'm not sure I want to spend an extra $2,400 to get it (leather plus CWP). The vinyl is really good-even for 6 hour trips. The paddles are fun (thats why I'm getting them), but you can' hope to shift this slick 8 speed as well as the auto does it in sport mode. Lights-Frankly I think people are ordering the lights for the looks, not the function (?). I currently have Xenons on my CTSV and have driven 3s with and without-no big deal IMO.
The need for xenons is really dependent on where you live and drive.
If you live in the city xenon's won't add much to night lighting.
But if one likes the angel eyes halo, then xenons are the way to go.
If you live in suburbs or country area xenon's are VERY functional as the lighting in the suburbs and especially country areas is quite limited.
Xenons provide a VERY noticeable lighting advantage allowing you to see farther, brighter, and sharper.
OP:
As you've already figured out, if you go with a 335i you'll get more standard items for the increased price. And along with the price increase you get the bigger brakes and the more powerful and smoother engine.
The 328i's 2.0 turbo is an excellent engine with plenty of strong power.
The 2.0T is more than up to the job.
Granted, the 3.0 isn't outrageously more powerful, but it is noticeably more powerful and quicker.
The 0-60 with the AT has been tested to be anywhere from .5 to 1 second faster. It depends on you if that makes a difference. But it's not just the time difference in acceleration it's also the feel of the acceleration, which is noticeably stronger with the 3.0T for obvious reasons, it's 50% larger in displacement, plus the inline 6 configuration is legendary in it's smoothness.
Leather isn't necessary as the leatherette is an excellent and more durable material, despite some thinking that the leather BMW uses is more durable, it isn't.
If you look at 3yr + used 3 series you'll see that the leather shows wear, and the leatherette does not. But if you keep the leather clean and conditioned, as one should with all leather, over time the leather becomes softer and more supple and takes on an "aged" patina that's unique to leather.
The leatherette doesn't require the added work and it'll look the same after 3yrs as it did when new.
If you get leather, then consider the whole premium pkg as you get some usable items for not much more money like the auto dimming rearview and side mirrors, and homelink that replaces the need for a separate garage door opener remote.
All F30's come with blue-tooth. The "enhanced" option simply gives you the option to stream audio. If you need or want that, then it'll cost $650 in US pricing.
The "sport AT" option is $500 and for many of us it's worth it.
With it you get paddles shifters, a different and cool looking gear lever with leather boot. The performance enhancement is that ZF and BMW claim that the sport AT can perform up and down shifts more responsively and do it a tad quicker.
If you go with sport or Msport you will get the sport suspension.
On a RWD you will get the full sport suspension including the stiffer springs, lower ride height, and sport dampers. This enhances handling due to the stiffer springs and stronger damping, but also due to the reduced ride height that lowers the cars center of gravity.
With Xdrive you only get the sport dampers but you don't get the lower ride height.
DHP pkg with RWD on sport and Msport with have the same lower ride height, but will include the adaptive dampers that continually adjust their damping based on road surface conditions. Also, you can set the dampers to 2 different settings, 'comfort/normal' or 'sport'.
The difference in the settings is noticeable. In 'comfort' the stiffer springs are controlled in a softer manner allowing for a more compliant and smoother ride on bumpy roads and on longer highway drives where you won't feel the undulations as much and the ride will not be as "busy" or "bumpy".
When in 'sport' mode the dampers firm up and provide stronger damping control of the springs providing better chassis control on twisty roads, and it reduces body lean angles in turns and transitional handling.
The advantage to adaptive dampers is more that you can have a softer and smoother ride when you're on the highway or smoother roads and don't need the added firmness.
In 'sport' mode the firmness isn't much different than the standard sport dampers as it feels pretty much the same. Yet still with the adaptive dampers in sport they do provide active damping control and adjust themselves better and quicker than the no adaptive so there is a bit more control over the springs over different pavement conditions.
With DH pkg you also get the variable ratio steering rack that increases ratio once you pass 100 degrees of steering wheel turn. This means that once you've turned the steering more the wheels/tires will turn even more as you add more steering. This is advantageous more so in parking lots and when parking in general where you do use bigger steering angle inputs.
It's not a huge difference, but it's included and does help when parking a little bit.
DH pkg with Xdrive. You will get the adaptive dampers, but you won't get the lower stiffer sport springs. You'll get a bit better handling when you set the dampers to 'sport' but it won't feel the same as it does on a RWD.
I think this is a bad decision on BMW's part.
Audi offers a sport and adaptive suspension on their AWD's and they include lower and stiffer sport springs.
If you really need AWD, the Xdrive is it. But, consider that a RWD will cost less and give you the full sport suspension. With the cost savings you can get a winter wheel set with winter/snow tires.
Many drivers have experienced great winter control with on RWD with winter/snow tires.
Like you I wanted what I felt was necessary and didn't get tech that I didn't want, even though some of those things add more luxury convenience.
But what is necessary and what is luxury is different based on individual wants.
I wanted a louder and cleaner audio so I paid for the HK.
I have no use for NAV or the heads up display, nor the enhanced BT.
My 335i Msport:
Sport AT
Premium pkg.
DH pkg.
MSRP: around $52,000 US pricing.
I went with the 18" summer tires, but I've since installed Conti DWS AS tires that I use year round.
Whew, that was a long post.
      04-27-2013, 06:45 PM   #26
bimmer13335
Drives: 2013 335i xDrive Sport
Just had a quick question about the DHPckg, as I've recently placed my order for 335i xDrive Sedan without it.
I'm more interested in having a smoother ride for those long trips on highways. The highways are not bad, but they have some bumps to them. If I set my car to 'Comfort Mode' without the DHP, will it still be a very comfortable ride?
Or will it be necessary to get the DHP for the added benefit of the adaptive dampers? I guess what I'd really like to know is...is it worth getting the DHP on the 335i xDrive.
Thanks for your time!
      04-29-2013, 02:39 PM   #27
ColoBlueMax
What, me? worry?
Drives: WRX Wagon
Don't forget to add the 6NS Enhanced USB and Bluetooth plus Smartphone Integration
I've read in several places that the 6NS Enhanced USB and Bluetooth plus Smartphone Integration is required to get full functionality of the iPhone integrated features. For the MY2013 builds, this required a separate selection of the 6NS option (after first selecting either the ZTP technology package or 609 navigation pro system by itself). It appears that for the MY2014, 6NS is automatically included with specifying either of these packages.
      04-29-2013, 03:30 PM   #28
R12ax7
R12ax7's Avatar
63
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Originally Posted by BMWforLife View Post
I had a 328i with leather for 6 months. now i have a 335i with leatherette. I notice a small difference in feel, but the leatherette has not worn at all in the drivers seat yet whereas the leather did quickly, and no passenger has ever known it was not leather until i told them.
get a 335 regardless. it comes with more options standard anyways. (moonroof, xenon, alarm all included, theres $2350 already).
if you want to play music wirelessly you need the enhanced bluetooth. 650$. if your strapped for $ on options I would put this low on the list. and you don’t need navigation for this as posted above..
I have heard this time and time again and have experienced first hand the quick wear of BMW leather. I am about to turn in my 2011 e90 with Chestnut leather and it is pitiful how it looks after less than 2 years and under 15k miles. My 2008 e90 with Terra was not much better. I am about to experience the leatherette first hand in 3 weeks (I was very hesitant to go for it at first) but have PM'd numerous people on the board here about the leatherette and everyone has spoken very highly of it.
I agree with others that the lighting package is a must if you go for the 328. Same with the DHP (although I have yet to experience it first hand).
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      04-29-2013, 03:47 PM   #29
ocso1606
ocso1606's Avatar
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
Heated steering wheel
M5 with lots of goodies
      05-02-2013, 11:39 PM   #30
infinitigor
Drives: 13' 335i
sport / msport package. those sport seats are a MUST, otherwise it will feel like your sitting on a bench
      05-03-2013, 08:18 AM   #31
64-bit
64-bit's Avatar
Drives: 19 Ford Raptor - On Order
Me 2
But living in New England 19" only on weekend cars and not on you daly car
2016 M3, Mineral White, SO Leather, MANUAL - ED 11/26/2015
2013 335i, Blue, M-Sport, Auto w/Sport Trans - ED 06/10/2013
      05-04-2013, 08:38 AM   #32
BoneMan_E60
BoneMan_E60's Avatar
Drives: 535xi
Originally Posted by 64-bit View Post
Me 2
I second that statement. Living in the NY metro area, The roads will eat up 19" rubber. I have a friend with 535 M sport with 19" rims. He has blown 5 tires in 1st year ownership! Some on "minor" potholes. The tire insurance package is like $2K. I would stick with 18".
As far as AWD in NE. I sold my beloved 328i when I moved here for A4 quattro, thinking I needed AWD for snow. I probably would have been ok with a dedicated set of snow tires. AWD really only helps in deep snow, ie unplowed roads with 6" or more snow; or climbing steep grades. So if you can stay off roads until they are plowed and only need to get around when it is light snow, I think u ok with RWD with snows. I think this is how most of Northern Europe does it. I currently have 535xi with all-seasons and have gotten stuck on steep grade driveway that was unplowed. My next car will likely be F30 335i, back to RWD and manual tranny.
      05-04-2013, 01:10 PM   #33
64-bit
64-bit's Avatar
Im 100% with you! Regular seats sucks, unless you are oversize.
      05-04-2013, 01:16 PM   #34
64-bit
64-bit's Avatar
Me 2
My last car was a 335xi and the car did not fell near as sporty as my other 2 RWD (2007 335i & 2010 lexus IS 250)
You may use your AWD maybe 3 x on a whole year, and I rather to work from home on those days, all other 362 days you can get by with snow tires.
Im back to RWD, yehhhh!
      05-05-2013, 03:12 PM   #35
BMWforLife
BMWforLife's Avatar
Drives: 2014 335i
I have had my 335i with leatherette for over 2 months and I don’t even notice a difference really (other than less wear and tear). Enjoy it!
14' 335i Sport. AW
Prem/Cold/Driver Assist/Tech Packages
CG Precision R-1 Exhaust
