Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 328i M peformance exhaust hp gains?
      03-14-2013, 01:15 AM   #1
momo3605
Drives: 2016 M4
Since active autowerke claims 9hp/13tq, does that mean that power can be gained from the M performance exhaust as well?
      03-14-2013, 01:17 AM   #2
momo3605
Drives: 2016 M4
Since they are both axlebacks...
      03-14-2013, 01:52 AM   #3
pkimM3r
pkimM3r's Avatar
136
Axle backs are worthless imho. Get something for a decent price which is downpipe back. Do these cars have the cats in the middle of the downpipe as well?
      03-14-2013, 02:10 AM   #4
David328M-Sport
Australia
62
No. Just a leaner, meaner G R O W L.
More meaner than leaner.
Ok, so it's not even leaner.
At all.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-14-2013, 04:06 AM   #5
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I saw 7whp 20ft lbs with a catback. That was likely mostly muffler. I would say the MP units likely give little hp, within variance in dyno runs, say 2-3whp.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-14-2013, 09:54 PM   #6
zibawal
Drives: 2012 X5D
Sounds realistic!
      03-26-2013, 10:35 PM   #7
JOHN328
Feeling horny
Australia
28
Drives: BMW F30 328
I've just installed my m performance exhaust for my 328i.
Although I don't think there's any said hp gain but I can feel a little more power from it and the turbo sounds a bit louder too. Must be from the better air flow.
So far I'm loving the exhaust, a little bit louder would suit me more, so by time when I get my bms and dp that should sort out all my problems.
Cheers
BMW F30 328i Sport Line
      03-26-2013, 11:17 PM   #8
overkill1125
overkill1125's Avatar
Drives: 2016 435xi Coupe
Is there a resonator on the 328? I see a can near the middle and not sure if that is the resonator or cats?
      03-27-2013, 12:50 AM   #9
1GrayBulldog
Drives: 2013 135i
Yes that center can in the exhaust is a resonator.
      03-27-2013, 07:34 PM   #10
overkill1125
So did anyone removed it like most do it on the e90?
Surprised that the BMW Perf Exhaust does not remove it on the F30 but it does on the e90
      05-26-2014, 12:06 PM   #11
overkill1125
Update?
      05-26-2014, 12:22 PM   #12
rustyminded
rustyminded's Avatar
116
Drives: BMW 328i
Nope AA axle back is catless which I experienced & notice a huge difference in torque, axle back is worthless if it's catted but catless will make a difference.
      05-26-2014, 12:42 PM   #13
rustyminded
116
Drives: BMW 328i
what is the brand of this catback
      05-26-2014, 04:31 PM   #14
MikeVictor
Australia
150
Drives: anything given a chance
First time I've read there's a cc in that section of the exhaust. Last I knew there was one in the mid- and one in the down-pipe. From your other post your AA system is also droning, which I have to say I wouldn't be a fan of.
      05-26-2014, 05:10 PM   #15
rustyminded
116
Drives: BMW 328i
yes it does drone if you installed CATLESS downpipe too not alone of course and not all the time just certain times in hot weather ONLY but given the sound everyone is going crazy what exhaust is making that sexier sound than a stock 335i, no one believes this is coming from a 4 banger.. aside all that maybe what's causing the drone is a leak
      05-26-2014, 06:08 PM   #16
overkill1125
is cat the same as resonator? I was referring to the resonator that is located smack in the middle of the pipes. I know the downpipe is in the front.
Add a catless downpipe and it will definitely change the sound but not planning to do that yet.
Just bought the MPE and wanted a bit more sound from it and therefore was considering in removing the resonator and replace it with a straight pipe.
Would that do anything of will it just make the interior noise worst.
      05-26-2014, 08:06 PM   #17
MikeVictor
Australia
150
No, a "cat" is a catalytic converter. A resonator produces the sound a manufacturer wants and is also designed to deliver performance at a certain rpm range. Fiddling with resonators often reduces performance as well as creating pollution issues if you live somewhere that performs pollution testing on cars.
      05-27-2014, 10:33 AM   #18
Jamesons Viggen
RE, Rogue Engineering
