BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > jb1 issue.
      03-14-2013, 02:29 AM   #1
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
jb1 issue.
Sup fellow f30 members, so I have a 328 n26 with a jb1 with 5k on the car and i've noticed my car makes a grinding sound on start up and changing gears from 1-3k rpm. Not sure what it is, might be a charge pipe? Anyways should I remove my jb, clear it, and take it in? Don't think its normal.
      03-14-2013, 04:12 AM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Wrong forum.
But yes.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-14-2013, 10:21 AM   #3
BMWFanatic2008
BMWFanatic2008's Avatar
103
Drives: M4
Hope the dealer doesn't have a way of checking whether you had it installed before.
F82 M4 | Yas Marina Blue | SO Extended Leather | DCT
F80 M3 | Sakhir Orange | SO Extended Leather | DCT (Gone)
F30 335xi | MSport | Estoril Blue | Sport 8AT (Gone)
F30 335xi | MSport | Estoril Blue | 6MT (Gone)
E92 335xi | MSport | Le Mans Blue Metallic | AT (Gone)
      03-14-2013, 11:21 AM   #4
Joshhleee
///M Enthusiast
Joshhleee's Avatar
im going to go to EAS to get my car cleared.
      03-14-2013, 04:11 PM   #5
bnekic
Drives: 2013 328i xDrive Sport Line
My car kind of makes a grinding sound upon cold start up but goes away after a few minutes (once car is warmed up a bit).
      03-14-2013, 07:55 PM   #6
David328M-Sport
Australia
62
How is this related to a JB1 issue?
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-15-2013, 01:13 AM   #7
Joshhleee
///M Enthusiast
Joshhleee's Avatar
or i thought the jb did something cause of the extra horespower and torque, idk just my thoughts.
      03-15-2013, 02:02 AM   #8
David328M-Sport
Australia
62
Not a grinding noise though.
Have you had a chance to remove the JB1 & test?
      03-15-2013, 09:32 AM   #9
Joshhleee
///M Enthusiast
Joshhleee's Avatar
not yet.. too lazy to take it out, LOL. im probably going to end up doing it asap then check before taking it in though. but you do have a good point, doubt the problem is due to the jb.
      03-15-2013, 01:51 PM   #10
BMWgasm
Hooah!
BMWgasm's Avatar
Drives: 2011 335i M Sport
Too lazy? It's potentially hurting your car and you're too lazy to take it out to see if its the problem? SMH.
'11 E90 335i M Sport Black Sapphire
'13 F30 328i M Sport Black Sapphire
      03-15-2013, 04:27 PM   #11
David328M-Sport
Australia
62
With thousands of JB units out there (N54,55 & 20), there hasn't, to my knowledge, been one single unit causing grinding. I doubt very much this is the first. We would be the VERY first to know if it did.
How does a piggyback tune affect a cold engine/transmission grinding startup?
      03-15-2013, 10:15 PM   #12
addm
Drives: 2013 328i xdrive sportline
As the power gain with JB1 is fairly modest, most likely it is coincidental that your car is having grinding noise and happen to have JB1. Factory tuned cars have problems all the time. And since JB1 is the most popular tune right now, the likelihood of such owner reporting problem with their car is more.
But I would still take off my tune just to be on the safe side.
      03-16-2013, 01:37 AM   #13
RollingLower42
RollingLower42's Avatar
30
Drives: 2012 BMW 335I
When you say grinding sound, is it grinding from the engine? Does it do it while your moving or not moving? Could it be something else like something with your suspension grinding?
      03-16-2013, 03:47 AM   #14
Joshhleee
///M Enthusiast
Joshhleee's Avatar
its when i first start the car and im idle in park, then the other sound happens when moving slowly in low gears around 1-3 rpm.
