BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 328i JB4 (Stage2) E85, 13.0@109 Run
      03-19-2013, 07:33 AM   #1
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Some more updates for the Stage2
BMS was out doing some VBOX testing with the 328i. 0-60 in 4.6s and a best 1/4 mile time of 13.0@109. Knocking on 12s door.
The car is still completely stock other than the JB4 and E50 fuel. This was using map 7 which peaks at 23psi.
They are planning to do some pump gas dyno testing later this week.
      03-19-2013, 07:53 AM   #2
Turboedv6
Drives: '13 Apline White Sportline 328
Looks good Mike! Can't wait!
2013 Alpine White 328xi Sport Line
2005 Summit White Chevy 2500 CC Duramax (stock F30 killer)
2005 Wicked White Evo 8 11.71 @ 117mph (stock turbo)
      03-19-2013, 08:43 AM   #3
bnekic
Drives: 2013 328i xDrive Sport Line
Awesome, can't wait to get stage 2!
      03-19-2013, 07:40 PM   #4
RSXDC5
RSXDC5's Avatar
138
Drives: M3
Awesome results!! Throw on a turbo-back exhaust and some better tires and you are EASILY in the 12's!
2015 M3 - Alpine White 6Spd
LED's, CCB's, Adaptive Dampers, Swifts, VRSF DP's, GC Camber Plates, 275/305 AD08R, Signature Wheels SV103 19x10.5/11.5
      03-19-2013, 09:15 PM   #5
ixse
Drives: 2015 boxster s
do you have to use E50?.. why not just go for E85 tune?
please tell me tune will be avail for N26 & manuals ~
      03-19-2013, 10:17 PM   #6
Casualvic
Drives: 328i xdrive
What mode where you on? Comfort, sport, or eco?
      03-19-2013, 10:23 PM   #7
Turboedv6
I'm sure he was in sport mode, unless he was going for most mpg in a 1/4 mile.
      03-19-2013, 10:30 PM   #8
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
The modes are indistinguishable at wot, so you can dyno in any of the the modes and make the same power. So if your are flooring it, it does not matter.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-19-2013, 10:35 PM   #9
Turboedv6
I know, it was just a failed attempt at humor.
      03-19-2013, 10:37 PM   #10
Casualvic
Drives: 328i xdrive
I have to admit...... that was hilarious!!!!!
      03-19-2013, 10:40 PM   #11
Turboedv6
Cmonnnnnn
      03-19-2013, 10:49 PM   #12
Casualvic
Drives: 328i xdrive
You should do standup comedy...it was funny though
      03-19-2013, 10:52 PM   #13
Turboedv6
I'll give it a shot some time
      03-20-2013, 02:20 AM   #14
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
yayyy, and this does work for the n26, just leave the first port unconnected. cant wait to see the pump fuel results.
      03-20-2013, 04:52 AM   #15
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
It's only a matter of time!
I vow to dyno within a week of receiving this tune.
If I'm lucky, BMS will need an N26 for Beta
      03-20-2013, 05:35 AM   #16
Turboedv6
I'm going strait to the track fueld by C16 and maybe some LOL gas.
      03-20-2013, 07:05 AM   #17
Mike@N54Tuning.com
I'm not sure the tuning can handle straight E85 so they are mixing it with pump gas for these results.
Mike
      03-25-2013, 07:28 PM   #18
BRM6
BRM6's Avatar
Brazil
Drives: 328/335/M235i/M4 - Current M6
Mike
Which makes it even more interesting for me... We got E everywhere!
      03-25-2013, 09:48 PM   #19
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
Hey terry,
If you need a beta tester for the n26 lmk. I can do irwindale runs for the 1/8th times. I beta tested your n52 and n55 tunes! And ill dyno it at eas
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      08-07-2013, 10:34 PM   #20
F32
Wanted to resurrect this post because I found it interesting...was this car a manual or auto? I'm curious to see updated VBox figures as well. I'm sure the Stage 2 tune has been tweaked a bit since March, so that alone should be good for 12s at 110+. With a turbo-back on top, this setup should move.
I'm curious what the limiting factor is for testing on a higher mix of E85. Is straight E85 in the tank out of the question or perhaps too risky for the fuel-system?
      08-08-2013, 12:15 AM   #21
RSXDC5
RSXDC5's Avatar
138
Drives: M3
Hopefully I can answer your question a bit...my car is completely stock with the exception of the JB4 Stage2. I have tried Map1/Map2/Map7...
To get to the desired 100oct to run Map7, I mixed my 91oct with 45-50% E85 (~105oct) as recommended. I can't speak for the N20 engine, but the N26 that I have will not successfully work with a 45-50% E85 mix while close to or at WOT. The engine hesitates, studders, and bogs down. To troubleshoot at the time, I switched to Map2 and then Map1, all Maps had the same problem. Once I filled up again, I blended my 91oct with enough E85 (roughly 15%) to get to 93oct so I could run Map2. Once I did this, all problems went away...this applies to Map1 as well. In the future, if I would like to run Map7 again, I'll have to fill up with 100% (traditional) 100oct.
      08-08-2013, 12:32 AM   #22
JNM3
JNM3's Avatar
215
Drives: Moonstone F80 ///M3
I almost fell out of my chair laughing.
For my own records, I ran a baseline on my 335i a couple weeks ago and installing BMS Stage 1 tomorrow then throwing it back on the dyno. Planning on recording any upgrades as I go along so that I can see the differences as well. I'll post up charts tomorrow night when I get them from EAS.
Not looking for Molly, then? LOL
-Justin N.
IG: @MoonstoneM3
