03-19-2013, 07:11 PM | #1 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
F30 Golf tee mod, Clamp alternative to Wire.
Its winter, Im bored and I sort of came up with this alternative way to do your golf tee mod on your F30.
Why you ask? Dosent the wire work just fine. Yes. It does. In fact Its still on my M Performance muffler. Ill put the clamp on it later on. But alot of people dont like the idea of putting cheap wire on their expensive cars, so this looks much better and neater I think. So since I did my own muffler upgrade, I got to keep my oem muffler. So Ill be demonstrating on it. I just used a simple clamp. Its best if you have a dremmel tool to cut with. Tools needed, Dremmel 8mm socket and ratchet (to tighten clamp) Caliper (not really reqired) use a ruler. Let the pictures do the talking.
FBO-PS1 and stuff
03-20-2013, 04:28 AM | #2 |
Rep 664
Drives: 2013 BMW 335i
Very nice idea... I shall go do this instead. More secured than wires. Haha.
03-20-2013, 04:32 AM | #3 |
Rep 664
Can I just buy that piece from you? Haha.
03-20-2013, 01:31 PM | #4 |
Dejan
1753
Rep 4,197
I mean yeah I can make you one. I can't guarantee it won't break if you over tighten it, it becomes very fragile where the 3.1mm of the clamp remain. It's still better then wire as my wire snapped once. Well see how this holds up.
FBO-PS1 and stuff
03-20-2013, 02:31 PM | #5 |
Rep 664
can you make me one? how much do you want for it? i don't have a dremmel
03-20-2013, 07:31 PM | #6 | |
Dejan
1753
Rep 4,197
In all honesty, if you wanted to try and cut the clamp with some shears it may work for you as well. You dont necessarily need a dremel. Just putting that out there.
FBO-PS1 and stuff
03-20-2013, 08:25 PM | #7 |
Perf BMW mag issue 147, 159
414
Rep 6,803
I simply removed the spring clamp and tack welded the flap in the open position. No worries of anything ever coming loose
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
03-20-2013, 09:13 PM | #8 |
Dejan
1753
Rep 4,197
That's even better! Clean no wire/clamp. Only thing is reversing it, it be a little tougher to get the weld back off, but with the right tool anything is possible
FBO-PS1 and stuff
10-21-2017, 12:12 PM | #9 |
Rep 516
Drives: E85 Z4M, F82 M4
Tent Peg Alternative
Sorry to revive and ancient thread, but I found this and intended to replicate it. I don't have a Dremmel, so I had difficulty cutting the clamp properly. Then I found a small tent peg (actually may be from a holiday lawn inflatable) in my garage......no cutting required.
10-21-2017, 12:15 PM | #10 | |
Dejan
1753
Rep 4,197
If I can find my clamp and if you want it, it's yours just pay the shipping to yourself. I don't need it. EDIT: Nevermind just saw your photos and what yuu did looks solid stick with that
FBO-PS1 and stuff
10-21-2017, 12:23 PM | #12 |
Rep 516
Apparently it throws a code when unplugged and in my case the original spring broke and fell off, so it seemed like the mod was the easiest solution for the "kill two birds" solution. Valve rattled like hell without the spring.
10-21-2017, 12:27 PM | #13 | |
Rep 516
10-21-2017, 01:21 PM | #14 |
DINAN SELLER
158
Rep 542
interesting, haven't seen a code from this connector being unplugged.
10-21-2017, 07:30 PM | #15 | |
Rep 516
