BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > License Plate Move Kit
Extreme Power House
      03-23-2013, 11:26 PM   #1
MNBart
Drives: 2016 X5M; 1997 M3
Anyone have pictures and tried to move their license plate somewhere else? i need it gone haha
Any good kits to recommend? Looking for fairly cheap but want it done right
thanks in advance!
      03-26-2013, 01:14 AM   #2
reedo302
Estorilblau Member
reedo302's Avatar
Drives: Dinan Estoril 328i M Sport
http://www.turnermotorsport.com/p-14...335i-2012.aspx
If you don't have front PDC, this is the best option.
      03-26-2013, 01:23 AM   #3
1bad335
Drives: 2007 335I/ 2012 335I sportline
thanks in advance!
They make kits that go into the tow hook whole and there are kits for PDC cars as well. For me it's more about getting the right guy to repair the 8 wholes they put into that front plate mount. When I got my car I told them "do not put a front plate on" they agreed but the mount was already on. After checking on here I found that that front mount is on there with 8 screws. Only way to do it right is have the whole bumper painted since I have BSM. So, kits are out there but be aware what lurks under that plate attachment.
Modbargins.com makes a kit for and w/o PDC.
http://www.**********s.com/No-Holes-...E36-E82-Z3.htm
      03-26-2013, 03:39 AM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Sorry for the less-than-ideal pic. This is the kit I am using, works great! -> http://www.gominigo.com/BMW.html
      03-26-2013, 03:37 PM   #5
MNBart
i really like that. however, i didn't realize there were 8 screws. seems like overkill...
thanks guys
      03-26-2013, 04:44 PM   #6
1bad335
thanks guys
It is way overkill and costly to fix right. the plugs IMHO look horrible, just to many of them.
      03-31-2013, 09:46 PM   #7
pitzerwm
Drives: 2012 335i
Being cheap, I took a rubber plug about 1" in dia. drilled a hole in the middle. Put a "gripping" nut on the back and a bolt thru the license plate holder and tightened the bolt until the rubber plug firmly gripped the towing "hole".
You do need to offset if you have a sensor there.
I didn't want to mess with removing that center piece.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
