03-30-2013, 01:17 PM | #1 |
Rep 157
Drives: 2006 BMW 325i Arctic Metallic
Quick drive review of BMW 328d and B38 turbo 3 cylinder engine (motortrend)
Featured on BIMMERPOST.com Output drops to 180 hp and 280 lb-ft or torque (at 1750 rpm), and 0-60-mph times will stretch to about 7 seconds, but we're promised a 4 in highway fuel economy. Final EPA figures are expected any day, but BMW expects a 20 percent improvement over the 2.0-liter TwinPower turbo gas version, with which this engine shares some 40 percent of its parts, including the aluminum block. If that holds true, we'll see 28 mpg city/40 mpg highway in the automatic sedan. With a 16-gallon fuel tank, that adds up to over 640 miles of bladder-busting highway range. When it goes on sale later this summer (production starts in July), the 328d will be offered in both sedan and wagon bodystyles with all options available on the gasoline models (including xDrive all-wheel-drive), with one exception -- no manual transmission. The take-rate was just deemed too small, and it would have presented the conundrum: Bring the super-wide-ratio Euro box that would blunt performance relative to the eight-speed automatic, or bring the performance-oriented ratios that might kill that 40-mpg number? To meet U.S. NOx emissions regulations, the engine uses a selective-catalytic-reduction (urea) fluid. The onboard tank is not expected to require refilling between oil-change intervals (typically 6000-10,000 miles), unless it's being operated a lot in very cold weather or at higher altitudes. On the eve of the New York auto show, BMW offered brief test drives around its New Jersey headquarters, which revealed the new engine's more earnest earth-hugging mission. This 328d sedan seems to strike a better balance between performance and fuel economy, and as such it comes off as better optimized for drivers inclined toward obsessively Tweeting their fuel economy. Nevertheless, floor the throttle in Sport+ mode and it surfs the waves of 280-lb-ft torque, merging smartly with freeway traffic or easily jumping ahead of a line of dawdlers for the right-hand-turn lane when necessary. Yet, it feels more at home in the EcoPro transmission setting. Leave it there, and you'll never feel either edge of the torque plateau as the car wafts from ratio to ratio seamlessly. The four-cylinder's firing pulses are enough farther apart than the six's that it sounds a bit more diesel-y too, but never objectionably so. Pricing has not been finalized yet, but we're told to expect it to fall between that of the 328i and 335i, probably closer to the former (unlike the highway economy, here they're targeting sub-40). The 335d only accounted for about 8-10 percent of 3 Series sales in its day, but given the greater affordability, expanded model availability, and the addition of xDrive, expect the 328d's sales mix to approach that of the X5 diesel, which currently accounts for 20 percent of sales. Will we love it a third less than we did its six-cylinder ancestor? Doubtful, but there's only one way to find out: Deliver one 328d xDrive wagon to Motor Trend headquarters for 12 months. Sampling BMW's Turbo Three-Banger BMW reckons it's just about devised the ideal cylinder: bore of about 84-85mm and stroke in the 88-90mm range for a displacement of about 500cc, Valvetronic variable timing and lift, direct fuel injection, and a turbocharger. Making the cylinders any smaller makes friction and the parts count become unattractive; making them larger makes the noise and vibration of the rotating mass become unpleasant. Each such idealized cylinder can produce roughly 40-75 hp/45-60 lb-ft on gasoline and 25-60 hp/55-80 lb-ft burning diesel. How big is your car and how fast do you want to go? Depending on your answer, you'll soon be able to string together three, four, or six of these ideal cylinders. Yes, starting next year, BMW will saw its venerable 3.0-liter I-6 turbo in half and sell both ends in its smallest home-market 1 Series cars and the plug-in hybrid i8 model on our shores, with new Mini and front-drive BMW 1 Series models getting it later on. The claimed fuel economy benefit: 5-15 percent relative to an I-4 turbo sized and tuned for equivalent output. This high degree of modularity greatly improves manufacturing flexibility, parts, and machining commonality -- and even overall quality (gas and diesel versions can share a block and many other internal parts). An I-3's exhaust pulses are far enough apart that a less-costly single-scroll turbo can deliver the same load responsiveness as an I-4's twin-scroll. (If you were wondering, Continental makes the I-3's turbo; it produces just over 20 psi peak boost in the version we're sampling.) On the downside, an even-firing I-3 does not enjoy an I-6's inherent balance. There is a natural front-to-back vertical rocking couple that BMW counteracts with a single balance shaft spinning at twice crankshaft speed, located below the block. A small sideways rocking couple induced by the balance shaft will remain, but it's not deemed noticeable enough to warrant the cost and parasitic loss of a second counter-rotating shaft. This new family of gas and diesel I-3s will come in a range of available outputs. BMW invited us to drive an early development prototype of one of the higher-performing gasoline versions, which is good for 177 hp and 200 lb-ft and was installed in a Euro-market 1 Series hatchback. The engineers still have a lot of work to do on the noise/vibration/harshness front. Upon start-up, it sounds a bit like a diesel, with clatter and injector noise clearly evident. BMW claims that the predominant sound frequencies produced by the I-3 throughout the rpm range overlap the I-6's, registering higher than the four's. Okay, if they say so, but the bangs are enough farther apart that it will never confuse anyone for being a six. That said, the raspy rap was decidedly sporty, except for a sour moaning note around 2000 rpm -- especially when upshifting at a speed that sends the engine back down through that speed when operating in the EcoPro mode. Sport or Sport+ speed up the shifts and elevate the shift points enough to eliminate that effect (which will surely be addressed prior to production). Beyond that, the car accelerated like any other eight-speed automatic BMW carrying about 15 lb/hp -- probably in the low 6s to 60 mph. The ultra-sporting i8 plug-in hybrid halo car arriving here next year will get a special 220-hp version of the engine, using a larger turbocharger optimized for high-end power at the expense of low-end torque, which will be supplied by the electric motor assisting the three-cylinder. Expect WAY better performance from that car, than from a 1 Series with no E-assist. [More BMW 3 cylinder engine details] |
03-30-2013, 05:15 PM | #3 |
Rep 2,218
^ so they can price it between the 328i and 335i... Most buyers have no idea what happens under the hood, the 328i is just a 2.0, and the 335 is just a 3.0, the 640i and 740i are 3.0's... I'm sure this is just going to get more confusing in the future, just be sure to be an informed buyer...
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
03-30-2013, 05:53 PM | #6 | |
Rep 1,482
320d is no slouch but I say just be honest with people. If I put a 328d badge on my car in the UK I'd be mocked more than if I put an ///M in front of it. |
03-30-2013, 07:04 PM | #7 |
Rep 6,673
03-30-2013, 07:36 PM | #8 |
Rep 349
03-30-2013, 07:38 PM | #9 |
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Cool info about the 3-cylinder motor
03-30-2013, 08:36 PM | #11 |
mhmmmm
136
Rep 633
03-30-2013, 09:35 PM | #12 | |
Rep 3,619
Although the 328i is a 4banger but it carries on the legend set by the e90 328i. I had the e90 328i while my X5 was in service a d after years of being in denial, I finally accepted that the 328 although slower than my G37 was more fun to drive. If the 4 banger is better than the e90 then it deserves the name.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
03-30-2013, 09:42 PM | #13 |
Rep 2,168
I just don't get it, I think this is all a cynical move by BMW in the USA. The 320d sells at a slight premium to the 320i in Australia and way below the price of a 328i. I hope they load it with fruit to compensate.
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
03-30-2013, 09:44 PM | #14 |
Rep 2,197
thats weird, our 320d is a good few grand cheaper than the 328i, they should have at least put dual exhaust pipes to call it a 328d..
you guys arent getting any sympathy from me though, your cars are still half the price of ours..
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
03-30-2013, 10:04 PM | #15 |
Rep 139
So they can pump the price and make more profit. I was waiting for the real 328d, but since they are doing this BS, I wont buy this 320d.
09 E92 M3
2011 Ducati 848 |
03-30-2013, 11:19 PM | #16 |
Rep 2,168
03-30-2013, 11:58 PM | #17 |
Rep 3,418
Taking European 320d and spec'ing it with the same options as EU 328i, then adding BluePerformance (urea tank required to make US emissions) gets the price of 320d _above_ 328i.
03-31-2013, 02:16 AM | #18 | |
Special Agent
74
Rep 1,731
It is clearly a pricing structure move- early indication was that they would call it the 323d and like the 320i remove some content but the focus groups and marketing folks obviously nixed that and the 328d was hatched. I don't agree with it but will say that I love my 120d with the same engine.
[SIGPIC][/SIGPIC]
03-31-2013, 05:21 AM | #20 | |
Rep 1,482
My difficulty is with the huge difference in the arbitrary number simply because it is on a different continent. The 328i is not comparable to the 320d, it's much more akin in BHP to the 330i which it too will beat on any thing under 100mph. The 330i beats the 320d hands down on power, performance and not sounding like a tractor. I cannot see any justification for calling it a 328d other than basically telling people in the US that they couldn't handle the reality of a 2 litre diesel that was pretty efficient but quick enough for most people. I'm insulted for you really. |
03-31-2013, 11:03 AM | #21 | |
Commander
Rep 210
Stay Ahead!
E46(00-03) - E46 Touring (03-06) - E90(06-10) |
03-31-2013, 12:14 PM | #22 | |||
Rep 141
