BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Remus Axle-back Quad Tip Exhaust for F30 335i
European Auto Source
      04-18-2013, 03:10 PM   #1
AWF30MSPORT
AWF30MSPORT's Avatar
Drives: '15 Porsche 981 Cayman GTS
I did a couple searches and came up with no feedback on the F30 335 Remus exhaust here or on YouTube; has anyone seen or heard anything about it? I'm relatively pleased with my M Performance exhaust, but sometimes I wish for a slightly louder exhaust note (although, now that the weather has warmed up and I've been driving with my windows down more often, the sound is quite a bit better now after 8,xxx miles than when it was first installed in the fall). The Remus Quad Race Exhaust on the E9x N55 sounds pretty good, maybe a bit on the loud side, I'm just curious how the new one for the F30 sounds. Since the F30 Remus is also axle-back, like the M Perf, I wonder if it requires the current exhaust pipe to be cut in the same place as the M Performance...I would hate to order it and find that I need to weld in a new small section of tubing in order to install it since I already have an M Perf exhaust. Anyway, I probably won't make the switch, just curious, and a bit surprised no one has installed it yet.
      04-18-2013, 03:23 PM   #2
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
Have you thought about installing a downpipe? You could gain a bit more of an aggressive sound as well as some performance. Although you would probably get a CEL unless you got the stage 2 from BMS but it is definitely worth it.
      04-20-2013, 02:35 PM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
who sells this?
SOLD: 2012 335i Mineral Gray
      04-20-2013, 03:07 PM   #4
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
2924
Drives: M2
Look for videos of AC Schnitzer if you can find that instead, they are made by Remus.
      04-20-2013, 09:19 PM   #5
AWF30MSPORT
Originally Posted by shivaswrath View Post
who sells this?
M 0 d b a r g a 1 n s (always gets censored if I type it correctly). I'm sure others sell it too, but I haven't looked.
      04-24-2013, 02:42 PM   #6
richb811
richb811's Avatar
311
Drives: 2011 E92 JZB M3, 2000 750iL
who sells this?
We are an Authorized North American dealer for REMUS.
As far as the sound goes, there aren't really a lot of videos out there right now for the 335i Remus system for the F30, but the sound is very similar in tone and volume to the E92 N55 Remus Race system.
Installed on a 328i
http://www.f30post.com/forums/showth...ighlight=remus
      04-24-2013, 02:43 PM   #7
shivaswrath
Drives: 2012 335i
you sell this for the F30 335i currently?
      04-24-2013, 02:44 PM   #8
richb811
richb811's Avatar
311
you sell this for the F30 currently?
Yes sir. We have them in stock.
      04-24-2013, 02:46 PM   #9
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
2924
Drives: M2
The AC Schnitzer (Remus) exhaust I had on my E92 had a lot of drone.
The sound was really nice apart from that though.
      04-24-2013, 02:48 PM   #10
shivaswrath
Drives: 2012 335i
I only see it for the 328i not the F30 335i....
      04-24-2013, 02:50 PM   #11
richb811
richb811's Avatar
311
Try this link : Remus Sportexhaust : BMW 335i (F30
      04-24-2013, 02:53 PM   #12
shivaswrath
Drives: 2012 335i
thx!
So I take it I need a new diffuser to fit these, or will they fit the stock cut out?
      04-24-2013, 03:02 PM   #13
Roki_014
Drives: 2014 335i
looks better than it sounds
      04-24-2013, 03:07 PM   #14
richb811
richb811's Avatar
311
thx!
You'll need to trim the stock rear bumper slightly for the quads to fit, yes. It's not an overly difficult task and most install shops will be comfortable doing it.
      04-24-2013, 04:10 PM   #15
AWF30MSPORT
Any chance you have access to the installation instructions to see where the stock exhaust pipe needs to be cut? Just curious if it's the same place as the M Performance, which I believe was marked on the stock pipe by a small dimple.
Thanks.
      04-26-2013, 11:31 AM   #16
richb811
richb811's Avatar
311
Thanks.
Luke, working on it for you. I'll shoot you a pm
      04-26-2013, 12:19 PM   #17
AWF30MSPORT
Thanks!
