E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Off-Topic Discussions > OT - need excel help
Reply
      09-11-2007, 09:09 AM   #1
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
I'm pretty handy with excel stuff normally but I'm stumped on my latest request from the boss. Google hasn't helped either.
I have to count the number of cells by colour?
I've posted it up here
http://spreadsheets.google.com/ccc?k...j94XA&hl=en_GB
So for example on the first sheet (data) I need a total somewhere that counts how many yellow rows there are, how many grey etc etc.
HELP
      09-11-2007, 09:12 AM   #2
NPDAN
NPDAN's Avatar
95
Drives: AW DCT M3
2008 E92 M3  [8.00]
07' E92 335i  [0.00]
Cant you do an "If" statement formula?
      09-11-2007, 09:13 AM   #3
silverbmwz3
Drives: X5 g05
Is someone manually colouring the rows? Would be much easier to use conditional formatting and a code to indicate the failure level?
e.g. a scale of 1 to 7 and then use conditional formatting to format the whole row based on that value.
In the absence of that I think you'll be down to VBA to count the colours. I can have a go if you want? I'm not aware of any formula to detect colour.
Current: E90 335d (May 2007) | Black/Black | Prof Hifi | Prof Nav | 6FL | Fully Electric Seats | Xenons | Folding Mirrors | PDC
Previous: 325ci Conv. Black/Black with lots of ACS
Previous: z3 3.0 Silver with Black&Red Leather
      09-11-2007, 09:16 AM   #4
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Yes - the colour is done manually - I've had a quick play in VB with this UDF
Function SumByColour(CellColour As Range, SumRange As Range)
Dim cell As Range
Dim SumColour As Double
Dim MySum
Application.Volatile
'If CellColour.Cells > 1 Then Exit Function
SumColour = CellColour.Interior.ColorIndex
For Each cell In SumRange
If cell.Interior.ColorIndex = SumColour Then
MySum = MySum + cell.Offset(0, -2)
End If
Next cell
SumByColour = MySum
End Function
found here:-
http://www.mrexcel.com/archive2/7400/8232.htm
but couldn't get it to work
      09-11-2007, 09:20 AM   #5
silverbmwz3
Drives: X5 g05
OK, here's one, glad you know VBA!
Public Function mycount(oColourToLookFor As Range, oRangeToSearch As Range)
Dim oCell As Range
Dim iFound As Long
iFound = 0
For Each oCell In oRangeToSearch
If oCell.Interior.ColorIndex = oColourToLookFor.Interior.ColorIndex Then
iFound = iFound + 1
End If
Next
mycount = iFound
End Function
Basically you point it at the colour you want to look for (i'd put this say next to your key and point it at each one -ie repeat the call for each one, and point it at the range you want to search (i.e. a single column of those resuls)
      09-11-2007, 09:23 AM   #6
silverbmwz3
Drives: X5 g05
Here's my example with formula showing:
      09-11-2007, 09:29 AM   #7
silverbmwz3
Drives: X5 g05
Of course, it means you have to keep the range size updated unless you somehow can call it with a named range...otherwise when you add a row the range won't include that row. Might be other ways if that proves a problem.
      09-11-2007, 09:34 AM   #8
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Silver - thanks very much - that works a treat!! I owe you a beer
      09-11-2007, 09:36 AM   #9
silverbmwz3
Drives: X5 g05
NP. Glad to help, anytime.
      09-12-2007, 01:01 PM   #10
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
More help needed - I'm rustier than I thought.
Ok - I've done this vb to select rows dependant on a string search then copy teh row to another sheet but I want to modify it to search for multiple strings and then copy those rows to the other sheet.
Sub yellowtoescalatedfaultsbyequipmenttype()
' messagebox
MsgBox "The magic will now start. The screen is going to flash repeatedly now!", vbInformation, "Health & Safety warning"
Dim LSearchRow As Integer
Dim LCopyToRow As Integer
On Error GoTo Err_Execute
'Start search in row 19
LSearchRow = 19
'Start copying data to row 54 in Sheet2 (row counter variable)
LCopyToRow = 54
While Len(Range("AW" & CStr(LSearchRow)).Value) > 0
'If value in column AW = "Critical Fault reported to ADST",
If Range("AW" & CStr(LSearchRow)).Value = "Critical Fault reported to ADST" Then
'Select row in Data to copy
Rows(CStr(LSearchRow) & ":" & CStr(LSearchRow)).Select
Selection.Copy
'Paste row into Escalated faults by Equip Type in next row
Sheets("Escalated faults by Equip Type").Select
Rows(CStr(LCopyToRow) & ":" & CStr(LCopyToRow)).Select
ActiveSheet.Paste
'Move counter to next row
LCopyToRow = LCopyToRow + 1
'Go back to Data to continue searching
Sheets("Data").Select
End If
LSearchRow = LSearchRow + 1
Wend
'Position on cell A1
Application.CutCopyMode = False
Range("A1").Select
Exit Sub
Err_Execute:
MsgBox "An error occurred - Please call 5404 8080 and ask for ***."
End Sub
      09-13-2007, 01:49 AM   #11
silverbmwz3
Drives: X5 g05
So when you look or the relevant string don't you just want to say Or.....then look for the other string(s) ?
I.E. Adding an Or statement where the string gets compared then another string comparison and repeat as many times as you need?
      09-13-2007, 04:27 AM   #12
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
i.e
If Range("AW" & CStr(LSearchRow)).Value = "Critical Fault reported to ADST"or"etcetc" Then
Pretty sure I tried that and it failed - not at work at the minute so can't check it again. Is that what you mean?
      09-13-2007, 04:29 AM   #13
silverbmwz3
Drives: X5 g05
If (Range("AW&Cstr(LSearchRow)).Value = "Critical Fault reported to ADST") Or (Range("AW&Cstr(LSearchRow)).Value = "1stnewcarlovesipodsandheknowsit")
you can't just repeat the string bit as each bit after a logic operator (OR, AND etc.) will be evaluated on its own merit. So you were asking the question:
"etcetc" ?
which doesn't stand on its own. The computer is thinking "yeah...what about it".
      09-13-2007, 04:39 AM   #14
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Mmmmm - I'll try that later - minus the ipods bit
      09-13-2007, 08:22 AM   #15
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Get a compile error:-
Expected:list separator or )
I tried moving the brackets around but no different.
      09-13-2007, 08:26 AM   #16
silverbmwz3
Drives: X5 g05
If your code above worked then this should (may be positionging number/brackets in my example above):
If (Range("AW" & CStr(LSearchRow)).Value = "Critical Fault reported to ADST") Or (Range("AW" & CStr(LSearchRow)).Value = "some other text") Then
looks fine to me?
      09-13-2007, 08:32 AM   #17
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Yet again - I owe you another beer! I hope you never come to a meet
      09-13-2007, 08:41 AM   #18
silverbmwz3
Drives: X5 g05
Thanks very much! NP, anytime.
Reply
e90post
