BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires > F30 M Sport, 403 19in, Larger Tire size question
Steve Thomas BMW
      04-24-2013, 04:55 AM   #1
Harveyd396
Drives: 2013 335i M Sport, MT, EBII
I have a 2013 F30 335i Msport, EBII, 6 spd man, #403 19in mags, factory stock Run Flat Bridgestone Potenza, front 225/40-19, rear 255/35-19.
My thinking is when they are warn to go with the Michelin Super Sports, NON run flats. I would like to bump up the width of the tires, not sure if I should do front and rears or just the rears. I was thinking of maybe going with either 265/35 or 265/30 in the rear, not sure if they fit on the stock 403 rims. Is it possible to go as large as 275/30? or bigger? Would be nice, look like a M3.
Would appreciate your ideas. Thanks
Harveyd396 is offline   United_States
      04-24-2013, 02:49 PM   #2
scott@bmwhn
Drives: Msport 328i
you could but it may give the tire a bulging appearance since the tire is wider and the wheel width is unchanged.
13' Msport 328i _Mperformance - Modulare - H&R_
Previous: 09' Msport 335i, 07' Msport 335i
scott@bmwhn is offline
      04-29-2013, 09:47 AM   #3
estragos
TUGA
estragos's Avatar
Drives: F30 320d M Sport
check this table, the 403M rims are 8.5 so the maximum is allready the 255!!
for 275 tires, you need to have minimum 9.5 rims...
http://www.tyres-pneus-online.co.uk/...es-advice.html
estragos is offline
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
