BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > M-Sport Rear Reflector DIY?
European Auto Source
      04-28-2013, 01:44 PM   #1
fricfracfrank
Drives: 2011 328i xdrive
IND M-Sport Rear Reflector DIY?
I see all the information and DIY instructions for replacing the front reflectors but after searching for a while I can't find a detailed guide to replacing the rear reflectors especially with m-sport bumper.
Any help is greatly appreciated!
Past: 2011 328i xdrive Black Sapphire Metallic - Nav, Premium pkg, Cold Weather pkg, Saddle Brown interior
Present: 2013 Estoril Blue 335i xdrive ///M sport - Cold Weather pkg, Premium pkg, Tech pkg, paddle shifters, HK, black interior
      04-29-2013, 04:01 PM   #2
fricfracfrank
Anyone? IND where are you with some help
      05-02-2013, 07:57 AM   #3
spindiesel
Drives: 2013 328i msport
I took my rear fascia and reflectors off and plasticoated them black. Super easy.
      05-02-2013, 08:02 AM   #4
R12ax7
R12ax7's Avatar
63
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Pics?
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      05-02-2013, 11:24 AM   #5
fricfracfrank
Yea where are the pics...or at least description haha
      05-02-2013, 12:52 PM   #6
n55x3
Drives: n55 BMWs
They take 2 minutes to remove. If you are looking at the back of the car there are 3 clips on each reflector. For the first reflector removal I'd lay on your back under the rear of the vehicle (once you do it once you can remove them without crawling under). Press in the clip that is closet to the middle of the car and push outward lightly. This will undue the inside clip, then for the middle clip you have to press down and push lightly. The third clip (the one towards the outside of the car) isn't so much a clip as it is more of a hook to hold the reflector in. When the inside and middle clips have been depressed you can just push on the reflector and it will pop out.
I just pulled mine out a couple days ago to tint them. Did a mock up by putting some clear tape on them and cut that to shape. Then sprayed VHT niteshade to tint them relatively dark. After I reinstalled them I decided it was a little odd looking on my MSport so I simply pulled the now tinted clear tape off and reinstalled the reflectors. I may decide to paint them the same color as the diffuser at a later date.
      05-02-2013, 02:50 PM   #7
fricfracfrank
THANK YOU! I just didnt want to start ripping them off and ruin anything.
      05-04-2013, 07:33 PM   #8
f80
f80's Avatar
1307
Drives: ∞ Improbability Drive
Did you mean "plastidip"?
///f80 YMB/SS 6MT ZCP | f80 | f30 |e92 | tt | S5 | e92 | 350z | e90 |
