BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > NEW: Rotating Tires with a Staggered Setup?
      07-31-2013, 05:50 PM   #1
antidentite
Drives: 2007 e92, 6mt
I was watching MotorTrend TV last night, and they were showing a new tire from a 6 series that was bi-directional, so you could rotate them from one side to the other. They said an additional advantage from rotating your tires - on top of the longer life - is that it limited the increase in road noise as the tire wears.
I'm considering order a new F30 with a squared, instead of staggered setup mainly due to the additional cost (and noise) associated with not being able to rotate my tires.
But if rotating tires may be possible on a staggered setup, I may consider staying with this setup. I know that special tires would need to be purchased just for this reason, so does anyone know how wide-spread these types of tires are?
Retired: '00 e46 (5mt)
Current: '07 e92 (6mt)
Next: F10 or F30?
      07-31-2013, 05:56 PM   #2
mikew2069
mikew2069's Avatar
61
Drives: F30 335i MSport
I have Mich Pilot Super Sport staggered setup and I just flip flopped my wheels/tires this weekend
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      07-31-2013, 05:56 PM   #3
Vectors2final
Vectors2final's Avatar
Drives: 2018 F80 YMB/SS ZCP
Michelin PSS are non-directional, so that may help you.
Delivered: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M
SOLD: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M
V2F's Yas Journal
      07-31-2013, 06:12 PM   #4
dinonz
Drives: 2016 M3 MWM ZCP
If they're not asymmetric, get them "popped inside out". Otherwise, with any sort of negative camber, you're still wearing the same inside edge of your tyres.
      07-31-2013, 06:43 PM   #5
mikew2069
mikew2069's Avatar
61
Yea I guess you could although it would be a huge pita
      07-31-2013, 07:18 PM   #6
dinonz
Yeah - it is, but if your tyres are wearing the inside edge more, it will extend the life of the tyres by a fair bit.
      07-31-2013, 10:38 PM   #7
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
I have different front and rears 19" from the Factory with 403M rims. This was one of my first questions when I took delivery. I pointed out years ago when I rotated tires to opposite sides the belt always broke slightly after the shift.
I was told that was the case years ago (and given some reason why that I honestly do not remember now) but assured that the modern tires of today do not have that problem.
But again, I was assured I had ACC at the same time, which I have since figured out I really do not.
      08-02-2013, 11:56 PM   #8
RPM90
Drives: 340i M-sport AT
As long as the tires are non directional you can swap left to right on a staggered set up.
This DOES help with tire tread noise as it helps even out the consistent tire wear that develops and can lead to higher tread noise.
Flipping the tires also helps extend the useful life of the tire.
It's not as much as non staggered tires as you can fully rotate that type.
I had a great experience with my 135i's staggered setup.
The tries did develop a wear pattern tread noise a bit over half their life span, so I flipped them left to right and the noise decreased greatly.
Performance remained great and the tires wore evenly across the tread.
They were non directional Conti DWS. The DWS do have a tread that looks directional but TireRack said they will work just fine flipped and they did.
I have the DWS on my 335i Msport staggered setup.
      08-03-2013, 12:09 AM   #9
rxander
rxander's Avatar
Drives: F30 Alpine White
Same tires here..how often mileage wise should I flip the Michelin PSS?
      08-03-2013, 08:56 AM   #10
mikew2069
mikew2069's Avatar
61
I flipped mine at 6k ish
      08-03-2013, 08:58 AM   #11
mikew2069
mikew2069's Avatar
61
How do you like the dws? Performance wise? How many miles did you get out of them on your 135?
I'm thinking about trying them when my PSS wear out. Seems like one of the only affordable tires I can find in 285/30/19
