08-07-2013, 12:50 PM | #1 |
Rep 47
Fitment and Offset Question
Hi All,
Im looking to purchase a set of wheels from a forum member and wanted to know if these will fit on my F30. I have the M-Performance BBK and want to drop on H&R Sport Springs. 19x8.5 +35 fronts and 19x10 +38 rears. Tires are 235/35 front and 275/30 rears. Any rubbing issues or fender poking i need to worry about? Thanks! |
08-08-2013, 06:26 AM | #3 |
Rep 202
Depends on the rims, but you will definitely have wheel poke on the rear. 19x10 ET 38 with 275s is too aggressive, and will stick out.
I have ZCP reps at 19x9.5 ET 38 with 265s. They are ever so slightly past flush, and would be considered too aggressive by many people. My 1/50th of a dollar. Matt |
08-08-2013, 08:11 AM | #4 |
Rep 475
10" ET38 with 275mm for the rears is aggressive.
But, some guys do it. You could runs a couple of degrees of camber, but I don't know anything about that.
EB 335i M-Sport / Euro Delivery / M-Performance Brakes / M-Performance Exhaust / Adaptive M Suspension / 19" M5 Reps / Michelin Pilot Super Sports
My European Delivery Thread http://www.f30post.com/forums/showthread.php?t=807429 |
08-08-2013, 09:34 AM | #5 |
Rep 1,801
You should be fine upfront, but definitely very aggressive in the rear as mentioned from fellow members. I test fitted 19x10 +38 with michelin pss 265/30/19 and it was past the fenders. If you can find a reputable shop with a CNC that knows what they're doing, you can shave off 4-5mm from the hub to make the offset +42/+43.
08-10-2013, 12:38 AM | #7 | |
Rep 1,591
However I'm in the same dilemma, except I have the option of full custom sizing so I want to be right on point. I have decided on 19x9 +29 front and rears 19x10 probably between +38 and +42ish but I do want to run at least 265s. I may just run +40 as I see a lot of guys running 20x10 +40 without issue from what I've seen.
-JustinNApproved
