BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Sport mode?
Extreme Power House
      09-02-2013, 07:19 AM   #1
Afy360
Scotland
Drives: F30 335d, F10 M5
Sport mode?
As I patiently wait for my 335d I thought I would ask you guys a question.
In my previous E92 330i when I hit the auto transmission to the left it would go into sport mode.
Is this the same in the F30 as it has a separate button for comfort, sport and sport +.
And if yes, what what do they do differently from one and other.
Hope that makes sense.
      09-02-2013, 07:50 AM   #2
Alkidrew
Alkidrew's Avatar
Drives: F31 325d M Sport GS
this was quite a good thread on it
http://www.f30post.com/forums/showth...light=sport%2B
      09-02-2013, 07:50 AM   #3
TripleD
Drives: Women crazy with desire
Same in the F30 Auto transmission, hit it across to the left and it puts it in Sport, which also shots the auto stop/start from doing it's thing!
The Sport, Sport+, comfort etc button adjusts the steering weight, throttle sensitivity etc
I have found that putting it into Sport and putting the auto into sport there's a noticeable jolt when going up the gears, rather than being smooth!
Treat every problem as your dog would; if you can't eat it or f**k it, pee on it and walk away!
      09-02-2013, 07:58 AM   #4
SomeRandomer123
SomeRandomer123's Avatar
England
232
Drives: F30 328i Luxury - Sport Auto
When you shift the lever to the left in the F30, the sport mode of the transmission is engaged. This has the car rev higher before upshifting and downshifts are also at a higher rpm than normal, hence sport. The changes are also sharpened up and the display that would normally show "D" will now show "S" plus the gear you're in, i.e. "S3". The transmission is still in automatic mode until you either shift sequentially on the lever or use the flappy paddles. This will change the display to "M" plus the gear you're in, i.e. "M3". The car is now in full manual mode and will not revert back to D (automatic) like it would if the lever was not pushed to the left. However, the car will downshift itself if the revs fall far too low and in Comfort, will upshift itself at the redline.
Going into Sport or Sport + mode means the car will not upshift itself and will just let you bounce off the rev-limiter. Sport mode will weight up the steering for more feel, sharpen the throttle response and if you have Adaptive M Suspension, stiffen up the dampers. Also, if the transmission is in position D (not to the left), the car will hold on to lower gears for longer, upshift at higher rpm and downshift at higher rpm, just like if you push the lever to the left. However, the effect is not as profound as moving the lever to the left (DS or M/S), so it may only drop 1 gear whereas moving to the left may see it drop 2 gears and upshift/downshift at even higher rpm. Also, Sport mode does not directly effect the sharpness or speed of the gear change, so you will need to push the lever left for the sharp changes.
That said, the transmission will adapt to your driving style and shift accordingly to some extent, even in Comfort.
Sport + just activates Dynamic Traction Control, which optimises forward momentum with restricted stability. In other words, it backs off the traction and stability control a little so you can hoon a little without killing yourself.
Sounds complicated, but you'll pick it up quick!!
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      09-02-2013, 08:01 AM   #5
SomeRandomer123
England
232
Yes, pressing on in Sport mode with the transmission in D is not ideal for smoothness or sport, as you can imagine! The changes are still, essentially, in Comfort so it can feel like there is a delay. Shift the lever to the left and you'll get your quick smooth shifts to match Sport. Comfort and D works wonderfully and imperceptibly, which is why my 328i Sport Auto spends most of its time in that default configuration.
      09-02-2013, 08:03 AM   #6
Alkidrew
Alkidrew's Avatar
This is the best bit, awesome fun switching to sport and feeling the car hunker down...
      09-02-2013, 08:29 AM   #7
rich1068
has left the building
Drives: F30 330d M Sport
Answers to all the questions one may be too 'proud' to ask on a public forum
      09-02-2013, 08:40 AM   #8
SomeRandomer123
England
232
      09-02-2013, 10:25 AM   #9
TripleD
Nope the Transmission is in 'S' and then select Sport mode, when going up the gears there's a noticeable jerk (and not the one in the drivers seat) when changing up the gears.
      09-02-2013, 10:43 AM   #10
Afy360
Scotland
Thanks for that, now I just need to put it into practice....
In 3/4 months!!!!
      09-02-2013, 10:43 AM   #11
SomeRandomer123
England
232
Depends to what extent you press on.
I was on some winding roads yesterday so wasn't particularly pushing the engine or trans hard, and this allowed for imperceptible shifts in DS and Sport. However, launching from the M6 Toll Plaza in DS and Sport at full power, the transmission shifts so fast and hard (DCT like), there is a jerk.
But remember we have a difference in engines! The all rounder 20d, the free-revving yet strong 28i, the torque-monster N57's (30d & 35d).
Moreover, I didn't feel my transmission had fully broken in until 8000mls as the changes became more and more imperceptible from when I got it with 7mls on the clock. I now have 31000mls on the clock.
      09-02-2013, 10:45 AM   #12
SomeRandomer123
England
232
In 3/4 months!!!!
No problem!
      09-02-2013, 12:16 PM   #13
gatsojon
gatsojon's Avatar
Drives: M4 CP SSII/SS
2017 BMW M4 CP  [5.00]
How well put sir!
Current: F82 CP SS/SS
      09-03-2013, 03:49 AM   #14
rich1068
I have to admit I didn't know this. I obviously knew the lever knocked to the left and that the rocker switch altered the gear change in Sport/Sport+ but I'd never actually tried a combination of the two. Though I have since reading this
To be honest I don't often mess with the flappy paddles (trying to second guess this gearbox??) and tend to stick with auto. When I do have a run on my favourite road and change the drive settings it appears I was just using Sport Lite.
And no, I never read the handbook.
      09-03-2013, 05:31 AM   #15
SimonB
135 to 335 M Sport to X3 30d M Sport
Australia
93
Drives: 2018 X3 30d, optioned up!
I am SO looking forward to my 335 M pack with adaptive suspension! Thanks for this excellent write up and excuse me haunting the UK forum :-)
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
      09-03-2013, 06:42 AM   #16
SomeRandomer123
England
232
Ha, yeah, from a transmission point of view you could see the Sport button as a Sport Lite setting! Then hit it to the left for the full sport program.
      09-03-2013, 06:43 AM   #17
SomeRandomer123
England
232
No problem, you haunt away!
      09-03-2013, 07:07 AM   #18
rich1068
I've confessed all to my E46 M3 owning friend. He called me a gaylord.
      09-03-2013, 06:50 PM   #19
ZigmundUK
Drives: G30 530d MSport x-drive
Actually there's an option in te menu system to choose exactly what sport mode gives you. I suspect most have it set to chassis only or chassis + steering. This gives the behaviour described - ie switching to sport mode doesn't change the transmission. Then flicking the gear lever left gives you sport transmission.
Btw floppies are better to make sure the car doesn't second guess you wrong on windy roads. Also allows you to get to 8th if in sport transmission...
      09-03-2013, 08:00 PM   #20
SomeRandomer123
England
232
The car will eventually upshift to 8th in Sport mode, you just need to be going quicker! ~100mph I believe...
