BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 18" Winter F30 ET37
      10-17-2013, 12:12 PM   #1
sroghen
Drives: 320i
18" Winter F30 ET37
25/40/18 18x8.5 x120 +37 offset
Someone plz confirm whether the above is a good fitment all around for 2013 F30 320i x-drive?
Let know asap as Im about to pull the trigger
Thanks
      10-17-2013, 01:00 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
13mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 13mm
new wheels - 3% too small in overall diameter and speedo will be 3km/hr lower than it really is.
This I would consider to be in the border line area, namely, the lesser front strut clearance. Therefore, if you can do a test fit before buying, then it's better.
      10-17-2013, 02:02 PM   #3
sroghen
Drives: 320i
Detailed info much appreciated.
Thanks
      10-17-2013, 02:32 PM   #4
.BMW.
.BMW.'s Avatar
Sweden
1117
Drives: BMW F31
Not sure if you mean 225/40-18 or 255/40-18?
255/40-18 is OEM size for F30, 225/40-18 will be 3% short.
Originally Posted by bobblehead View Post
13mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 13mm.
I don't agree.
8.5x18" ET37 will have 9mm less inner clearance and extend 3mm on the outside compared to OEM 8x18" ET34.
If compared with staggered 18" M Sport, the rear will looks like a 10mm spacer on M Sport 400 wheels.
      10-17-2013, 03:15 PM   #5
bobblehead
bobblehead's Avatar
Drives: warp speed
the guy has a 320xdrive. he is going +1 . it comes in 17*7.5 et37 stock.
      10-17-2013, 03:40 PM   #6
.BMW.
.BMW.'s Avatar
Sweden
1117
Drives: BMW F31
Sorry, my bad!
My calculations was based on OEM 18" wheels.
      10-18-2013, 12:16 AM   #7
sroghen
Drives: 320i
sorry i meant: 225/40/18
stock on my 320xdrive car came with 225/45/18
      10-18-2013, 01:40 AM   #8
.BMW.
.BMW.'s Avatar
Sweden
1117
Drives: BMW F31
Then my calculations are correct after all!
I still don't think 225/40-18 is an optimal choice, they are 3% shorter than OEM and will look a bit stretched on 8.5" wide wheels.
However wider tires can give problems with front strut clearance.
      10-18-2013, 08:20 AM   #9
sroghen
Drives: 320i
Damn, I checked with the seller the wheels are 18x8
Does it make a difference in the calculations above?
(Also, how do you guys come up with the numbers? Is there a chart out there that explains all this?)
      10-18-2013, 08:54 AM   #10
bobblehead
bobblehead's Avatar
Drives: warp speed
http://1010tires.com/Tools/Wheel-Offset-Calculator
http://1010tires.com/Tools/Tire-Size-Calculator
http://www.willtheyfit.com/
      10-18-2013, 10:00 AM   #11
sroghen
Drives: 320i
Thanks it is very useful.
Besides the speedometer issue, it looks like it may fit fine. Am I correct?
      10-18-2013, 11:05 AM   #12
.BMW.
.BMW.'s Avatar
Sweden
1117
Drives: BMW F31
Correct!
The wheels will be fine since you have confirmed that they are 8x18", the only difference compared to OEM is 3mm in offset. That will be hard to notice.
225mm wide tires will fit better on 8" wheels aswell!
There will be a speedometer error and the 40% tire profile (compared to OEM 45%) will increase wheel gap slightly.
      10-18-2013, 03:02 PM   #13
sroghen
Drives: 320i
Originally Posted by ss0803 View Post
Correct!
Great stuff.
For winter tires, is it anything to worry about the minus 5% tire profile in terms of stability and security. I dont want to compromise security because of child in the car.
Thanks
      10-18-2013, 04:41 PM   #14
.BMW.
.BMW.'s Avatar
Sweden
1117
Drives: BMW F31
Generally I would say that higher sidewall is better for a winter tire!
But the difference isn't that large:
225/40-18, sidewall hight 90mm
225/45-18, sidewall hight 101mm
You find some good infomation about winter tires here: tirerack.com
