BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > new tires
      10-23-2013, 02:20 AM   #1
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
new tires
I have 19' 403M with Bridgestone potenza S001 factory tires(rft)
225/40/19 Front
255/35/19 Rear
i wanna get rid of them and get Michelin PSS , i have been searching for my sizes but couldn't find a front set idk if i can fit a little wider one (235/40/19)
any ideas?
Docrace 6266
      10-23-2013, 03:02 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
You have at least two options for the front tire:
235/40-19 (1% taller than OEM)
245/35-19 (1% shorter than OEM)
Since the M403 wheels are 8" wide front and 8.5" rear a difference of 13mm I would have choosen 245/35-19 for the front.
F: 245/35-19, section width 248mm
R: 255/35-19, section width 260mm
The tire widht differs by 12 mm which will make the tires fit similar on the front and rear wheel!
      10-23-2013, 02:28 PM   #3
smv
Drives: F48 X1 25D Xdrive
225/40/19 Front
255/35/19 Rear
any ideas?
Is it because you dont find them in ur shop, coz from what I can see they exist:
http://www.tirerack.com/tires/TireSe...=57430&tab=All
Btw, any reason why you want to change them? I have the exact same S001 tyres in the same dimensions etc... and i find them excellent! So why the change? Just out of curiosity...
      10-23-2013, 05:31 PM   #4
M-terkait
M-terkait's Avatar
Kuwait
209
my wheels spinns while accelerating through 3rd gear at 50mph -.- i need more grip before i even add jb4/dps
Docrace 6266
      10-27-2013, 12:41 PM   #5
M-terkait
M-terkait's Avatar
Kuwait
209
any1 replaced factory RFT Bridgestone Potenza S0001 with their 19's
with new decent summer performance tires and what have you felt after replacing?
i can't feel the edge of slipping with my car , sometimes i lose control without meaning to
not sure if i should replace the tires soon or do some more miles on them.
Docrace 6266
      10-27-2013, 03:17 PM   #6
m2michael23
Drives: G82 M4 Competition
i feel you man, that was the first thing i did to my car - new wheels and new tires/ PSS.
      10-27-2013, 06:29 PM   #7
Nitrous Garage
Nitrous Garage's Avatar
Drives: E82 135i / E92 328i / E60 550i
That is one of the first things I changed on my 135i too. The bridgestones are great but no other street tire hooks up like the PSS. If your planning on tuning and adding bolt ons then they are a must.
If you decide to change them out just pm me and I would be happy to work you up a fast quote.
      10-28-2013, 04:04 AM   #8
M-terkait
M-terkait's Avatar
Kuwait
209
You noticed that am not from the US ;(?
Docrace 6266
      10-28-2013, 10:25 AM   #9
Nitrous Garage
I just did
      12-12-2013, 05:39 PM   #10
M-terkait
M-terkait's Avatar
Kuwait
209
I have found Toyo Proxes T1 Sport & Nitto Invo for my rims on OEM sizes
toyo is cheaper than the nittos but not sure which are better in performance or even comfort as a DD & spirited driving .. anyone experienced in these tires?
Docrace 6266
      12-12-2013, 09:07 PM   #11
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Might want to try adding an LSD...
