BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Winter Tires for 441M Wheels
      10-23-2013, 06:44 PM   #1
Kyokio
Drives: 2016 S5
Can I run a square setup for the 441 M wheels?
18" M Double-spoke style 441 M
8JX18 ET:34
8.5JX18 ET:47
TireRack recommends 225-45-18 but then offers an alternative of 225-45-18 for the front and 245-45-18 for the rear.
      10-24-2013, 08:20 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
i don't see why not
      10-24-2013, 09:44 AM   #3
Kyokio
Drives: 2016 S5
Originally Posted by bobblehead View Post
i don't see why not
thx for the reply but i'm looking for a more definitive answer.
anyone using the 441M wheels as their winters? if so, what tire size did you guys go with?
      10-24-2013, 09:47 AM   #4
-AndyH-
Czech_Republic
17
Drives: F31 330d X-Drive M-Sport
Hi
I put Continental TS830P 225/45/R18 RFTs on my 400m (same size/offset as yours). There are only two approved BMW winter tyres in those sizes - the other being a Pirelli SottoZero II.
Pics are here: http://www.f30post.com/forums/showpo...&postcount=224 http://www.f30post.com/forums/showpo...&postcount=231
      10-24-2013, 09:53 AM   #5
Kyokio
Drives: 2016 S5
Originally Posted by -AndyH- View Post
Hi
thanks! i'm buying dunlop winter sp 4d tires.. they ride/perform better than rfts imo.
      10-24-2013, 10:08 AM   #6
.BMW.
.BMW.'s Avatar
Sweden
642
Drives: BMW F11
8JX18 ET:34
8.5JX18 ET:47
225/45-18 has 7.5" wide wheel as recommendation, but 7-8.5" are allowed.
225/45-18 looks a bit stretched on 8" wheels, will be even worse on 8.5".
Since you have X Drive, you should not choose 225/45 front and 245/45 rear, since it could cause damage to the all wheel drive system.
For a great look there are two options, either OEM staggered setup with 225/45-18 front and 255/40-18 rear or a square setup with a slightly wider tire, 235/45-18 or 245/40-18.
However wider tires will not give you the best performance if you drive in a lot of snow during the winter.
      10-24-2013, 12:55 PM   #7
Kyokio
Drives: 2016 S5
thanks alot! this was very helpful. decided to go with 235/45/18 square setup.
      10-25-2013, 02:00 PM   #8
remmib
remmib's Avatar
Norway
823
Drives: 2013 F10 520d M-Sport
Yes, no problem. Go with 225/45/18.
I had 225/45/17 winters on 17x8 and 17x8.5 on my e90, and now I have 245/40/19 on 19x8.5 and 19x9 for my F10.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      03-16-2015, 08:47 PM   #9
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Bump
Anyone know if these 441M can fit a square setup of 225/40/18 as I already have a set of this size tires
I want to use these winter tires and then get a new set for summer
Thanks
      03-17-2015, 01:53 PM   #10
bwagner
Drives: 2018 M3 MW ZCP
Alternate Square Setup
I have the same wheels, but went with 245/40-18 Michelin Alpin PA4. You will need 10-12mm spacers to run the rear wheels in front.
B
