BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Help with 19" wheel set up
European Auto Source
      10-24-2013, 09:24 PM   #1
b0unce. [?]
Drives: 2013 3series
Hey folks, noob to this forum and with my f30 still. Looking for some solid advice/help for my upcoming wheel and tire choices.
I'm looking to run a 19" squared set up. I've decided to go cheaper this round and be able to rotate tires to save some money.
My f30 328i xdrive is dropped on H&R sport springs currently. Without rubbing but having a flush fitment, what set up am I safe to run with?
Would 19x9.5 wheels work? What offset/spacers for front and rear? 245/40's squared would be fine?
Thanks in advance.
      10-25-2013, 02:09 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1171
Drives: BMW F31
245/40-19 will look stretched on 9.5" wheels, it has 8.5" wheels as recommendation (but 8-9.5" are allowed).
A square setup with 8.5x19" and 245/40-19 will be a great choice, if you like a bit tire stretch you might choose 9x19".
Offset is most critical for the front wheel, for 8.5" wide wheels ET32-35 will be a good fiment.
      10-25-2013, 05:32 AM   #3
reedo302
Estorilblau Member
reedo302's Avatar
Drives: Dinan Estoril 328i M Sport
With the right offset and tires, you can likely run a 255/35-19 up front without any issues. It might be a little bit safer to stick with a 245/40-19 though.
That being said, you're not going to fit a 9.5x19 up front, even with stretched tires. You will likely get some impact when turning, especially considering your drop.
Stretching tires, like with running a 245 on a 9.5" wheel, leaved your tires susceptible to more damage, and it reduces your handling. It also makes you look like the Euro stance crowd that loves to show how low their cars are and how much they can stretch a tire, as if it's a contest to see who can have the worst ride quality and handling possible.
      10-25-2013, 12:07 PM   #4
Nitrous Garage
Nitrous Garage's Avatar
Drives: E82 135i / E92 328i / E60 550i
I would suggest a 19x8.5 ET35 all around with a 5mm spacer in the rear and running a 245/35 tire. If you have any questions about wheel and tire fitment or possible wheel choices do not hesitate to ask me
      10-25-2013, 03:16 PM   #5
b0unce. [?]
Thanks for the help, I think i'll run with your suggestion.
Now... Wheel suggestions are welcome!
      10-25-2013, 03:27 PM   #6
Nitrous Garage
I'm here for that too
What kind of style/color wheel were you looking for?
Here are some samples to get you started
      10-25-2013, 03:54 PM   #7
b0unce. [?]
I'm definitely looking for something with a lip, 2 or 3" lip maybe.
te37, bbs lm, ccw classic, work meister/vs-xx. all reps of course.
i'm also interested in something like this:
      10-25-2013, 04:56 PM   #8
Nitrous Garage
I do have these MRR GT-1 Wheels available.
      10-25-2013, 08:17 PM   #9
b0unce. [?]
These are the correct fitment? Price?
      10-26-2013, 01:44 AM   #10
Nitrous Garage
They are available in a 19x8.5 but I am going to have to wait till Monday to get you pricing and make sure they come in the right offsets.
      10-26-2013, 07:35 AM   #11
Gastoys
Drives: 2013 BWM 335i M Sport sapphire
I don't under stand all the wide tires and wheels unless looks is the only desire because the rotation mass will greatly reduce braking and acceleration performance not to mention mpg.
Why not a set of forged aluminum light wheels say 8.5 front and 9 rears .
      10-26-2013, 11:29 AM   #12
Jackson743
Drives: 335i M-Sport/EBII/ED 12/5
Really?
Looks are important. A wider wheel doesn't necessarily equate to more or that much more weight. There is a wide range of wheels to chose from. The quality of the tire is clearly the most important factor. And, many things factor into whether you'll get more traction.
That said, you appear to be a bit of an absolutist. "Great reduce braking and acceleration performance . . . "?
Come on.
Try to envision dragging a wide piece of rubber on a surface, then a narrower one. That should help you out. The only thing you said that was sort of true was the reduced MPG. And, that decrease is a marginal decrease.
Finally, I bought heavier wider wheels with Michelin PSS and ditched the Conti RF's. The difference in just night and day in acceleration, braking and cornering. Talk about dialing out the understeer.
EB 335i M-Sport / Euro Delivery / M-Performance Brakes / M-Performance Exhaust / Adaptive M Suspension / 19" M5 Reps / Michelin Pilot Super Sports
My European Delivery Thread http://www.f30post.com/forums/showthread.php?t=807429
      10-28-2013, 03:17 PM   #13
b0unce. [?]
awesome, sounds good! awaiting your response
