Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Aggressive fitment, will it work ? Vorsteiner V-FF101
      10-26-2013, 12:27 AM   #1
fil3
Drives: F30
2013 BMW 335i  [0.00]
Exclamation Aggressive fitment, will it work ? Vorsteiner V-FF101
I am looking to get concave style wheels. 1st choice is Vorsteiner V-FF 101
anyone know will 2013 335i xDrive will fit front: 10x19 rear: 11x19 ???
thinking is too aggressive. but i saw alot of F21 or F10 fit 8.5x19 10x19
they look flat face not concave.
can anyone show me a pic of 10x19 and 11x19 on those rims?
      10-26-2013, 04:03 AM   #2
AMJAM
AMJAM's Avatar
Australia
17
Drives: 2013 Alpine 328I MSport
I am not sure if anyone has gone 10" wide on the front I think 9" is the limit. The 11" wide rear has been done. What is important is the offsets. What are they?
2013 Alpine White 328I M Sport ARRIVED
      10-26-2013, 04:16 AM   #3
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
2023
Drives: M2
Just because you fit a wider wheel it won't get more concave by default. It depends on the offset in relation to the wheel width. Even on custom wheels like HRE and ADV.1 it is really hard to get them concave without going to very aggressive offsets.
      10-28-2013, 06:02 PM   #4
richb811
richb811's Avatar
355
Drives: 2011 E92 JZB M3, 2000 750iL
Fitting an 19x11" back there is going to be a chore. Most cases a 19x9.5" is usually the better option.
You ain't fitting a 19x10 up front unless you can fabricate yourself new fenders.
      10-29-2013, 11:42 PM   #5
fil3
Drives: F30
so front must be 8.5x19 and rear go for 10x19
any good looking must be concave style rim recommending?
      10-30-2013, 12:08 AM   #6
Camnyc
wannabe
33
Drives: 2016 M3
19x10 is doable up front, high et though unless you want to stretch a tire.
19x11 will be a lil touch out back, tire stretch, camber and some massaging of the quarters
      10-31-2013, 06:12 PM   #7
richb811
richb811's Avatar
355
You are underselling the amount of work he is going to need to do to make this work. Its going to be a bear.
