BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Screw in Tire Tread
European Auto Source
      11-25-2013, 05:57 PM   #1
F30Drive
F30Drive
F30Drive's Avatar
Drives: 2013 328i Sportline
Screw in Tire Tread
Just noticed a screw in the tread of my run flat summer tire! So annoying as I've only had the car for 7 months and only driven 3500km. Does anyone know if BMW Canada covers this repair????
2013 Melbourne Red 328i Sportline 6MT- Black Dakota Leather - Aluminum - Coral Red - Premium Package - High Speed Max.
      11-25-2013, 06:13 PM   #2
f31mtl
Drives: 2017 330i Touing
Only if you have the extra rim and tire protection package. My dealer tells me that they don't repair run flats only replace them. But you can go to any tire shop and they will fix it. I had a run flat fixed on my mini a few weeks ago. Its a very inexpensive fix.
2017 330i Touring M
      11-25-2013, 09:18 PM   #3
shag
The Black Wagon Man
shag's Avatar
Drives: '14 328xdT M Sport
Yep, done it before too - nobody wants to touch a run-flat tire unless you REALLY insist and sign a waiver. Make sure the screw is straight and in the middle of the tread, if it's not, you might need to replace the tire. Also, do NOT let it run out of air/pressure, if it's a slow leak keep some pressure in it. If you drive with a completely deflated tire, you'll end up damaging the sidewalls - if you absolutely need to drive it, you can do so (they're runflats after all) but no more than 80 km/h IIRC.
Do you have OEM Pirellis? If so, they have a comprehensive road hazard warranty which might mitigate the cost of a tire replacement (prorata calculation).
More info here:
http://www.pirelli.com/mediaObject/p...atWarranty.pdf
'14 328d xDrive Touring M Sport, BSM/CR.
      11-25-2013, 10:07 PM   #4
F30Drive
F30Drive
F30Drive's Avatar
Yes the car came with Pirelli tires. See the attached pic of the screw. Do I contact Pirelli directly?
      11-25-2013, 11:41 PM   #5
shag
The Black Wagon Man
shag's Avatar
Oh. Not sure I would risk it at that position. I think you have to go through your dealer, how long have you had the car?
      11-26-2013, 12:18 AM   #6
F30Drive
F30Drive
F30Drive's Avatar
I've had the car for 7months and I have 3500km on it.
      11-26-2013, 12:19 AM   #7
F30Drive
F30Drive
F30Drive's Avatar
FYI. I found the screw this weekend when I was putting my winter tires/ rims on.
      11-26-2013, 08:31 AM   #8
tristantumble
tristantumble's Avatar
Drives: '17 340xi msport 6MT, MPPk
I got a screw in my tire after 3 days of owning my car. Called the tire manufacturer and they had no warranty to cover this. The dealer however patched it and waved the repair charge.
      11-26-2013, 09:22 AM   #9
n55x3
Drives: n55 BMWs
It's an easy do it at home fix. Just get a tire plug kit and you can fix it in 10 mins max. Did this last year on my wife's RFTs. Her's was actually a bolt and probably caused an even larger hole than that screw.
http://www.amazon.com/Slime-1034-A-T.../dp/B000ET525K
You don't even need to take the wheel of the vehicle.
      11-26-2013, 11:37 AM   #10
335BOY
Drives: 2017 SQ5
Exactly. ANY tire shop will fix it in 10 mins if you dont want to do it yourself.
      11-27-2013, 04:58 PM   #11
csnow
Drives: 2013 EBII 335i xdrive Msport
The Pirelli road hazard warranty should cover you. I had a similar situation earlier this year (tire was only 4 months old). I called Pirelli and they said any authorized Pirelli dealer could replace the tire for me under warranty. I went to Kal-Tire, they didnt believe me so I had them call Pirelli to confirm. In the end, Pirelli confirmed for Kal-Tire that the warranty existed and gave them instructions on how to submit the warranty claim. I got a brand new tire at no charge.
