02-17-2015, 12:32 PM | #90 |
Rep 1,145
After months of planning and searching, I finally have all my parts in to do this!!! Doing my prep work now while it's cold and rainy, will try to get this done this weekend and will post my notes afterwards!
02-18-2015, 09:32 PM | #91 |
Rep 25
Ah, i see you also have a M-Sport, i think the coding may be a little different since we dont have the fog lamps, can you please let us know exactly what you code?
02-19-2015, 09:14 AM | #92 |
Rep 241
Thanks for this. Will start collecting parts now.
Charlie Vu
2013 328iX Melb RED- JB4 - AFE 5R Intake - B14 Bilstein - Morimoto H1 Projectors and LED Angel eyes- Morimoto HD Elite 50w 5500k H.I.D. |
02-19-2015, 09:21 AM | #93 | |
Rep 241
Charlie Vu
02-19-2015, 11:21 AM | #94 |
Rep 1,145
In total around $1600 I would say. I was able to find one complete headlight a few months ago for $700, then was able to piece together the other side, then order all the parts brand new for the levelers which I plan to try. It really is a matter of patience unless you want to spend big, I spent months looking for the control module on ebay with no luck, then out of the blue 2 of them get listed within days and I finally was able to get one for $75 instead of having to buy it new for $300.
I also found that for another one of the screws, you can just find the equivalent at Lowe's/Home Depot. There was one in particular, "B. 07129904491 (x4) - ISA M5x10 screw", that would have been on backorder for a couple weeks, so I just got a couple packs of M5x10 flat pan screws that seem to work just fine. |
03-17-2015, 04:34 PM | #95 |
BMW Fanatic
331
Rep 1,076
Is there anyway to simply make the xenons only adaptive?
Thanks
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
03-21-2015, 08:15 PM | #96 |
Rep 1,145
Coding was no different, since adding the VO options 522 and 524 don't affect the headlights at all.
03-21-2015, 08:22 PM | #97 |
Rep 1,145
Some positive news to report! I finally finished this retrofit, and everything seems to function just fine, except I am having one minor problem. My passenger side headlight is aimed down much more than the driver's side, and I am receiving an error on the car of "Headlight Vertical Aim Control Malfunction."
EDIT: So apparently that is the error message given regarding the levelers issue, because when I use the coding to disable the levelers, that error message went away. I was able to adjust the headlight beam manually back to being level. I will have to keep looking into this to see if I can figure out a resolution. Otherwise, everything works great! Thanks to those who put in the effort to make the guide. It was very spot on, including the difficulty in installing the rear leveler and removing the halogen headlights lol. Last edited by roxxor; 03-22-2015 at 02:30 PM.. |
03-25-2015, 05:05 PM | #98 |
Rep 46
My 2014 328d (build 09/13) has pn 63117259551 and 63117259552 for headlights, but it apparently does not have adaptive headlights.
I VO coded 524 on to it, coded the ecu, and then fdl coded LWR_AHL_TYP = auto./dyn. LWR+AHL = 03, C_FLC_ENA = F030disable (stock was F030enable but tried disabled anyways), C_AFS_ENA = F030enable, C_BLC_ENA = F030enable, C_CLC_ENA = F030enable. It did have the auto leveling headlights before, and they still function, but I'm getting adaptive headlight failure message on my gauge cluster. Is there anything else I need to code (or add?) to get this all up and running? I'm hoping that since I have at least 63117259551 that 63117259552 is also an adaptive headlight but I can't find any info on these part numbers other than 63117259551 here. Thanks! |
03-25-2015, 08:02 PM | #99 |
Rep 1,035
From TokenMaster... but even he puts out his disclaimers . I tried to get as close to your build date as possible. It only has options for March, July, and November 2013 - so I picked November.
Fortunately, it appears only two ECUs are affected, FEM_01 and REM_01. Its looks like all your FDL coding was done only on FEM_01. Try coding REM_01 as well. I'm not sure why REM would be affected by headlights, but its listed here. Good luck and let us know how it goes |
03-26-2015, 01:01 AM | #100 | |
Rep 46
03-26-2015, 12:35 PM | #101 | |
Rep 1,035
Here you go . |
03-26-2015, 07:02 PM | #102 |
Rep 1,145
I can't find anything about those part #'s, and Google only turns up a couple hits. The document in the instructions is a typo, it should be 63117259554. So if your headlights are in fact the Non adaptive ones, you wouldn't be able to add the coding successfully since they wouldn't have the correct mechanism in the lights.
03-27-2015, 02:13 AM | #103 | |
Rep 46
I'm seriously choked at my dealer because they said the car had adaptive headlights, which is one of the options I wanted because it was incredibly useful on my E90 where I live. I didn't actually double check on delivery and just assumed that the bi-xenons meant adaptive headlights since thats what I was told came with the lighting package. It wasn't until about a week after delivery that I noticed that they didn't swivel when I drove because I hadn't done any night driving since. Of course once I brought this to their attention, they ended up being useless and saying "Oh, it's only on the 2015's for the 328s and its part of the executive package. Nothing we can do now unless you want to trade it in and get a new card..." |
03-27-2015, 07:23 AM | #104 | |
Rep 1,145
03-27-2015, 07:56 AM | #105 | |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
BMW Canada - Stupid packaging techniques! |
03-27-2015, 04:07 PM | #106 | ||
Rep 46
So I guess this would be my shopping list? 63117259553 or 63117338707 - Driver side adaptive headlight 63117259554 or 63117338708 - Passenger side adaptive headlight http://www.realoem.com/bmw/showparts...49&hg=63&fg=05 63117316186 x2 - Driver module for headlight http://www.realoem.com/bmw/showparts...56&hg=63&fg=05 |
04-13-2015, 11:01 PM | #107 |
Rep 10,473
hey guys, new to the f30 here and was on e90post for a few years, so i picked up a f30 with the dreaded halogens. My question is, since there so many adaptive headlights on ebay can i buy a adaptive one, but code only xenon and not adaptive and make them be static? would that work? or will they not work properly?
04-14-2015, 08:29 AM | #108 | |
Rep 376
04-14-2015, 10:33 AM | #109 | ||
Rep 10,473
1) i dont care for adaptive, i mostly drive on the freeways so i do not need to bee around corners that much. 2) to retrofit adaptive xenons i will need to install sensors on my control arms and run wires thru the car to the computer and its a lot of work. 3) i dont want to just put a hid kit into a halogen reflector, light goes everywhere |
04-14-2015, 01:58 PM | #110 | |
Rep 1,145
The only difference in the adaptive Xenons is the housing and the control module. So either way, you would need the levelers unless you just code it to disable them. |
adaptive, diy, f30, install, xenon |
