| 01-26-2014, 01:05 PM | #1 |
Rep 2,054
Posts ![]()
Drives: 2020 G20 320i M Sport
Can't get radio to work on CIC to NBT retrofit
Not sure if anyone here has a solution but I originally had a factory CIC infotainment system on my F30 and I swapped it out for a NBT system. On the CIC, there was one black FAKRA connection that was used for both AM an FM radio but on the NBT however, there is a white FAKRA port for AM/FM1 and black port for FM2 only. If I plug the original black FAKRA into the white port, AM doesn't work and some FM channels work. If I plug it into the black port, AM works but FM only has a few stations. Does anyone have a solution on how I can get this to work? If I plugged that one black FAKRA into the CIC, it works perfectly fine.
Diagnostics/Coding | CarPlay Solutions | iDrive head unit repair & retrofits steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca iDrive Head unit repair services | Remote Coding Package| NBTEVO Retrofit wiring kit + programming |
| 10-05-2014, 12:08 PM | #2 |
Rep 15
I'm in the same situation that you were in, as I've stated in the main NBT thread... I think that the issue will be better spotted in this separate thread
Any chance that someone knows how to solve this issue? |
| 10-05-2014, 05:46 PM | #3 | |
Rep 287
Plug in your Original Fakra connector to the Port 7 of your NBT and separate antenna like bellow to port 6. Should work fine. http://www.ebay.com/itm/ANTENNA-DA-V...item5d4dc59144 |
| Bookmarks |
