BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Explanation of How M Adaptive Suspension Works
Vorsteiner
      12-09-2013, 06:01 PM   #23
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Originally Posted by momo3605 View Post
Really? So you mean even in the soft setting it can become stiff based on certain readings? If so, what would that reading be?
From @Racer20's post:
Originally Posted by Racer20 View Post
When driving down a smooth road, the active valve is fully open, and the damper is in full soft**, or some "steady state" setting close to it. When the sensors detect a large swell, pothole, choppy pavement, etc., or if you turn the steering wheel or brake or whatever, the ECU does the math and sends some current to the active valve solenoid for a split second. The valve gets stiffer, the damping force increases to deal with whatever is going on, then it drops back down to the soft setting. This all happens in fractions of a second.
**(Note that "full soft" is /= comfort mode. Full soft means no current being sent, no active control, absolute minimum damping force. Comfort mode typically has some level of active control, just less of it than normal and sport modes)
      12-09-2013, 07:25 PM   #24
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
Read my previous post. It's still adaptive, but the mode you're in determines how much the damping you start with and how much it increases for a given road event.
      12-24-2013, 02:18 AM   #25
RSXDC5
RSXDC5's Avatar
99
Drives: M3
Very informative stuff here guys! Thanks!
2015 M3 - Alpine White 6Spd
LED's, CCB's, Adaptive Dampers, Swifts, VRSF DP's, GC Camber Plates, 275/305 AD08R, Signature Wheels SV103 19x10.5/11.5
      01-02-2014, 01:47 PM   #26
Bleser
Bleser's Avatar
Drives: 2013 335i Sport RWD
Originally Posted by DVC View Post
It would be great to read your thoughts on the various considerations that are popular around here... some of those being:
  • Changing Just Springs - Many guys go for just lower springs (e.g. H&R Sport), with a similar spring rate to OEM. I have been considering going with slightly firmer springs, only about 1/2" lower, with matching bump stops. (Dinan plans to release a spring/bump stop kit in January 2014) Seems like these would match up well with the stock adaptive dampers in Sport mode...
  • New Shocks/Springs - e.g. Bilstein B8/H&R Sport springs have been popular and well-regarded
  • Coilovers - KW V3, Bilstein B16, TC Kline, etc. More adjustablity than regular shocks, but maybe not necessary? I've heard that the JRZ kits are in a different league altogether in terms of both comfort and performance...
  • Stiffer Anti-Roll/Sway Bars - I've seen claims that these will address the lateral body roll issue without doing much to change individual shock damping... but I've also heard that too stiff ARBs can be counter-productive.
Anxious to hear @Racer20's response to this. I imagine just changing springs throws off all the calculations/model so far that you lose the effective damping system and calibration, but then again it sounds like changing wheels/tires also does this, so maybe it's an acceptable change.
I'm in the market for a used F30 and some have the adaptive M suspension and some don't for a similar price point. All things being equal, at this point I'm not sure I'd want the adaptive system or not. I always say I won't mess with the car's suspension, but a few years into ownership I change my mind I won't want to regret the decision either way.
      01-02-2014, 02:31 PM   #27
momo3605
Drives: 2016 M4
Assuming price is equal, I'd say go for the adaptive. You can always swap it out to an aftermarket suspension just like the passive one. But I feel like for the $900 they charge out the door for new adaptive suspension, I would've saved it towards the M perf suspension. The fact is both suspensions are soft. It's just which one will enable you to upgrade the suspension more easily. That would be the passive, but not by a huge margin. You'll just need to get the error lights for the edc coded out unless you go with KWs edc coilovers
      01-03-2014, 10:37 AM   #28
Bleser
Bleser's Avatar
@momo3605 - thanks for the feedback. That was my feeling as well, but it also comes bundled with the variable sport steering and I've seen mixed reviews of that.
      01-03-2014, 12:39 PM   #29
DVC
DVC's Avatar
Drives: 335i
Well, until we get some more wisdom from Racer20, here are my thoughts on the F30 adaptive suspension...
Unless you plan to swap out dampers right away, it's definitely worth getting the Adaptive M Suspension. It controls body pitch/roll better than the passive sport suspension, while at the same time also takes bumps more smoothly. In most situations, when the driver is giving smooth inputs, it is an excellent suspension. When driving aggressively, or on poorly constructed/maintained roads (mid corner bumps, etc.) there is more pitch/roll than I like, but not too bad.
My suspicion is that slightly shorter/stiffer springs will match up quite well with the adaptive dampers in sport mode. The Dinan springs and matching bumps stops (which should be released this month) will hopefully hit the nail on the head. When Dinan is able to get past BMW's encryption and release their Shockware (with a revised, firmer Sport mode suspension calibration), then the Adaptive M suspension will hopefully offer the more taut ride that we're all looking for, while still giving the capability to switch to a softer mode for cruising down the highway, etc... This is one of the reasons I wanted adaptive suspension in the first place, so I'm reluctant to replace dampers until I give the Dinan system a chance.
But in the event that we want to change to new dampers at some point (M Performance, Coilovers, etc.), this can of course still be done. We lose the adaptive aspect of the stock dampers - as well as the ability to change firmness settings - but it's still doable. In order to avoid EDC error codes, there may be coding options, or as I understand it, KW has a module that can be used (not just with their suspension).
... the variable sport steering ... I've seen mixed reviews of that.
I've not heard any negative reviews of VSS - everything I've seen has been unanimously positive... which is another reason to opt for DHP, even if the suspension gets switch out later.
      01-03-2014, 01:42 PM   #30
Bleser
Bleser's Avatar
@DVC, thank you for your reply. Going back on my comment about the variable sport steering, I can't 100% confirm that is was negative on the 3-series; I know other manufacturers have gotten knocked for 'artificial' load off-center that isn't predictable with these systems. If it's good in the 3 then it'll probably be worth it, and I might be confusing reviews.
Excited to learn more about the Dinan system once released. I agree with you that going with the Adaptive M suspension and then the Dinan springs/tuning later might be just about perfect.
      01-03-2014, 06:04 PM   #31
DVC
DVC's Avatar
Drives: 335i
...I can't 100% confirm that is was negative on the 3-series; I know other manufacturers have gotten knocked for 'artificial' load off-center that isn't predictable with these systems. If it's good in the 3 then it'll probably be worth it, and I might be confusing reviews.
There have certainly been knocks on the 3-series electronic steering in general, but that's more related to the weight/feedback of the steering compared to the e90 hydraulic system. But as far as F30 steering goes, I think the consensus is that VSS is preferred.
      01-07-2014, 12:56 PM   #32
Racer20
It's hard to offer a very good answer to specific questions like these without having driven the system to know what's really causing the poor performance. The best I can say is that a slightly stiffer spring (5-10% in rate, <1/2" drop) or 1-2mm larger in sta-bar diameter may help the situation, without sacrificing ride too much, but anything larger than that will likely put the car too far outside the model's parameters, and result in some tradeoffs. Your best bet would be to keep the front to rear spring/bar rate ratio of the stock system.
Sorry I can't be more specific, there's just no DHP cars anywhere near me to test drive.
      01-07-2014, 06:45 PM   #33
Bleser
Bleser's Avatar
These threads concern me about both the adaptive suspension and VSS:
http://www.f30post.com/forums/showth...neven+pavement
Not sure if these problems are on *every* car with Adaptive M and VSS or what, but these threads with no resolution and multiple problem reports can ruin an ownership experience. Do you have these issues?
      01-08-2014, 12:06 PM   #34
DVC
DVC's Avatar
Drives: 335i
I have experienced nothing of the sort.
      01-09-2014, 09:03 PM   #35
Andrew@ActiveAutowerke
Andrew@ActiveAutowerke's Avatar
607
Drives: 17 F80 M3 YASSS
I just installed super sports on my adaptive suspension 435. It works perfectly so far in all settings. No codes or anything as of yet but I only have 30 miles.
      02-03-2014, 11:01 AM   #36
Ghetto2315
Drives: 16' BMW i8
So what is the difference between M Adaptive Suspension and M Dynamic Damper Control on the new F8X M3/M4? Or am I an idiot??
      02-03-2014, 11:09 AM   #37
Dernayka
Drives: Bmw x6 50i
Send a message via Skype™ to Dernayka
How to identify if my car got those adaptive dampers or anything else?
      02-03-2014, 11:11 AM   #38
Racer20
Different names for the same thing. BMW uses several different suppliers for this technology depending on the platform, so they may have some kind of branding scheme where they call one system Adaptive, and one Dynamic. They are all a bit different in how they work and their capability, but the basic functionality is the same. I could be wrong, but as far as I know, the different terminology doesn't mean anything.
      02-03-2014, 11:51 AM   #39
Richbot
Drives: Jerez Black E90
There is a standard disclaimer that comes from every OEM chassis enginerd I have ever talked to: if you change anything I wash my hands of you and you could and probably will die
      02-03-2014, 12:18 PM   #40
hyperboost
hyperboost's Avatar
38
Drives: M3, 535XI Msport
first, thanks to OP for posting up this review. I never quite understood what's adaptive and passive suspension.
then, one part of your post you mentioned that 18mm increase in rear offset is HUGE and makes a difference. I think a lot of members will put on more aggressive wheel setups once they get their M3/M4. Does this mean that the handling will suck?
What would happen if the offset number is lower but the wheel weight is lighter?
F80 YMB M3 DD|16 RS7 Stock|16 Range Rover SC'ed|12 GTR Stock|F10 535XI Msport AW - Sold|E92 M3 MR exported to China |E93 M3 AW sold |E46 M3 IR ESS SC'ed with loads of mods|E46 M3 TiAg Track weapon Moton CS suspention - sold|Bentley Continental Mulliner package - sold|87 944 NA winter beater - gone|E39 540iA - sold|10 Cayman|04 G35 Turbo'ed 380rwhp - sold|03 350Z SC'ed - Sold|11 Mustang GT SC'ed 513rwhp - sold|AW SC'ed E92 M3 - gone
      02-03-2014, 12:23 PM   #41
nachob
Drives: 2011 1M, 2003 330i ZHP
I'm a chassis engineer and I develop adaptive suspensions systems. This will be long.
Excellent write up and thank you for this contribution! While these systems have a place in many luxury cars, I don't want them in a M car. Just like launch control etc. As you pointed out they can do strange things sometimes and as you learn your car's traits, there is always digital intervention that you sometimes cannot always predict. I work with software and I can tell you that it is very difficult to program for every situation. The justification for these active suspensions is to provide a comfortable ride with sports-car handling when you need it. That's a nice goal but the tradeoff in expense, lack of predictability and maintenance after warranty is expired and weight is not worth it. If you want a comfy car, get a Lexus or non M car with adaptive suspension. M cars should be as light and driver-feedback oriented as possible.
I remember the 1992 F1 season. Williams came out with their adaptive suspension and was crushing everyone. Theirs was tuned for performance and it worked great on the racetrack where it is a very controlled environment UNTIL they hit Monaco which changes from streets to highway, etc. They had to turn it off. I know things are much better now and if I had a 550i or a luxury sedan, I would love this active design but not for my "racecar for the street,"
Again, I am not shooting the messenger, I am grateful for you post, I'm just concerned because BMW USA just made the Adaptive Suspension mandatory for the USA market. In the past, if someone wanted this type of system it was choice and this choice is being taken away.
Thanks
      02-03-2014, 12:44 PM   #42
DASHOCKER
The power of V!
DASHOCKER's Avatar
Drives: 2007 335i coupe steptronic
1998 Lexus Gs400  [0.00]
2010 ebony & ivory  [0.00]
2006 BMW X3  [0.00]
2009 pics  [0.00]
2009 e92 335 xdrive  [0.00]
Send a message via Yahoo to DASHOCKER
nyc potholes will really put this to the test.. my poor car lol..
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm.
      02-03-2014, 12:59 PM   #43
MSportDC
///MSport-DC
MSportDC's Avatar
Drives: 2013 F10 M5, 2012 X5 35d
2012 BMW X5 35d  [0.00]
Racer20,
What are your thoughts on the application of after-market springs by reputable companies such as H&R, eibach on these highly complex, modern EDC BMW suspension systems?
In other words, do you advise against their application since as you say in your post that these configurations are highly complex and subject to behave in very strange, albeit unsafe, ways for the vehicle?
Thanks.
2012 BMW X5 35d (Alpine white/Black - Loaded) - Delivery: 2012/9/17
2013 BMW M5 (Azurite black/Black full merino/Piano trim/20"/Exec./Driver Assist. - Delivery: 2012/11/16 (GONE)
      02-03-2014, 01:11 PM   #44
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
Dinan springs and bump stops going on my adaptive suspension right now. I'll update how it feels later today. Hopefully.
2015 M3 Alpine white, shakir orange
carbon roof, black 19's, lighting, executive, HK
side&top view, adaptive susp, mods to come......
