03-19-2014, 11:12 PM | #1 |
Rep 458
Wheel Question - Forgestar F14's
Hi all, I'm hoping for some opinions and advice on a wheel set up. Currently I am on OEM 400M M sport wheels with a square set up. I have xdrive and want to move to a 19" wheel. I've seen some post with concerns that a staggered setup will damage the xdrive system but the 403m option is available from BMW with the staggered wheel/tire combo so I assume that's false. I would imagine keeping wheel and tire combo diameter as close to stock would be more important. I'm also stock ride height but possibly looking at H&R sport springs at some point.
Would the recommended set up be 19x8.5 Front and 19x9.5 rear? The company I am ordering through recommended 19x8.5 or 19x9 upfront on 245/35/19 then 19x10 in the rear on 275/30/19. Unfortunately, the super deep concave's offset won't work with the F30 so deep concave is my only option. Should I go deep concave all the way around or semi concave upfront and deep concave in the rear? This is a daily driver I am not trying to get too aggressive so comfort and reliability are not affected. I appreciate any feedback! Thanks!
Alpine White '16 M3 6MT
03-20-2014, 12:27 AM | #2 |
6579
Rep 5,304
If you go with a 10" for the rear, I ABSOLUTELY recommend you go with a 9" front. A 245 will look a little wide on the 8.5" wheel, but will be perfect for the 9" width.
03-20-2014, 12:41 AM | #3 |
Dinosaur supervisor
3030
Rep 4,214
I wouldn't go 9/10 if I was on stock suspension since those offsets will be quite aggressive. You won't rub but the wheels might end up a tad outside the fender.
Unfortunately the wheels will be almost flat in a 8.5/9.5 setup. |
03-20-2014, 08:47 AM | #4 | |
Rep 458
03-20-2014, 11:13 AM | #6 |
Rep 204
I'm running 19x8.5f et30 with 245/40/19 and 275/35/19r et42 on a x-drive lowered on H&R springs and so far no rubbing. This is on a F32 and don't know how different the F30 is.
03-20-2014, 11:49 AM | #7 | |
Rep 458
03-20-2014, 11:50 AM | #8 | |
Rep 458
03-20-2014, 03:15 PM | #9 | |
Rep 204
03-21-2014, 11:12 AM | #10 | |
Rep 227
Tires are still a variable too. I've worked out a deal with the shop I'm working with to use whatever fits. We're gonna try to squeeze 285s on this baby! |
03-21-2014, 02:50 PM | #11 | ||
Rep 458
03-24-2014, 01:18 PM | #12 |
Rep 1,392
Do you think my e92 forgestar F14 will fit my upcoming F32 435 with M suspension:
F: 19x9.0 5x120 ET35 R: 19x10 5x120 ET28 Thanks.
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
