01-05-2023, 01:30 PM | #1 |
Rep 94
Drives: 2018 BMW 440i GC
F36 440i RWD Wheel and Tire Upgrade Question
I recently purchased a used F36 2018 440i Gran Coupe RWD. It came with the Track Handling Package so it has upgraded M brakes (large slotted rotors in front) and 704M 19" staggered wheels (225/40/19 and 255/35/19).
The problem is that I live in Atlanta and some of the roads within the city are horrible.. I'm pretty sure I've already bent one wheel after hitting a pothole. And yes, the car came with run flats which I absolutely hate. I want to downgrade to 18" wheels and tires with a taller sidewall for more comfort within city driving. I will probably drive it on the track once a year but do some spirited mountainous driving every month so don't want to take too much of a hit on handling. Anyway with my current setup, since I have to buy new 18" wheels anyway, I want to upgrade to the widest tires that I can possibly get for the car without any modifications to the suspension or fenders. TL;DR: What are the widest possible wheels/tires I can mount on my 2018 440i GC RWD w/ M brakes without any modifications? Would be great if I could get wheel size, tire size and offset options. Thanks! |
01-05-2023, 01:52 PM | #2 |
Rep 4,380
widest practical is
255/40/18 front, optimum wheel width 9", min 8.5" max 9.5" up front, offset between ET30-35, ET35 if 9.5" 285/35/18 rear, optimum wheel width 10" or 10.5", min 9.5", max 10.5" at rear. offset between ET40-45, ET45 if 10.5" what wheels are you considering? . Last edited by alohasurftoad; 01-05-2023 at 02:43 PM.. |
01-06-2023, 12:32 PM | #3 |
Rep 94
Thanks for the info. With your info, I'd plan:
FR: 18x9 w/ 255/45/18 RR: 18x10 w/ 285/40/18 Do you think these sidewalls will work? I honestly have no idea about what wheels I'd choose, I don't even know where/how to start looking. But for tires I'm considering either PS A/S or Continental DWS 06 (A/S) |
alohasurftoad3132.00 |
01-06-2023, 01:18 PM | #4 | |
Rep 4,380
it is very important you are within the offset range i have given for the wheels that you choose. what is your total budget? for wheels/tires/tpms/etc. what wheel style desired? if you can obtain some used 513M or checkout Apex FL-5 or EC-7 for now. if i think of something else i'll post later Last edited by alohasurftoad; 01-06-2023 at 01:40 PM.. |
mclovin69x40.50 |
01-07-2023, 10:36 PM | #5 | |
Rep 22
01-07-2023, 11:09 PM | #6 |
Rep 4,380
01-08-2023, 12:22 AM | #7 | |
Rep 5,413
mclovin69x40.50 |
01-11-2023, 01:30 PM | #8 |
Rep 94
Thanks for the responses. So I kinda switched directions and I'm leaning more toward a square setup now.
I found these wheels (18x9.5; 5x120; ET36): https://www.bbwheelsonline.com/verde...hoCYHQQAvD_BwE Planning to put 255/40/18 (26" diameter) DWS 06+ on them. Y'all think this could work? My budget would probably be under $1500. I really don't want to spend money on this but I'm hoping I could get around $1000 back at least by selling my 704M wheels (CarMax put brand new tires on the front yesterday, but they put run flats |
01-11-2023, 02:02 PM | #9 | |
Rep 4,380
https://f30.bimmerpost.com/forums/sh...8&postcount=16 you can run ET36 if the rim width is 9" or 8.5", though. how about these? https://www.aodhanwheels.com/collect...43630946779395 https://www.aodhanwheels.com/collect...37849198657693 . Last edited by alohasurftoad; 01-11-2023 at 02:24 PM.. |
01-17-2023, 10:03 PM | #10 | |
Rep 94
I'm still looking for rims and tires. I don't want to spend so much on brand new ones so I'm looking around for used options. A lot of wheels that came off M cars for around 1800$ but they're too big. I came across a set Apex SM10 (10" and 11") with PS4s) Any idea how much I'd be able to sell my 704Ms with 19" runflats on them for? |
01-17-2023, 10:13 PM | #11 |
Rep 94
Anyone know if these wheels would work on my car?
https://www.facebook.com/marketplace...b-8239e0c53a10 |
01-23-2023, 01:34 PM | #12 | |
Rep 94
I found some 219M wheels in a staggered setup for sale near me 18x8.5 +29 245/40/18 18x9.5 +23 265/40/18 They have Continental Extreme Contact tires on them right now I know that the offsets are off but do you know if these will work alohasurftoad |
01-23-2023, 03:38 PM | #13 |
Rep 4,380
the rear will be poking far out and may contact the fender lip under compression. it also increases understeer from front/rear tire width stagger and widening rear track. if you do not care that the your handling is worsened, it will fit with those shortcomings.
01-30-2023, 05:52 PM | #14 |
Rep 94
alohasurftoad thank you for your help so far.
I did a little more research and read more of your posts and I am trying to figure out if this setup will work. Your confirmation/advise would be great. FR: Bayern Antler 18x9.5 ET35 with DWS 06 255/40/18 https://www.carid.com/beyern-wheels/...AaAg7dEALw_wcB RR: Bayern Antler 18x9.5 ET45 with DWS 06 265/40/18 https://www.performanceplustire.com/...MaAmVDEALw_wcB I do have M Brakes in the front (370mm) with the Blue calipers that came with the ZTR package so I'm trying to make sure that the front wheels will clear the brakes - do you know if these rims will clear the front brakes? Thanks! |
01-30-2023, 07:19 PM | #15 | |
Rep 4,380
if square, it'd be better to run 18x9.5 ET35 with 255/40/18(non-directional tires) square so you can rotate any direction. obviously, it will be 10mm less in the rear than a 265/40/18, so i understand if you want rear at 265 for dig traction. if you're interested in it staggered, you can do 235/45/18 on 18x8.5 ET30 front, 265/40/18 on 18x9.5 ET45 rear. here's 18" antler on F30 https://www.butlertire.com/gallery/B...r_Wheels/10100 not sure if you are interested in this look, Aodhan AH-X reasonably priced and decently light as well. 255/40/18 square on 18x8.5 ET35(20.24lbs) or 18x9.5 ET35(20.94lbs) if you want more concavity with a slight stretch. https://www.aodhanwheels.com/collect...43678907924739 |
mclovin69x40.50 |
01-30-2023, 07:36 PM | #16 |
Rep 4,380
be careful with the CARID beyern antler it is listed as 5x120.65. it will fit our 5x120 but is off by a hair, so the lugbolts would closer to the hub by a hair, not perfectly centered. |
01-31-2023, 02:27 AM | #17 | |
Rep 94
01-31-2023, 03:06 AM | #18 | |
Rep 94
You're right, I don't think the extra 10mm is worth giving up the benefits of having a square setup and rotating.. BUT I can't help but wonder what a 285 on the rear would be like alohasurftoad in your opinion, what would the handling and ride difference feel like between a 255/40/18 square setup and a 255/40/18 - 285/35/18 staggered setup? - both setups on the same antler wheels I figured I might as well have all the details before spending $1800 on this set up Last edited by mclovin69x; 01-31-2023 at 10:43 AM.. |
01-31-2023, 10:44 AM | #19 |
Rep 4,380
the difference in ride would be basically imperceptible. the difference in handling depends on what front and rear offsets you choose for the tires and would only be felt at or near the cornering limits
mclovin69x40.50 |
02-01-2023, 12:05 AM | #20 | |
Rep 94
Before I pull the trigger, will this work alohasurftoad : Front: Bayern Antler 18x9.5 ET35 w/ 255/40/18 Rear : Bayern Antler 18x9.5 ET45 w/ 285/35/18 (should I go with ET35 or ET45 here) |
02-01-2023, 12:44 AM | #21 | |
Rep 4,380
https://f30.bimmerpost.com/forums/sh...8&postcount=16 with 285/35/18 rear, you need ET45. ET35 will stick out too much |
mclovin69x40.50 |
02-02-2023, 12:23 AM | #22 |
Rep 94
would it be more suitable if I go with a 18x8.5 ET35 Antler in the front? Would this increase the clearance with the strut?
