06-06-2019, 07:13 AM | #23 |
Rep 445
That's the one I used, it actually had a different one listed that was discontinued and that one should be the replacement. When I had both in my hands at once it was pretty obvious the difference, probably due to age. My old o ring was so limp lol
10-08-2019, 10:14 PM | #24 | |
Rep 7,633
Sorry to bump and older thread but i just read about the orientation of the IC-CP O-ring for about an hour and it still isnt clear. I suspect i have a boost leak and this is the only part of my IC+CP install i am not 100% certain about. Can anyone confirm that the above sketch someone made is incorrect? I believe thats what the posts after this picture stated, but i saw different information in other threads. I think i installed it as in the picture above, where the taper was going in the direction i was sliding the pipe on. |
10-08-2019, 11:38 PM | #26 |
Rep 5,410
Here's a sketch that I found last year.
alohasurftoad3132.00 |
10-08-2019, 11:50 PM | #27 |
Rep 7,633
That sketch agrees with the sketch i posted from earlier in this thread, but then it seemed like people were giving the opposite info.
In any case, thanks for the replies. I am going to try to make a basic boost leak tester this weekend to identify and fix any leaks. If it turns out I have a leak at IC-CP connection, I may just order a new O-ring before taking anything apart to replace it. Hopefully you can get that at BMW? I will follow the above two sketches, which is how i installed it originally i believe. |
10-09-2019, 08:30 AM | #28 | |
Rep 445
FWIW the hot side(Turbo to IC) mirrors the drawing I made, but the air flow is the opposite direction. |
10-09-2019, 08:37 AM | #29 |
Father of Frankenfold
300
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I use 4.0mm x 59mm o-rings for my FMIC connections. They make it slightly more difficult to install the FMIC, but they're non-directional and seal better.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
10-09-2019, 11:44 AM | #30 | ||
Rep 7,633
I also read that the O-ring should be pretty firm, but mine was definitely soft. I kindof thought that soft was normal for the O-ring, with more firm indicating signs of age... Quote:
FWIW my IC-CP connection was SUPER easy to install, almost too easy. I lightly oiled the O-ring and IC connection point before sliding it on, but it took almost no effort for them to mate. I should have checked how loose they felt but by that point i just wanted everything back together. |
10-09-2019, 11:55 AM | #31 | |
Rep 445
Let me know how all of this goes for you, with the weather cooling down I am more inclined to mess with it. What CP do you have? |
10-09-2019, 12:22 PM | #32 |
Rep 205
Following - going to upgrade my FMIC soon, so definitely curious about this as well.
Also, how do you test for boost leak? From my search, most articles discuss loss of power, but I don't think I'm experiencing any of that (upgraded my CP & DP). As a matter of fact, even when my charge OEM CP blew off, I was able to hit redline and WOT on the freeway - honestly couldn't tell a difference that my CP was off. |
10-09-2019, 12:55 PM | #33 | |
Rep 5,410
My original factory o-ring at the intercooler end came out crimped in the groove so I was lucky that I didn't have leak symptoms. Those o-rings will be there for years. No use taking a chance re-using the original o-rings. Look at the troubleshooting time and $ to track down something that turns out to be a cheap part. |
10-09-2019, 04:10 PM | #34 | |||
Rep 7,633
In terms of identifying if you have a boost leak, you basically need to log. Typically you will see boost and load below target, WGDC higher than it should be (trying to compensate for boost leak), among other potential issues. I did logs when completely stock, then logs after IC+CP install, then logs after IC+CP+stage 1 tune, so i have all of them to compare. After the install but no tune, i was already a bit below target, whereas i was basically right on target before install. After the tune and higher boost target, i was way more below target, suggesting a leak (along with higher WGDC). You may not tell a difference if its s small leak and WGDC can compensate to reach target boost. Quote:
10-09-2019, 10:03 PM | #35 |
Rep 7,633
10-10-2019, 08:16 AM | #36 |
300
Rep 531
Inside diameter. O-rings are spec'd by cross section thickness and inside diameter.
10-10-2019, 08:39 AM | #37 |
300
Rep 531
O-ring seals for charge pipes
Here you go: O-ring seals for charge pipes
10-10-2019, 06:47 PM | #38 |
Rep 2,664
Just got doing this myself and I can say with confidence that the O-Ring flare has to be facing towards the rear of the vehicle. The other way doesn't make any sense. When I take my old CP off I will take a picture of that one as well but I'm currently targeting 18 pounds of boost with zero leak issues.
I picked up the OEM gaskets to replace my old ones with...
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
10-10-2019, 09:44 PM | #39 | |
Rep 7,633
Hindsight 20/20, i should have just ordered new OEM ones before the install, oh well. |
10-13-2019, 07:45 PM | #40 |
Rep 7,633
Following up and confirming that the posts and sketches above are correct. The Oring flare/taper goes into the charge pipe, away from the IC. I confirmed on the OEM TIC pipe.
See additional discussion about using larger Orings here: https://f30.bimmerpost.com/forums/sh...43&postcount=4 |
10-13-2019, 09:10 PM | #41 | |
Rep 445
10-14-2019, 07:03 AM | #43 | |
Rep 2,664
09-12-2022, 05:21 AM | #44 |
Rep 823
I've just stumbled across this excellent thread after noticing my post-intercooler upper boost hose connector was leaking on my N57 430d. The hoses look exactly the same as pictured in this thread.
Does anyone have any advice on how to get the damn o-ring seated into the inner ridge of the pipe collar? Try as i might, i could not get the damn thing seated all the way around. The bump before the recess causes excessive slack on the O-ring and access is very fiddly. After spending 20 minutes failing, i ended up putting the o-ring at the very end of the pipe collar instead. I've driven the car 50 miles since and it hasn't leaked at all. Once my new part arrives (and i manage to fit it) i think ill use both! |
