03-18-2020, 03:56 PM | #67 | |
Rep 470
Here's a before log at least: https://www.bootmod3.net/log?id=5e70...0b43508e6f7259 I'll get an after in an hour or two. FYI that on this tune and the Pure Stage 2, I can't go full throttle till 3500-4000 or else I get pretty heavy throttle surges that buck the car. Edit: After log: https://www.bootmod3.net/log?id=5e72...0b43508e6f8db6
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' Last edited by doodlebro; 03-18-2020 at 07:10 PM.. |
03-18-2020, 04:40 PM | #68 | |
Rep 7,733
Boost vs target looks way off in that log, especially for PS2, so i hope the Orings solve your issue. |
03-18-2020, 07:10 PM | #69 | |
Rep 470
Got one extra PSI at least, and didn't really have to massage the throttle like I usually do to get a good log that doesn't taper to 9-10 PSI by redline. FWIW it's normal for boost not to hit targets on PWG at altitude without a custom tune. Thanks again @hardparker, great mod.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
05-05-2020, 01:39 AM | #70 |
Rep 33
O-Rings
Installed all FTP pipes and HD VRSF on f25 chassis. Next O-ring works well for me:
80*4mm - FTP CP to TB; 59*4.6mm - HD VRSF to FTP CP and BP; 49*4mm - PS2 outlet to FTP BP (will try 4.6mm but not sure it would fit); 10*3mm - FTP CP to jet pipe (original size 10*2.5mm is not sit firmly). Thanks for the thread Hardparker! |
hardparker297.00 |
06-03-2020, 02:37 AM | #71 | |
Rep 596
Drives: 2012 F25 (N55), 2014 I01 (REX)
ftp includes o rings, i believe they are even pre installed did you essentially throw away the included o rings and used the ones hardparked recommended? |
06-03-2020, 11:15 AM | #72 |
Rep 7,733
If we had to use a 59x4.6 (or 4.5 if that was a typo), then theres no way OEM style Orings would work. He might have received a VRSF IC with IC/TIC pipe connections that were out of spec like i did.
evilchargerfan282.00 |
06-17-2020, 11:11 AM | #73 |
Rep 7,733
The advice is to use the stock oring if it will seal, otherwise use the biggest oring that you can fit. There are situations where people can run OEM orings with aftermarket IC/CP/TIC. However, there are also clear situations where OEM orings will not seal with aftermarket hardware (myself included in this situation if you read the thread). So, it just depends on how lucky you get with your parts. Having went through everything i did, i would not attempt a IC/CP/TIC install without having these larger orings on hand.
07-02-2020, 01:22 PM | #74 |
Moto Lover
197
Rep 604
Drives: '19 BMW S1000XR
The measurements of the o-rings, are they OD or ID? Getting ready to order them from McMaster Carr so I can get them same day.
07-02-2020, 01:32 PM | #75 | |
Rep 7,733
https://www.theoringstore.com/store/...d=41&chapter=6 Should be inside diameter, but if you are concerned, check the website of the actual place you are ordering from. Edit: Basically you measure ID and CS. For Oring store that's what they go on. |
07-02-2020, 01:35 PM | #76 | |
Moto Lover
197
Rep 604
07-02-2020, 01:54 PM | #77 |
Rep 7,733
07-02-2020, 02:01 PM | #78 | |
Moto Lover
197
Rep 604
With that being said, should I get another set that is .5mm bigger or maybe a whole 1mm? |
07-02-2020, 03:18 PM | #79 | |
Rep 7,733
From OP, what i ended up using to seal mine - "4.5mm x 60mm o-ring, lightly sanded to reduce it's thickness, worked best at eliminating leaks" You might be able to use the 4mmx59mm as that is already a step up over stock. This is specifically for IC-CP. |
09-01-2020, 10:10 PM | #81 |
Rep 7,733
09-02-2020, 09:39 AM | #82 |
Rep 35
09-02-2020, 10:14 AM | #83 | |
Rep 7,733
Not sure the exact dimensions of the OEM one, but should be almost exactly the same, perhaps half a mm smaller CS. In any case if you want the original you should be able to get it from BMW or any of the online vendors. |
09-02-2020, 10:52 AM | #84 |
Moto Lover
197
Rep 604
I forgot to update this thread when I bought the o-rings from the website in the original post.
When I bought all of these o-rings, I bought all the o-rings for my bolt ons. That includes the CP to TB, CP to IC, turbo CP to IC, turbo CP to turbo. However, I only had 1 major boost leak which was from my CP to IC. When I took the CP off, I saw that I slightly ripped the OEM that I had installed. I tried installing the "Intercooler: 2 - 4mm x 59mm" but that was too small, the o-ring didn't fit inside the groove. Of course the "4.5mm x 60mm" that thejeremyman9 recommended was out of stock so I didn't have that on hand. I went to the dealership and bought 2 more of the OEM o-ring. Again when installing the new OEM ring, I ripped it, causing another leak when I did my test. I wasn't sure what I was doing when installing it because when I put it together, there was very little resistance. I checked the inner lip and grooves to check for sharp objects but there was nothing I could see. After using the already ripped o-rings a few more times, I installed my last good o-ring and it worked out. No leaks. For reference, I have Evolution Racewerks CP, IC and turbo CP to IC. I still have these o-rings if anyone wants them, just paying for shipping and they're all yours. This is what I bought: 2 x 4.5mm X 49mm (NBR) Buna-N 70 Duro Metric O-Ring (N4.50X049) 2 x 4mm x 81mm (NBR) Buna-N 70 Duro Metric O-Rings (N4.00X081) 2 x 4mm x 59mm (NBR) Buna-N 70 Duro Metric O-Rings (N4.00X059) 2 x 5mm X 49mm (NBR) Buna-N 70 Duro Metric O-Ring (N5.00X049) 1 x 4.5mm X 81mm (NBR) Buna-N 70 Duro Metric O-Ring (N4.50X081) Last edited by itsrichierich; 09-02-2020 at 12:04 PM.. |
09-02-2020, 11:57 AM | #85 |
Rep 7,733
I think everyone bought out the 4.5x60 after that post lol. When i installed my TIC a few weeks ago it was still out of stock. I probably have 20+ Orings now of various sizes and CS... for each one i basically bought one size smaller and larger diameter with the same CS, then for the actual diameter, i bought one size thinner and one size thicker CS.
I always started with the largest CS and went down until one fit. If one fit that seemed loose, i went back up to the larger CS and sanded it down (use a drill with attachment and fine sand paper so its evenly reduced) about 0.1mm CS at a time until i could barely get it on. I had to do this for the turbo side of my TIC and my CP-IC. So if the one you need is out of stock, go to a larger CS of the same diameter and sand it down until it barely (tightly) fits. |
07-15-2021, 11:56 AM | #86 |
Car Hypochondriac
372
Rep 914
So I grabbed a 4.5x59 a while ago, noticed my charge pipe leaking at the IC connection and swapped it over. I thought it felt good for a few days, but now I've picked up a pretty loud whistle under boost... I'm wondering if reinforcing my charge pipe just blew out my DV lol.
That or the o ring isn't holding. I went and picked up an OEM seal from the dealer and I plan on putting it in today to see if I can hit 18psi again. It won't even hold 10psi right now.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-15-2021, 01:11 PM | #87 | |
Rep 7,733
07-15-2021, 02:18 PM | #88 | |
Car Hypochondriac
372
Rep 914
My only idea is my DV tore. I mean it is almost 8 years old.
