04-01-2020, 04:41 PM | #199 | |
Rep 143
I use the car so seldomly atm so it's nice to just have it work when I do. |
04-02-2020, 05:53 PM | #200 | |
Rep 6
Android 10 - Issues April 2020!
Here's a list of my personal issues post install this week. 1. NO SIGNAL on iDrive side (android is working well). I have tried removing the GREEN fiberoptic cables and putting them back on. I saw the diagram and they are in the proper attachment site. The LVDS cable is properly attached onto the android screen as well. Absolutely no clue as to why there continues to be a no signal problem. Have been on all possible websites trying to understand the issue. 2. AUDIO: I have tried all possible configurations and I am unable to hear anything from the android side. I have increased AUX volume on android. I have clicked on manual AUX and automatic AUX on factory menu settings. I have tried ALPINE AUX, HARMAN AUX, OTHER AUX and nothing. I have installed AUX cable to my car's AUX input in the center console and nothing happens. There is no other scenario I can come up with. Very disappointing. FURTHERMORE, I am unable to access the iDrive menu and so cannot switch to AUX from there either. 3. CarPlay: I purchased a wireless carplay, however, there seems to be NO CARPLAY APP. I have looked at all the apps, but there isn't a carplay. What is going on? |
04-02-2020, 07:39 PM | #201 | |
Rep 143
Although Eonon themselves never responded to my emails, the seller that I got the unit from on Amazon was super helpful and seemed to be affiliated with the company. Let me know if you want his/her contact info if you do in fact have an Eonon unit, they may be able to help or at least direct you to the right place. (I know that for my current Avin unit, they use an app called AutoPlayBox). |
04-02-2020, 09:19 PM | #202 | |
Rep 6
Anyone have any idea about points 1 and 2? I see many posts with these same issues, but no answers anywhere. |
04-03-2020, 04:08 AM | #203 |
Rep 41
About Carplay, I think that the vendorīs app should work, as there are different carplay possibilities. Thatīs why you should get the app from your vendor.
The optic cable didnīt make any diffenrence to the sound in my unit. The only thing I could observe was, that I couldnīt get a connection to connected drive and couldnīt make any changes in the bord computer when it wasnīt plugged in. I think you wonīt hear any sound until you switch media to AUX on the BMW side, which is a little bit difficult when you get no signal there. |
04-03-2020, 11:36 AM | #204 | |
Rep 6
Anyone? Thx! |
04-03-2020, 11:42 AM | #206 |
Rep 41
No signal issues are mostly related to cable connection issues. You probably have to got through the harness and check the pins. Unfortunately I donīt know which one is responsible for the picture on the BMW side. Thereīs also a small black box integrated in the harness, inside is a 15A fuse, you could check this one. But normally if the fuse is broken the whole unit doesnīt start as these are the power cables.
04-03-2020, 09:51 PM | #207 | |
Rep 6
Thx! Anyone else? |
04-04-2020, 11:49 AM | #208 |
Rep 4
Black screen on boot
Hello, I've a problem with my Android 10.25 with Snapdragon 625 because when I start engine and the stereo is on boot (with connectedDrive logo) sometimes it stucks on black screen, have any of you already encountered this problem? Thanks
04-04-2020, 03:45 PM | #209 | ||
Rep 1,049
I normally do a reset then id does start again, sometimes 2 resets are necessary. I noticed that the Android system itself is booting up as i hear DAB-Z app then. So it seems the MCU controller only does stuck. As i modified my unit i`m not able to get any warranty from the seller, so i have to live with it. Kri |
04-04-2020, 07:20 PM | #210 |
Rep 401
I've had a black screen a couple of times, maybe in cold weather, but reverse gear and backup camera is still working, and black screen is gone when I switch back. I'm not sure if this is the same problem as yours?
04-05-2020, 04:32 AM | #211 |
Rep 4
04-05-2020, 11:08 AM | #212 | |
Rep 1,049
----------------------------------------- I updated my 2GB/32GB System now also with Android 10, it seems to also work with this, not only 4GB/64GB At the moment i`m working on my Desk bench again until now it seems to run fine. i also tested the touchscreen in recovery mode again and it seems to work fine at least there It still does not work in Bootloader mode. Info: "Simple Reboot" does require root to work. Kri |
daschacka76.50 |
04-05-2020, 12:23 PM | #213 |
Rep 4
Hi, I had the same problem with the black screen on e70, helped in factory setting change the setting from harman to other.
04-05-2020, 01:03 PM | #214 |
Rep 1,049
As i`m now also on Android 10, i tested Netflix again and it does Work
I tested it with a 6.26.1. So working Widevine seems to be the first real new feature for Android 10. Please note, as Netflix verison 4 seems to crash the system, i wasn`t running it long enough to see if will also appear on V6. Kri |
04-05-2020, 07:55 PM | #215 | |
Rep 143
Does anyone know if this is a relatively safe source for that version?: https://mobile.softpedia.com/apk/net...uild+15+31696/ |
04-05-2020, 10:15 PM | #216 | |
Rep 122
04-05-2020, 11:08 PM | #217 | ||
Rep 1,049
It`s also possible to download movies and play them later Iīll try to grab the latest APK from my moblie this week then at least i have a trustfull source Quote:
Also i had two unexpected reboots, but maybe because i did no factory/wipe reset installation of the last version. As long as there are no critical issue`s reported no updates do come out. so as it`s pretty new it`s on us to report issues to the Sellers, as more users report them the better is the chance to get it fixed. i lately reported the scrolling bug, when you push the controller sidways and then rotate it, it always does a rotate to left first altough you have srcollt to right. maybe some other people could also report this Kri |
gsnake19.00 |
04-06-2020, 06:44 AM | #218 | |
Rep 1,049
Have you followed the recovery guide ? you have to rename the zip file and also rename the thumbdrives name. If you are still on Android 9 then use the Naming convention from Android 9 (P) , not Android Android 10 (Q) After every successful process you need to rename the thumbdrive again and delete the dummy text file that has been created on the drive. Kri |
04-06-2020, 01:54 PM | #219 | |
Rep 41
04-07-2020, 09:50 AM | #220 |
Rep 21
Hi to all! I found a solution for the silent bug.
Edit the line with Android media volume and set it to 39 instead of 28 in factory_config.xml and then import the file in the hidden menu in settings. No need to start and close the KsWMediaKit with Tasker. Seems to be a bug in the r/w settings in MCU or Android. @Kri Would you be so kind to update your gorgeous version of factory_config.xml with my setting in your repository so everyone can finally forget this bug? |
