03-28-2017, 09:47 PM | #23 |
Rep 884
03-28-2017, 09:54 PM | #24 |
Rep 3,211
Plenty of 335s on the street w/ 8hp45 .. I leave it to you to easily google zf slippage. ZF shafts have also snapped. Theres a reason there are tuners who also make available ZF mods as well. Push it hard enough with tunes and itll go bananas eventually and usually according to Murphy at the worst possible circumstance. Your not exempt from the laws of physics & engineering.
03-28-2017, 11:59 PM | #25 |
Rep 703
Agree with others here. Huge amounts of torque through the ZF can be done but what we are saying is that longevity and reliable will take a huge hit. How many miles/for how long have you been running 700 nm and over? For 50K mi. Or more? Been to any HPDE events?
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
03-29-2017, 02:18 AM | #26 | ||
Rep 2,379
Up to you to decide what information you will make your decision on. Quote:
(A Dane in China) Last edited by harkes; 03-29-2017 at 02:27 AM.. |
03-29-2017, 08:40 AM | #27 |
Rep 3,211
Datalog my friend and if need be consider upgrades
I dont know how you drive but if I had 500 ftlbs I would be using it all the time and thusly the transmission wouldnt last without upgrades and its expensive to replace a tranny |
03-29-2017, 08:48 AM | #28 | |
Rep 3,211
pot marks on gear teeth eventually grow in size clutch packs begin to wear and slip earlier |
03-29-2017, 03:07 PM | #29 |
Rep 775
When the transmission suddenly sounds like ball bearings in a blender, then you've gone too far.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
03-29-2017, 04:14 PM | #30 |
Rep 3,958
03-29-2017, 04:55 PM | #31 |
Rep 775
Nice vid! It's actually a deeper, more individually defined tone than that in a car.
Enjoy the Drive,
07-13-2019, 08:40 AM | #32 | |
Rep 14
07-13-2019, 07:30 PM | #35 | ||
Rep 2,379
(A Dane in China) |
07-15-2019, 08:52 AM | #37 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
In general the zf transmissions seem very durable.
Not exactly related. But a data point. I have a 2011 335d with a zf6hp28 and folks have pushed those transmissions to 700lbft, for years without failure. Which is well in excess of the 525lbft max torque rating. On modified diesels we’ve hardly ever had anyone report a transmission failure. I have no doubts that zf builds a good product. It’s not like fords older transmissions where routine maintenance was every 60k miles replace the plugs and the transmission. |
07-25-2019, 06:25 PM | #38 |
Rep 14
07-25-2019, 08:53 PM | #39 |
Rep 2,379
Du vil elske at faa din PS2 i! Hvad har du af planer med tuning? MHD/BM3 eller noget helt andet? For at gaa over 17-18psi skal du have ekstra fuel volumen, men den gaar allerede ret godt med 17psi
(A Dane in China) |
07-26-2019, 06:19 AM | #40 | |
Rep 14
Er du fra Danmark? |
07-28-2019, 08:24 AM | #41 | ||
Rep 2,379
(A Dane in China) |
07-28-2019, 11:16 AM | #42 |
Rep 2,499
The only FCA ZF licensed transmission not made by ZF is the 845RE which is used with their V6 applications. All their V8 cars use ZF branded transmissions from Germany. Now, I can't say this for sure with the Demon since it's possible FCA did some modifications on it to suit the higher torque of the supercharged V8, but I figure you're talking about the 845RE. The 845RE is very similar to the 8HP45 which is what the F30 uses (before the B58 equipped cars). It's basically the same transmission, just made in Chrysler transmission manufacturing facilities in America with some small modifications.
08-07-2019, 05:59 PM | #43 | |
Rep 14
Hvordan endte du opp i Kina? Bor selv i Norge enn så lenge, men jobber alle andre steder enn Norge Leverte bilen min til Peter hos PureTurbo.eu i går og kan nesten ikke vente med å få den installert. Må bare si, for en mann! Tror man skal lete lenge etter en mer i møte kommende og ikke minst kunnskaps rik og interessert mann enn Peter@ pureturbo. I min jobb reiser jeg mye over hele verden men aldri følt meg så velkommen som hos Peter! |
01-02-2021, 08:45 AM | #44 |
Rep 1,527
Any update on this story? I'am looking for a f30 340i (with 8HP50) and I see that stage 1 is already immediately 580Nm. So clearly beyond specification. Will it hold?
