03-23-2022, 07:35 AM | #23 |
Rep 208
Drives: San Marino blue 435i Gc
03-26-2022, 11:04 AM | #24 |
Rep 10
03-26-2022, 11:06 AM | #25 |
Rep 208
The colors are not right unfortunately. I don't know how to get that right. But the kit is self explanatory. Taps into the idrive controller. You need to pin out empty spots to run wires to doors. Then coding.
03-28-2022, 09:12 AM | #27 |
Rep 308
What's with the cryptic answer? Why is the coding so secretive? Where is it "out there"?
2017 F31 328d xDrive
M Sport M Performance |
03-28-2022, 10:21 AM | #28 |
Rep 1,960
I recall finding a post telling how to modify the values of the OEM colors. Additional colors would be added to the same location I'd assume. I'll see if I can find the post and will report back.
Hypermile48.50 coupedream71.00 |
03-28-2022, 10:49 AM | #30 |
Rep 208
I don't code. I did see it on AliExpress a long time ago in pictures of the led kit but I don't know where it's at. It's not secretive. It's out there. Again, I'm not a coder. Steve coded my car for the led lights.
Hypermile48.50 |
03-28-2022, 10:50 AM | #31 |
Rep 208
I bought 5 series ones and trimmed them to fit. It's a lot of work, you have to remove the trim and dremel and glue to fit the led strip. Then I used wire ties and glue to fit the blue trim back in place. See pics in above response.
Hypermile48.50 |
03-28-2022, 10:52 AM | #32 |
Rep 308
Thanks for clarifying. I contacted a vendor on Ali WRT coding. I will share the response here.
03-29-2022, 09:18 AM | #33 |
Rep 308
Ok, after some digging, I found the seller who has a pic of the coding that is required to make it work on NBT cars. I don’t have pictures hosting subscription so I’ll post the link here and hopefully someone can post the picture of the coding. Of note, they are using BMWAi to code. https://m.aliexpress.com/item/100500...b2156d9&gclid=
03-29-2022, 09:31 PM | #34 | |
Rep 1,960
https://f15.bimmerpost.com/forums/sh....php?t=1205119 A few color options and links to find colors in RGB and convert to hex from the same post. https://f15.bimmerpost.com/forums/sh...3#post24418293 (post 124) The 3 groups (dash, doors, footwell) you have to worry about from same post. https://f15.bimmerpost.com/forums/sh...1#post24459531 (post 140) This isn't a "how to" for our cars but should get you going in the right direction. Hope this helps. |
Hypermile48.50 |
05-10-2024, 12:29 AM | #35 |
Rep 23
Hello, if anyone needs the coding values for the BMW models with FEM, for example F30/F31....
HU_NBT2 COLOUR_SWITCH — > active BRIGHTNESS_AMBILIGHT — > active ((( COLOUR_SWITCH_ENSEMBLE —> 10 entries ))) And: from colour must be change from default to Licht apparently 11 entries do not work, and the function disappears in the I drive again FEM CS_TYPE two_colours PIA_DEFAULT_CD Change to color_2 MAPPING_LCI_7_FUNCTION Change to cs_2 Regards Last edited by Persian; 05-10-2024 at 09:29 AM.. |
