06-14-2017, 05:13 PM | #45 |
Rep 11
Drives: 2023 Brooklyn Grey M4 Manual
I have a 2012 F30, and I noticed the same cold start smoking issue around 45K miles and under warranty. At first, the smoke was only noticeable after it was sitting for about a week. After I started noticing the smoke after it was sitting for a day or 2, I finally brought it in at around 48K miles for this issue, and after a Puma case, the dealer was instructed by BMW NA to replace the old feed pipe. After pipe was replaced, the smoking was gone... or so I thought.
Around 52K miles, I again started noticing the smoke after the car had been sitting for 3-5 days (my wife works from home, so both cars aren't driven daily). I brought it back to the dealer since the issue had returned even though the warranty was up. The dealer stated that they could not reproduce the issue even after the car had been sitting up to 3 days (which I do not believe). You almost have to have someone else start the car, because the smoking is usually immediate and you might miss it if you don't look immediately after start-up. Anyway, I'm at around 60K miles now and the smoke is now there after sitting overnight. I brought it to another BMW dealer who was able to reproduce the smoke, and they deduced that the bearings inside the turbo was bad, leading to a mixture of oil and antifreeze to seep in. I did purchase an extended warranty with Warranty Solutions through the previous BMW dealer, and luckily, they authorized the turbo replacement. I did have to come out of pocket $100 for the deductible as well as ~$200 in hoses and clamps that were not covered. I paid about $2,700 for the 4 star coverage from Warranty Solutions, and in hindsight, it was well worth it, as the turbo replacement would have been easily a $4K repair out of pocket. On a side note, the dealer also discovered a cracked gasket in the engine compartment causing some oil leakage, which Warranty Solutions covered as well. It is my opinion that the turbo should have been replaced to begin with by BMW under warranty in addition to the drainage pipe. I was lucky to have purchased an extended warranty that covered the turbo after warranty, and good luck to those out there that are not so lucky. |
bradleyland1506.00 |
06-15-2017, 12:04 AM | #46 |
Rep 308
My 2012 f30 did this for long time. But then i cant talk to bmw about it since i have hfc haha
And now its out of warranty. Even if they had recall, i dont know if they would do anything because of my hfc. Just changed engine oil after 4000 miles and oil is so damn black. Either something wrong with engine or bmw used crap oil last time they did. |
06-15-2017, 02:53 PM | #47 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
06-15-2017, 09:09 PM | #49 |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
I wouldn't let it go too long. Oil leaks in to the compressor housing, and is sucked in to the engine on startup. That coats your intake with oil, including your intake valves. As your intake valves get hot, that oil will carbonize, and next thing you know, your fuel economy starts to suffer, and you'll need an intake port cleaning to add to your turbocharger replacement bill.
08-10-2017, 01:31 PM | #50 |
Rep 4
Anyone taken this problem to an Indy shop out of warranty? How much is it going to run me? I have a 2013 328i 70k kms and it's starting the smoke after sitting 12 hours.
Thanks, Nik |
09-26-2017, 01:46 PM | #51 |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Some updated info for anyone tracking this thread. I just received a letter today indicating that BMW has extended the warranty on the "Engine Oil Feed Line" to 10 years / 120,000 miles for our N20 equipped 2013 X3 28i. What's frustrating is that there is no mention of the turbocharger itself.
I found a pretty interesting blog post by a BMW technician that explains why this is so frustrating: https://bmwtechnician.com/2016/05/16/n20-turbo-update/ If you check the comments, you'll note that the technician remarks that it's a 50% chance that the engine oil feed line will actually fix the smoking issue. While I appreciate BMW's acknowledgement of the issue, this is a half-measure. We deserve warranty protection from the entire fault, not just the less expensive component.
09-26-2017, 02:47 PM | #52 | |
Rep 308
Is something like this covered under CPO?
I really want to take it in for a check but since i have a HFC, im scared that they will just make excuses like HfC is the problem LoL. Quote:
09-26-2017, 03:23 PM | #53 |
Rep 43
So after I bought my CPO 2013 BMW 320i with 30k miles on it. For a few days I didn't drive it and white smoke would come out of it when I would turn it on. So the next day I turned it on no smoke. So hmm..Leave it to sit for a few days again BAM white smoke again. This was like a week or two after I bought it. Literally drove like 50-100 miles maybe. I took it in explained what I read on the forum. What do you know they called me today "Turbo Oil Line Leaking"..I'm pissed because they didn't know this when they fucking certified this car. The dealer said they run a car through a bunch of test before being certifying..
ANYWAYS they fixed everything for free under CPO all I had to pay was 50$ for some b.s cpo fee. everything is running perfect |
09-26-2017, 08:34 PM | #54 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Given the close relationship between the turbocharger and the downpipe/HFC, I'd probably put the stock one back on before taking it in. No way I'd risk a several-thousand dollar repair getting flagged as denied over an HFC. If you do take it in with the HFC installed, be sure to read up on Magnuson-Moss before you go in, so you'll know the magic phrases to let them know you won't be dicked around.
09-26-2017, 08:42 PM | #55 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Still frustrating, and frustrating that BMW aren't covering the full turbocharger under warranty.
09-26-2017, 11:44 PM | #56 |
Rep 464
Could you ask/force your dealer to do a valve walnut blasting? Since the car technically burns oil because of a warranty issue, shouldnt they be cleaning the mess (although walnut blasting is not needed, its a good thing to do)?
09-27-2017, 09:13 AM | #57 | |
Rep 43
09-27-2017, 11:26 AM | #58 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Although, pulling the intake and having a look is really the only way to say for sure. It's always surprising to me how reality fails to meet expectations. I've pulled apart motors that I would have sworn would be a mess on the inside, only to find they're practically spotless. You just never know until you look.
09-27-2017, 01:39 PM | #59 |
Rep 464
Did they replace oil line feed or something to do with the turbo? I have an appt next month but my car only does it after sitting for 6-7days. So not sure how to prove it to them, I have a video recorded of my car however, and i made sure to film the current miles, and my licence plate to have proof of the situation. Do you think they would approve warranty work this way?
09-27-2017, 02:38 PM | #60 | |
Rep 43
09-27-2017, 07:51 PM | #61 | |
Rep 464
09-28-2017, 09:30 AM | #62 | |
Rep 43
09-28-2017, 11:34 AM | #63 |
Rep 308
Yes! I have cpo warranty until next year!
I do have to pay $60 deductible. What should i do with the hfc.. I installed it myself with a friend before and it was a pain.. |
09-28-2017, 11:54 AM | #64 | ||
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Also, if I could ask a favor of you, that'd be cool. These kinds of threads — i.e., "will BMW deny my warranty claim because of X" — tend to get mired down in the same old disagreements. The risk evaluation is up to you, but I'm going to give it to you straight: the downpipe is directly attached to the turbocharger, and BMW routinely denies drivetrain warranty claims for downpipe modifications. See quote below: Quote:
The favor I'd ask is that this thread not get turned into another one of these arguments over whether or not BMW will deny/admit your warranty claim. The information is already out there. Please go check it out
09-28-2017, 12:37 PM | #65 |
Rep 43
Just replace everything back to stock! You'll be fine if you have warranty. Just to be on the safe side.
09-28-2017, 01:53 PM | #66 |
Rep 308
Thanks guys. I will have to go back to stock
Just a last question, HFC has nothing to do with white smoke? I cant remember if white cloud happened before swapping to hfc 🤔 haha |
