01-13-2022, 06:25 AM | #67 |
Rep 1
Hi there , im new here , i have a f34 330d xdrive and i would like to upgrade the wheels from 19x8 front and 19x8,5 back with 20x8,5 front and 20x9 back , any advice on what tires i sould get to not mess up the xdrive system?
01-13-2022, 10:49 AM | #68 |
Rep 4,512
235/35/20(26.5"), 275/30/20(26.5")
235/35/20, 265/35/20(26.3"), 0.8% difference 225/35/20(26.3"), 255/30/20(26.1"), 0.4% |
RobertMarian0.00 |
01-13-2022, 11:07 AM | #69 | |
Rep 2,157
11-27-2022, 08:25 PM | #70 | ||
Rep 914
This quote is from the E83/53 xDrive training document. That chassis uses an older ATC 400/500 transfer case. The F3x transfer case is a newer ATC 35L unit. Aside from both being chain-driven TCs, I'm not sure where the similarities end.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
07-31-2023, 11:26 AM | #71 |
Rep 31
Drives: 20 440i xDrive GC,sc300 TURBO
Again sorry to revive a old thread
im looking to replace my 225/45/18 square setup with a 245/40/18 and car is xdrive so trying to match up a spare tire kit since ill be taking off the run flats and closest ive found is with 1.2%. only time i would be running that spare is if a tire goes out. so for a short time i would be on it would it ruin the system?
2020 440xi Gran Coupe ///M Sport B39 Mineral Grey Metallic
Kyostar Intake | CTS Charge Pipes | BM3 Stg 2 | XHP Stg 3 | RVG DP | H&R Springs | |
07-31-2023, 12:38 PM | #72 | |
Rep 957
PeteyF3636.00 |
07-31-2023, 12:39 PM | #73 |
Rep 31
visionaut
thanks so much
11-28-2023, 09:42 AM | #74 |
Rep 4
Drives: bmw 320i msport x drive
tyres
how would 245/35/20 and 275/30/20 fear on the x drive?
11-28-2023, 03:17 PM | #75 |
Rep 957
stevegwill6000.00 |
11-29-2023, 12:55 AM | #76 |
Rep 4
03-08-2024, 12:19 PM | #77 | |
Rep 358
For years I ran 225/35/20 and 255/30/20. P Zeor. rears worse nearly x3 faster than rears. Brutal, they were cheaper then they shot to 700$ a rear. 2017 grew up and went 19, with Japanese rays. Tried: 235/40/19 275/35/19 PS4S. 35,000kms brilliant! Ceramic rotors helped make it even more fun by dropping 30 lbs unsprung mass. 2021 MICHELIN PS4S Set #2. 225/40/19 265/35/19 Bubble defect, warranty swap to same. 235 wore the Dinan spring on one side, presumably backing up in my driveway. 19,000 kms on set #3. Meanwhile, Dec 2023, nearly losing the car with new X Ice snow- brand new, hardened after 3,000 kms on our first snow- Michelin. tested them on compact slush-the blocks hard, do nto open roll and slush over, no longer bite. What happened? Michelin is now garbage and ditched by connoisseurs I know- cracks, bubbles, hardened compound. What happened is Michelin introduced a new polymer for longevity- a plastic- on all its models without changing names. At 6/32, the 2022 PS4S skids at 15C, hot to night chill thud thud thud for 15-20 kms, plastic deformation. Dec 2023, after the X Ice snow incident, Michelin recalled and bought me a new Hakkappellitta R5 winter set, mor eexpensive, direct JP Morgan deposit, brilliant on the 3,600 lbs car. Have the PS4S now, 6/32, atrociosu noise and hardened plastic compound! Last season three Michelin Power Cup cycling tires failed on me, got refunded, no accident, my mom's AS 3+ hardned up after 5,000 kms, DONE WITH MICHELIN. I do not care about 60,000 km treadwear if they lose grip or thud like Kumho Koreans! T Case- replaced 2021- 7000$. The culprit was me having fun, two dozen launch controls, the part shot up from 800$ to 5000$. Now, with Bilstein B6, new HRE sway bars (Thanks Farkle), the car is better than it ever was new. As my PS4S are due in 2 months, going to Continental Extreme Sport 02. Reminder, my base stock TC program is 225/35/20 and 255/30/20. So I will go for 225/40/19 Conti or 235/40/19 Conti S02 Rear: 265/40/19 Conti S02 (-0.4%) or 275/35/19 Conti S02 (+0.8%) All are within the 2014 Stock 2%. Hope for even wear. |
03-08-2024, 12:36 PM | #78 | |
Rep 417
BMW must think that is OK for the long term so you are fine |
