03-14-2016, 09:57 PM | #67 |
Resident BMW Fanboy
259
Rep 866
Control arm bushings?
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
03-15-2016, 04:39 PM | #68 |
Rep 96
2013 BMW 328i. 72k miles so far. Only issue would be the seat belt sensor is malfunctioning on the passenger side. Nothing major.
2022 M3 COMPETITION SKYSCRAPER GREY
09-19-2016, 12:50 PM | #70 |
Rep 275
09-20-2016, 12:45 PM | #71 |
Rep 3
2012 F30 335i Sport with 57,xxx miles.
So far outside of standard services I've had, -Camera Malfunction, all Cameras. They flashed the firmware of the controller to a newer version which didn't fix the issue. Then they stated replacing wiring harnesses until they couldn't replicate the issue anymore. Problem solved. -CIC Controller replacement. Paint had rubbed off the media button. -Radio buttons replaced. Cracked paint. -HUD glass vibrating. -CIC screen flexing making plastic cracking noises. -Gas cap lock not functioning properly (Would "lock" but wouldn't actually extend the locking bar). -Oil filter housing leaking oil. Replaced the Gasket. -Drivetrain malfunction. Ended up being a failed fuel rail sensor needing to be replaced. So far that's it. Every single one of the above was covered by BMW under warranty. |
09-23-2016, 06:25 PM | #72 |
Rep 9
2013 Sportline 328i
81,000mi Nothing so far outside factory warranty, although I did purchase 100k extended for $4K and might not pay for itself. Timing chain and oil pump chain so far no whining or noise. Changing oil every 7.5k Mobil One with OEM filter. At 85K will be doing tranny pan fluid replace (about 3l out of 7) Will plan on keeping car hopefully to 150k. |
09-26-2016, 04:51 AM | #73 |
Rep 700
2014 328d
56k(roughly) NOx sensor at purchase Front brakes replaced under warranty at 45k Had the pinch sensors in the front windows malfunction, reflashed computer at dealer, problem solved. Engine seems to "miss" at cold start during winter, dealer said it was nothing out of the usual, could be lower grade diesel used in winter, gonna look at using dieselkleen this winter to see if the problem comes back. Currently have a front wheel bearing that seems to be going out, will get it looked at on next service. Nothing else out of the usual aside from regular maintenance otherwise. I was going to see about trading it in next spring, but thanks to VW, I'm probably better off keeping it with how fast it's depreciating. |
09-26-2016, 09:58 AM | #75 |
Rep 129
I had this too. When I replaced my under seat woofers, I saw that the wiring loom was cut on the passenger seat. Must have been a error in the production run. My car is also a 2013. I bought the car new, so there's no way this happened after I picked up the car.
09-26-2016, 10:42 AM | #76 |
Rep 94
My 2013 328 also has a weird issue with the passenger seat belt sensor. If I place anything on the seat, even my cell phone, the seat belt indicator will go on. Hahaha, pretty annoying after being tired from a long day, throwing my phone on the seat, then the indicator going off a few minutes after. I pick the phone up and the indicator turns off.
I never replaced my subwoofers but did install a trunk subwoofer and an amp. I think the indicator started tripping out after the stereo upgrades. I wonder if the extra bass in the car messed with the indicator's sensitivity. |
09-26-2016, 09:11 PM | #77 | |
Rep 62
That rattle on the drivers side dash is driving me crazy... how did you fix it from the AC vent? |
09-26-2016, 10:10 PM | #78 | |
Rep 57
It drove me nuts but so far I haven't heard it for a while. I just applied some foam strips to it last time. Maybe it's from my head up display or gauge. |
09-28-2016, 08:31 PM | #79 |
Rep 2,446
Drives: 2022 M3 6MT
65k on my 2014 328 xdrive. No issues at all so far.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
09-29-2016, 07:27 AM | #80 | ||
Rep 62
12-21-2016, 10:23 AM | #82 | |
Bimmer Fanatic
37
Rep 82
It's driving me nuts. To me it sounds like struts/shocks and mounts, dealer says it's VSS and says it's normal. |
12-21-2016, 01:14 PM | #83 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
11K miles...zero issues, one oil change (another coming up) 2015 F36.......
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
12-21-2016, 02:47 PM | #84 | |
Rep 205
http://f30.bimmerpost.com/forums/sho....php?t=1267119 |
12-21-2016, 06:53 PM | #85 |
Rep 15
Drives: 2014 335i xdrive 8at
2014 335i, Drivetrain malfunction at approx 27000 miles.
Very excessive soot on tail pipes, pronounced engine bucking, engine would stall. Cause: Bad injector. Remedy: BMW replaced 1 bad injector and 1 fouled plug. All good for 5 days then same problem, even more severe this time. Cause: 2 bad injectors, don't recall the cylinder numbers I'd have to look at the paper work. Remedy: BMW replace the 5 injectors remaining and 5 plugs. All good from then on, at 31,000 miles now. Always run Shell V Power 93 octane. I drive in sport mode / manual mode 95 % of the time, 90 percent highway time at 65-75 mph. Some fair amount of spirited driving as well. Wondering if I should anticipate this cropping up in another 25,000 miles.
Sort of like Mark Twain’s story…when he was fifteen he was surprised that his father had been able to live so long, considering how little he knew.
12-21-2016, 07:00 PM | #86 |
Rep 142
2013 335ix
47k miles, recently my electric fan was found faulty. Couldn't produce power past 3k rpm. Took to dealer and was replaced under factory warranty. Coolant hose going from expansion tank to upper radiator was brittle and broke cause of electric fan - also replaced under warranty. |
12-21-2016, 07:36 PM | #87 |
Rep 1,486
94k. The f30 is one of the most reliable bmw product launches ever. Every other generation was riddled with widespread failures. Really only the common thing with f30 is the oil filter housing. The n20 timing chain is there but lessr frequent
12-26-2016, 08:09 PM | #88 | |
Bimmer Fanatic
37
Rep 82
