10-18-2018, 07:19 PM | #67 | ||
M3MBER
77
Rep 129
Drives: F80 M3 -Yas Marina/Silverstone
Or does the mapping force it to be one or the other (blinkers or DRL). Not both? If anyone knows how to keep both so they are always on, let me know! Thanks
2015///M3|Yas Marina Blue|Silverstone|
12-11-2018, 09:58 PM | #69 | |
Rep 1
Coding this using Bimmercode
Which platform did you use to do this? I've been trying to find these fields in Bimmercode and having issues. |
12-22-2018, 04:34 PM | #70 | |
Rep 1
Be careful make sure you double check or even triple check your values. I messed up the first time and my tail lights were all messed up. If you have any questions message me on Instagram (@maustax) I’m not on these forums often this is my first reply ever lol. Hopefully everything will work for you! |
02-05-2019, 07:45 AM | #72 |
Rep 41
02-05-2019, 07:47 AM | #73 |
Rep 41
I also need help!
So I did it all and it worked, but now, theirs a different problem. Can I turn the blinker lights to brake lights? I've tried messing with it and couldn't figure it out. BMW 328I 2015.
02-06-2019, 07:34 AM | #74 |
Rep 13
02-06-2019, 07:59 AM | #75 |
Rep 41
I don't know if you have done this, but click into each ecu in expert mode, then search. without clicking anything else. none of the numbered ones. BTW, if you wanna a fast reply, I sent you my number in PM.
03-26-2019, 06:16 PM | #76 | |
Rep 146
Hi,
Great work guys. Is this possible on F25/26 X3/X4 as there is no REM ecu? Cheerz Quote:
04-22-2019, 12:06 AM | #77 |
Rep 10
Rear led brightness coding
Hi all,
Would it be possible to code the Rear led bar brightness ? I coded the rear led bar to work as turn signal, it needs to be brighter though. Anyone can help? |
05-02-2019, 10:07 AM | #78 |
Rep 89
Just did mine, thanks! Is there no way to use the rear light bars as DRL as well as it being the turn signal light? I really like the look of the rear light when I had it as a DRL! But it seems like we can't have both?
Here' a quick video of mine:
My Instagram
Alpine White '14 BMW 320i 6-Speed MT: GSR Tuned, H&R Sport Springs, Injen CAI, Borla catback exhaust, ER FMIC/Chargepipe/Downpipe, VMR V810 wheels |
06-09-2019, 01:36 PM | #79 | |
Rep 14
Nitrof23MT0.00 |
06-09-2019, 01:57 PM | #80 |
Rep 14
I think it is possible when you code the inner lights as DRL and outer lights as turn signal
07-06-2019, 08:57 PM | #81 |
TeQuiero
89
Rep 424
Hey everyone-
With the light bars acting as the turn signal, is there a way to still retain its original DRL function? So basically, ideal goal is: DRL stays on, and when blinker turns on, it'll blink while the other side stays on. |
07-08-2019, 11:57 AM | #82 | |
Rep 245
If you follow those parameters exactly, you retain DRL function too. My question is can you increase the intensity of the DRL as during day time they are dim |
07-09-2019, 11:58 PM | #83 |
Rep 146
Hi,
I coded my sons 2014 F30 328i as per post # 58 but as we didn't get the results my son thought we would see, I restored the file I'd saved before making changes. I restored the previously saved file, the rear lights behave as before but the side mirror turn indicators aren't functioning correctly. After restoring, I locked the car and let it sit for 30 minutes or so. then used the remote to open car and the mirror turn indicators function correctly but then they won't come on again, whether using the turn stalk, hazrd light or locking the car. On further investigation, it seems that the mirror turn indicators work if you only OPEN or LOCK the car, as soon as you flick the turn indicator stalk to turn left or right or press hazard light switch, the mirror indicators are deactivated and no longer flash even when opening or locking the car. Sounds like PRIORITY settings are out of wak. Any idea on where I can check the settings? Cheerz : Last edited by daMANiack; 07-10-2019 at 02:40 AM.. |
08-17-2019, 08:48 AM | #84 | |
Rep 93
Thank you for the coding. Nice to know my 2016 is now on par with my 2004 e46 when it comes to LED technology lol |
09-09-2019, 03:11 PM | #86 |
Rep 7
bit late... and i know I'm reviving an old thread but how does anyone get the rear led bars to stay on all the time with DRL, like the halos, but also flash with the turn signals. i am trying to do it on an M240i LCi and it blinks in every mode, but they are only permanently on when its dark or the switch is on position 3 (side/parking light's)
09-09-2019, 03:14 PM | #87 | |
Rep 7
Are your tail light bars on ALL the time as well as flashing when indicating? |
09-09-2019, 04:06 PM | #88 | |
Rep 1,508
I really doubt that these values would work on an LCI 4 series. I went through the process to activate rear fog lights on my USA car. The values for the 3 series don't work on my 2019 F32. |
