06-07-2019, 04:05 PM | #68 |
Rep 1,433
OP reporting in...
I've had the Akebonos installed for a few hundred miles now. I'm very happy with the results. My primary objective was to reduce brake dust, without squeal or performance compromise. The brake dust is significantly reduced. I have zero squeal. The performance is as good as the OEM, though I haven't had any prolonged spirited drives yet to compare fade.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired Last edited by eleven11; 06-08-2019 at 09:58 AM.. |
mlev371.00 |
11-05-2019, 02:36 PM | #69 |
Rep 445
Reviving an old thread, but I bought a set of these to replace the powerstop z23's I have on my m235. Im hoping these dont shift as much front to back after going from drive to reverse and vice versa, the powerstops have gotten really bad on the drivers side. Hope to install them tomorrow.
11-05-2019, 02:59 PM | #70 | |
Rep 266
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
11-05-2019, 03:25 PM | #71 |
Rep 445
11-06-2019, 09:08 AM | #72 | ||
Rep 5,410
Logicoeur993.50 |
11-07-2019, 03:44 PM | #73 | |
Rep 266
2013 F30 335i
11-08-2019, 07:07 AM | #74 |
Rep 445
So far I like them, oddly enough the feel isn't that great with light applications, but the bite is vastly improved. No clunk going from reverse to drive, or at least not loud enough for me to hear it. Still get the grinding noise and inconsistent performance under heavy application on rough roads, as I tried to detail somewhere in my post history. I am almost certain that is suspension related and the brakes are fine though.
11-08-2019, 09:37 AM | #75 | |
Rep 172
11-08-2019, 09:41 AM | #76 | ||
Rep 5,410
11-08-2019, 03:23 PM | #77 | |
Rep 266
2013 F30 335i
11-08-2019, 05:15 PM | #78 | ||
Rep 445
11-13-2019, 03:06 PM | #79 | |
Rep 1,078
11-13-2019, 05:32 PM | #80 | ||
Rep 445
11-13-2019, 05:40 PM | #81 | |
Rep 552
Otherwise, put on new Zimmermann rotors and Akebono pads and you will not hear it squeal ever again. I'm experienced in this issue and it was torture having super loud squealing breaks all the time. |
mikeyymonster526.00 |
11-13-2019, 05:49 PM | #82 | |
Rep 1,078
mlev371.00 |
11-13-2019, 06:04 PM | #83 |
Rep 1,078
11-13-2019, 10:06 PM | #84 | ||
Rep 552
I had a cheap pair from r1 concepts that had an ear piercing squealing issue when cold. I cringed every time I had to brake near someone walking by. I could not fix it and it got worse over time. I think the cheaper pads are definitely more prone to it. |
08-20-2020, 11:45 AM | #85 |
Rep 522
Everyone still enjoying their Akebono pads?
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
08-20-2020, 11:54 AM | #86 |
Rep 266
I'm still enjoying them, my only gripe is they squeak pretty bad when coming to a stop once they're warmed up a bit. Others on here have said they don't squeak at all so I'm wondering if I need to just apply some more brake quiet to the backs of the pads - just haven't had time to get around to it yet. Put about 5,000 miles on them so far
2013 F30 335i
pauli18c212.00 |
08-20-2020, 12:22 PM | #87 |
Rep 1,934
No squeaking, about to be a year of use on stock 335i brakes. In the midst of upgrading to 345mm rears, New rotors all around ( Platz1 340mm floating for the front, R1 Concepts 345mm with aluminum hats in the rear). Purchasing akebono for the new rears as well. Undecided about braided lines, but since I need a brake fluid flush anyway I may add them just because.
pauli18c212.00 |
