06-11-2018, 11:47 AM | #111 | |
Rep 41,181
06-11-2018, 11:55 AM | #112 |
Rep 46
I have done that, but the error is there anyway:
select Read VIN from FA button, then select Read VIN, then select HU_..... -> blflash, swdeploy, cddeploy and ibadeploy. then "check software avaliability, then start. |
06-11-2018, 11:58 AM | #113 |
Rep 41,181
Do it again, and keep messing with it until it works. It is VIN issue. I've seen it a hundred times, and everyone always claims that they do it right and it not work, but eventually they get it to work.
06-11-2018, 12:17 PM | #114 |
Rep 46
Maybe it's relevant to mention that I updated FW on FEM_GW the other day before I tried to update HU_ENTRYNAV, it seams to be succeded.
Could there be a failure here ? The car runs fine, but the HU does not Work. I have also tried to do the following: Select Read VIN from FA button, then select Read VIN (VIN okay), select Read VIN from FA button again, and then select HU_..... -> blflash, swdeploy, cddeploy and ibadeploy. then "check software avaliability, then start (no error messages). After about 35 minutes I stopped the flash, but is 35 min not enough ? |
06-11-2018, 12:25 PM | #115 | |
Rep 41,181
As for flashing, Head Unit can take up to an hour. You should not be stopping Flash. It should run its course to the end, either succeeding or failing.
06-11-2018, 03:33 PM | #116 |
Rep 46
I will try tomorrow again, and I will take the time it needs to finish with success or error.
Thanks a lot for your help so far. By the way, I use E-Sys version 3.27.1 and v.4.10.30_PSdZData_Full Do they fit together, or should I use a newer version of E-Sys ? |
06-11-2018, 03:36 PM | #117 |
Rep 41,181
Yes, software is fine.
06-12-2018, 06:53 AM | #119 |
Rep 41,181
No.
06-12-2018, 11:25 AM | #120 |
Rep 46
I tried Again (this time with the car started, I don't know if my charger (25A) could hold more than an hour):
First a got an error: [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: Service TD returned a negative response with response code securityAccessDenied; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "31min 55s". [C206] Then I startet all over and got a new error: TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2018/06/12-17:44:16.498 [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] negative response error: code: cancel ecu requires finalize description: T2 timeout on Service RDBI_ADS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] negative response error: code: cancel ecu requires finalize description: T2 timeout on Service RDBI_ADS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [] - [Exception - HU_ENTRYNAV - 63] negative response error: code: cancel ecu requires finalize description: T2 timeout on Service RDBI_ADS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "11min 35s". [C206] |
06-12-2018, 11:58 AM | #121 |
Rep 46
Now I'm not sure if I do it correct, what I do is, my car is F30 LCI:
1 Launch E-Sys via free ESysLauncherPremium 2.8.0_Build_143 2 Connect to car Project=F020 ... (not direct), use connection via Gateway (Should I use VIN?) 3 Comfort mode, TAL Calculating 4 Read and save FA 5 Activate FA 6 Read and save SVT-Actual (SVT_ist) 7 Edit SVT_ist as you described 8 Create SVT Target (Complete Flash, I-Step shipment F020-15-07-504) 9 Do KIS/SVT Target Calc and save as SVT_soll 10 Do TAL Calc and save as SVT_tal 11 Expert Mode - TAL-Processing 12 Load SVT_tal 13 Load SVT_soll 14 Read FA (FA_aus_VCM 15 Check read VIN out of FA, and click Read VIN 16 uncheck all, and select HU_ENTRYNAV (blFlash, swDeploy, cdDeploy and ibaDeploy) 17 Check software avalability (All software units (SWE) are avaliable) 18 Press Start |
06-12-2018, 12:00 PM | #122 |
Rep 41,181
Yes.
06-12-2018, 12:17 PM | #124 |
Rep 41,181
Yes, assuming you have an ENET Cable and not ICOM Interface.
06-13-2018, 12:23 PM | #126 |
Rep 46
Hi Again,
I tried today with connection as VIN and not Gateway. I got errors: TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2018/06/13-17:05:52.995 [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR [] - [Exception - HU_ENTRYNAV - 63] job failed with negative response error: code: repeat job description: transfer data repetition counter exceeded; LinkName: HU_ENTRYNAV_63_ETHERNET_63 severity: ERROR TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "36min 24s". [C206] Hmm, I looked at repetition could be to many resending errors I thought, and that could be a bad connection. I then tried to change the RJ-45 cable to at high grade Cat.6 cable, and hurraaaa, it finished successfully in 21 minutes. Thanks a lot for your help Shawn, I'm really really happy about your skills and that you used time on me. Thanks Again Shawn, you simply rescued my car, and made me very happy. |
06-13-2018, 12:26 PM | #127 |
Rep 46
Hi Again, forgot.
Should I always use connect via VIN, or should I use gateway when I flash FEM_GW ? I have learned a lot, but want just to be sure Thanks again |
06-13-2018, 12:47 PM | #128 | |
Rep 41,181
07-03-2018, 12:41 PM | #129 | |
Rep 9
08-12-2018, 01:36 PM | #131 |
Rep 41,181
PM sent.
