05-11-2015, 12:50 PM | #155 | |
Rep 397
Appreciate the detail information. NEXT, do a pair of the LCI DRLs
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
05-11-2015, 02:51 PM | #156 | |
Rep 1,035
You sure you want to go over this cliff, bro? Packages from Amazon, Ebay, TRS, and everywhere else will start showing up daily, every last inch of available space on your countertops will start disappearing, your wife will constantly be rolling her eyes at you, your free time will start evaporating, your friends will start sending APB's out on you, and your pic might even start showing up on milk cartons. Last warning, because there's no turning back if you do ... |
gregtaylor160.00 |
05-11-2015, 05:25 PM | #157 | |
Rep 397
How long did it take you to just open the headlights. I will want to have my weekends. Maybe I will just stick with the Eagles eyes to retrofit the HIDs projectors and take out the Halogens. Really like how these look though, hopefully get some LCIs as well like blueaudi's prototype.
05-21-2015, 10:38 PM | #159 |
Rep 1,035
F30 Quad BiX - mini-H1 projs + 35w ballasts/6000k Xenon HIDs + DTM 7000k Corona Rings
Just a rough mock-up of the quad bi-x setup testing out alignment and low-beam/high-beam functionality. Nothing is secured, and lens is off.
Cutoff beam alignment on quads is a bitch ... and this is only one headlight.. Here is a short clip going from 4 low-beam projectors to 4 high-beam projectors (activating all 4 solenoids simultaneously to drop the shutters): Last edited by squidlyboy; 06-08-2015 at 08:41 PM.. |
gregtaylor160.00 |
05-22-2015, 10:10 PM | #160 |
Rep 60
That looks sick..awesome job "squidlyboy"
If anyone is interested, the retrofit source is having a sale site wide... 15% off for memorial day. code: "Remember15" |
05-23-2015, 05:59 AM | #162 | |
Rep 1,035
I simulated two blown LEDs in the top pic using some black cardboard bits to cover up one on each side, then removed the cardboard in the bottom pic. Its really hard to tell if you're not looking for them, and if you are looking for them, its still hard to tell The third pic shows the "blown" LEDs without the acrylic on it. The magic of using etched acrylic - credit Beinarcis for that. He told me early on that it just looks cooler etched because leaving the rough cut resembled the E39 look. I agreed. But it also has some other useful features Speaking of which ... i'm a little worried about the option Mike over at Extreme Powerhouse is giving people over in the other thread to get the non-etched acrylics for their halogen angle eye retrofit. Blown LEDs are gonna be a LOT more visible if you can see each individual LED in the clear (non-etched) acrylic. Thanks for asking |
gregtaylor160.00 |
05-23-2015, 07:23 AM | #163 |
Rep 60
Need an opinion.
Option 1: 2 sets of projectors from iJDMTOY 2 sets of MORIMOTO ELITE HID SYSTEM Option 2 2 sets BI-XENON MORIMOTO MINI STAGE III (H1) Option one will be less expensive than option 2. Do you think I will have any problems if I use the iJDMTOY projectors with Moromito HID ? Thanks |
05-23-2015, 08:58 AM | #164 |
Rep 1,035
I agonized over this same decision - but it wasn't exactly like your situation:
morimoto mini stage iii (h1) vsijdm (mini-H1) projectors + morimoto elite hid (35w/50w ballast+xenon 4500k/5500k/6500k HID bulbs). But it was very similar. For me it was between: morimoto mini stage iii (h1) vsgeneric mini-H1 projectors + generic 35w ballast/xenon 6000k HID from amazon. I spoke with TRS and asked them what the quality difference was between their $540 (for two pairs) mini stage iii (mini H1 projectors/xenon HIDs/ballasts) versus generic mini H1's/35w ballasts/xenons (~$140 for 2 pairs). TRS showed me a picture that showed the sharpness of their cutoff beam compared to the sharpness of a generic mini H1 and it was noticeable. They said they tune their lens to provide the sharpest cutoff. So i had to decide whether the $400 difference for the pair was worth having a sharper cutoff compared to a little bit more of a blurrier cutoff. In the end, i figured that you aren't buying these things to have a cutoff sharpness contest against a garage wall. First and foremost, you are buying xenons/HIDs to give you more/brighter output on the road so that you can see better. And compared to halogens, its a night and day 3x difference. And when the light shines on the road, sharper/blurrier cutoff is not something you are really going to be able to see anyways when you are driving. Its the output lumens that's important. The ironic thing is that when these generic mini H1's arrived, the cutoff was just as sharp as the morimoto ones i saw in the picture he showed me So back to your question... So my projectors and my xenon bulbs/ballasts are not "matched" by any means. And i haven't had any issues by buying the projectors and xenon bulbs/ballasts separately. They fit and work together great, and there's going to be manual adjustment of all the lights anyways to make them align properly. Bienarcis mentioned to me in an earlier conversations that his iJDM mini H1 projector bowls were a little more thinner oval shaped than the morimoto mini H1 projector bowls, but otherwise worked. If he's around i'm sure he'll have more info/details on that. But the way i see it, there's going to be a lot of custom cutting to make ANY set of mini H1 projectors fit in F30 headlight housings regardless of which one you go with Last edited by squidlyboy; 05-24-2015 at 01:06 PM.. |
gregtaylor160.00 |
05-23-2015, 07:05 PM | #166 | |
Rep 1,035
Paying someone will probably take you (and this is just a wild a** guess on my part) anywhere from $2k - $4k But you saw bienarcis post on his part list cost itemization. I'm doing mine for about $270 sourcing all the parts which includes:
Its not the parts that makes it expensive, but the labor, skill, and dealing with the fact that BMW made sure that their halogen's were designed to be the most bi-xenon-retrofit unfriendly headlight housings ever made in the history of cars Last edited by squidlyboy; 05-25-2015 at 11:26 AM.. |
05-25-2015, 11:04 AM | #167 | |
Rep 60
Thank you for all the info. I just bought the iJDM and the HID separately.. Time to have some fun now.... |
05-28-2015, 04:18 PM | #169 |
Rep 62
damn... I've been gone for a minute lol!!
sorry guys i've got myself a part time job so with that on top of school, I don't think I can make anymore lights for those who have been requesting. If I find some spare time then I definitely will try but for now... enjoy this! The rest is still being written. I will try to finish them as promised
2015 F10 M5
2014 F30 328i 2001 E39 530i (sold) |
05-28-2015, 04:19 PM | #170 |
Rep 62
squidlyboy damn bro those lights are looking fresh!!!!! hahaha I bet you'll finish yours before I do!
2015 F10 M5
05-28-2015, 10:32 PM | #171 | |
Rep 1,035
05-28-2015, 11:35 PM | #172 | |
Rep 62
2015 F10 M5
05-28-2015, 11:40 PM | #173 |
Rep 62
for the DIY'ers: here's the DIY for making the acrylic and attaching them to the LEDs. Let me know what you guys think.
https://docs.google.com/document/d/1...it?usp=sharing I will attach the disassembly video and this google doc link to the first page as well. The rest of the DIY is still in progress guys. Sorry for making you guys wait so long. I will try to get it out soon!
2015 F10 M5
05-29-2015, 05:34 AM | #174 |
Rep 616
You guy are good but this is way to much work for me to undertake so I got in touch with a guy called Wouter over in the Netherlands who will take apart the lights fit some projectors and rings and send the lights back for 440 euros (480ish USD/315ish GBP)
I'm in the UK so this is ideal for me as they will fit RHD projectors and everywhere I've looked only do LHD, even RHD Eagle Eyes are like gold dust and look nasty IMHO. The company is www.retrofitlab.com and Wouters email address is info@retrofitlab.com, ive got everything i need to send him except a headlight and as soon as i have this off they'll go. bienarcis makes taking the headlight look really easy in his vid but reading others experiences of doing this I don't think its as easy. The one real worry I do have is the reliability of the LEDs on the rings, I remember when I fitted CCFLs to my E46 years ago I had to replace the rings at least twice because they blew. As you all know the lights on the E46 just clipped together so doing this wasn't a big deal but on the F30 doing this is going to be a complete nightmare. |
05-29-2015, 07:46 AM | #175 |
Rep 60
bienarcis thank you for the disassembly video...that helped a lot... man this is going to be a lot of work . I just got my 4 projectors, and the 4 morimoto elite HID lights.... Can you or squidlyboy help me wt a wire diagram please ..thanks .... squidlyboy that looks sick
05-30-2015, 01:42 AM | #176 |
Rep 1,035
F30 Halogen Headlight Wiring Diagram for Quad Bi-X Setup
Disclaimer: What you do with this information is up to you. I am in no way responsible for what happens to your headlights or car. This is the way i plan on hooking up my lights, but it doesn't mean you should also. Check the information and verify it to your satisfaction before wiring up anything
Here is the Wiring Diagram for retrofitting a single BMW F30 halogen headlight for two Mini-H1 projectors / 35w Ballasts + 2 DTM-style Corona LED rings. You will be duplicating this for both headlights, so it will result in a quad bi-xenon setup. All the OEM bulbs will be removed with the exception of the turn-signal/side marker bulb. This means low-beam, high-beam, DRL, and parking lamp bulbs - all gone. The two pics below are of the headlight connector going into the passenger (right) side headlight. The notes below are for a single headlight. But you'll be wiring both headlights the same way. The wiring and connections should be done in the housing as much as possible to provide the cleanest looking solution as possible. Depending on what ballasts you use (slim-line or otherwise), you may or may not be able to stick those inside the headlight housing.
. Last edited by squidlyboy; 06-17-2015 at 02:17 AM.. |
gregtaylor160.00 |
angel eyes, corona, f30, morimoto, projectors |
