06-20-2014, 07:22 AM | #177 | |
Rep 6
Blue Strip Removal
just wanted to know if you managed to posted the process and removal of the blue strip Im very keen to do this on my car Thanks |
06-22-2014, 02:50 AM | #178 |
Rep 1,093
Susbscribing to this thread, since I guess the steps are same for installing other trims as well.
Also let me know if any of you are planning to replace your trim with mperf and looking to sell your trim, if your current trim has red on it (gloss black with red strip or aluminium with red strip). |
07-12-2014, 10:54 PM | #179 |
Rep 2
Almost done !!!
Hey mate I'm getting a full M interior kit with the alcantara steering wheel and gear lever on my luxury line (saddle brown) next Wednesday. Will share to u guys how it looks. Cheers !!
08-28-2014, 02:30 PM | #181 | |
Rep 47
Since my dealer screwed up my order and put burl wood instead of Aluminum Hex, I ordered the CF kit. My car shows up in a week or so, so I'll update this and let you know. A little nerve wracking because I'll probably get my car post-return policy, but I really can't stand wood interiors. |
12-30-2014, 08:53 PM | #185 | |
Rep 577
Edit: got my kit today. It looks amazeballs! So glad I did this. the box is actually quite small. 39" x 14" x 6". So you could take it on a plane as carry on. Installation wise I found the dash components very easy. The door handles on the other hand were tricky, as there is a metal spring catch inside a slot that you have to press with a screw driver at an awkward angle at the bottom and underneath the door handle. Also the clips we're really tight on mine and while getting them off I thought I was going to break one. Managed to avoid that. |
01-10-2015, 01:37 PM | #186 |
Rep 65
Really struggling removing the door handle trim... I was able to remove the drivers side trim but it took a ton of effort. Also, when I put the CF trim on, it didn't seem to sit as flush with the door as the stock trim. Any tips? Did anyone get installed at dealer? If so, how much did they charge for just the door trim?
01-10-2015, 02:50 PM | #187 | |
Rep 577
It's tricky to get the metal tab depressed enough to get the plastic stay passed it. On one handle I just couldn't and ended up bending the metal tab up to the point that the plastic stay got passed it. The plastic stay didn't break, so I got away with it. My door trims are also not as well fitting as the walnut trim was. Before putting on the door trims, run a blunt edge down the door handle rubber/plastic to make sure it is not raised. That seems to help make them match closer and be more flush. Hope that helps. |
02-24-2015, 04:40 PM | #188 | |
Rep 3
Same problem with my kit for a 2014 F32 Did you get a correct part in the meantime ? Complained to my bmw dealer and I'am waiting for an answer now... |
02-25-2015, 07:40 AM | #189 |
Rep 7,010
If they made this kit with the glossy/smooth finish, I'd probably spring for one. As nice as this one looks, I'd prefer the smoother texture.
06-01-2015, 01:52 PM | #190 |
Rep 218
Anyone have this installed in a 4 series? Interested to see how it looks with the accent trim extending to the door in the F30 LCI like it does in the current F32 and F36. Debating on whether it would look better with piano black accent or chrome accent (I think a blue stripe on the doors only wouldn't look great).
08-09-2015, 01:05 PM | #192 |
***** noob
1402
Rep 10,477
Drives: 325xi>M235i>428GCx Mspor
Does the M Perf Trim come with the metal clips or do I need to use the old ones?
The metal clips that attach the pieces Anyone know? |
08-09-2015, 10:09 PM | #193 |
Rep 1,374
Drives: Audi R8 v10 Spyder
It comes with all necessary metal clips pre-fitted.
09-05-2015, 07:35 AM | #194 |
Rep 104
its beautiful
09-09-2015, 05:52 AM | #195 |
Rep 55
Drives: F20 Alpine White M135i
I am thinking about fitting this to my M135i. The one answer I can't seem to find is how does it standard up to daily use. Is it more resistant to scratches compared to say the brushed aluminium, which seems to scratch if you just look at it funny. If and when it does scratch is it as noticeable? It would be greatly appreciated if someone could answer this. I know the kit is different to the F20 but essentially the same materials.
09-09-2015, 06:23 AM | #196 | |
Rep 1,374
I usually lay warm damp towels on top of the alcantara, brush it with a new toothbrush & vacuum any particles. For optimum results use a Alcantara solution & special brush to restore the napp
09-09-2015, 06:48 AM | #197 |
Rep 55
Great thanks for that info.
10-22-2015, 12:44 AM | #198 |
Rep 1,047
