01-15-2020, 11:56 AM | #2113 | ||
Rep 399
If you have been using DET, and now want to use the +12 Cam cable instead, you must change the Gear Selection in Factory settings to Automatic.
01-15-2020, 12:18 PM | #2114 | |
Rep 399
01-15-2020, 02:26 PM | #2115 | |
Rep 93
Thank you! |
01-15-2020, 02:31 PM | #2116 | ||
Rep 117
With my sd625 it works.... |
01-15-2020, 02:35 PM | #2117 |
Rep 44
01-15-2020, 02:50 PM | #2118 |
Rep 93
01-15-2020, 03:51 PM | #2120 |
Rep 43
01-15-2020, 04:16 PM | #2121 | |
Rep 399
I would contact the seller with this information. Remember, you need to change option Gear Selection in Factory settings: Manual is for using the Detect cable, Automatic for using +12V Camera cable and let Android decide when to switch on the camera. Sometimes, the option is reversed (bug), so try changing if it doesn't work. When correct, the PDC/camera interface should be displayed when engaging reverse gear, regardless if a camera is connected, and Detect cable should NOT be connected (else you wouldn't know if the camera is switched on by Detect cable being powered from an external source). Also, option System, Camera selection should be "Adding camera". Last edited by Mjam; 01-15-2020 at 05:15 PM.. |
01-15-2020, 06:12 PM | #2122 | |
Rep 113
Cheers. |
01-15-2020, 09:07 PM | #2123 |
Rep 33
Here are my issues:
-Android iDrive date shows Jan 1 -Android iDrive music doesn’t use BT music. It's a separate Android app and the iDrive section only works with the pre-installed songs on the hard drive. -Dimming is inconsistent between iDrive and Android settings. iDrive settings don't seem to save/work. -Carplay (zlink) does not automatically start when BT and Wifi are connected -I changed the BMW bootup logo and now I can't revert it back to the original -I'd like to remove the "android" logo when booting up -MPH on OEM side is way off. Also uses liters for gas. -Bluescreen (I didn't order it, but got it anyway) can't be seen with polarized sunglasses I supposed I'm wondering what value the Android iDrive screens provide? Carplay is great when it's working, but the audio isn't that great. I had to run AUX from the HU to the armrest to get this to work. I ordered from Navidom, but it's the same from Avin. A friend ordered from Avin and the packaging, everything, is the exact same. |
01-15-2020, 11:28 PM | #2124 | |
Rep 122
adb shell settings put secure icon_blacklist bluetooth,alarm_clock,rotate,nfc_on |
Kri1083.50 |
01-16-2020, 12:41 AM | #2125 | |
Rep 1,407
Drives: 13' F30 328i 6MT
2 - The music app will play any songs you copy to its internal memory or from USB.. You can also remove the songs or link that to a diff app like spotify 3 - I dont seem to have any dimming issues, If headlights are on it dims and if they are not its brighter. 4 - Carplay seems to work fine, Somtimes I just have to fiddle with it but mostly its fine and autostarts 5 - I havent messed with the logo stuff 6 - Would be cool to remove the Android Logo on boot but not a deal breaker 7 - Agree I wish it was in gallons not liters and that MPH is way way off, Says like 125mph when im doing 75mph 8 - Blue Anti Glare - I also ordered black and got blue, I feel black doesnt even exist because many others said the same. For me ( I had a 6.5" without Bluetooth audio ), I gained wireless carplay and a much nicer big screen... The android apps and custom stuff is neat but mostly im in Carplay and just love that I now have full navigation, wireless streaming audio amd a much nicer screen. The most major complaint I have is the sound quality is a little worse, I have HK Audio with and I notice it.. The latest 3.8 software appears to have made it a little better and if we can just find a way to leverage the internal DSP or get Viper4Audio or something to work that maybe resolved as well..
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
01-16-2020, 12:45 AM | #2126 | |
Rep 45
You said without root? Do you have some information about how to connect the device to the PC? Can I do that in a snapdragon device? Last edited by franbass; 01-16-2020 at 12:51 AM.. |
01-16-2020, 01:48 AM | #2127 | |
Rep 1,048
I did this on my Snapdragon HU. What is needed and how you connect via adb is described at the Rooting guide. Kri |
franbass10.50 |
01-16-2020, 01:54 AM | #2128 | |
Rep 45
But I still not sure if it's mandatory to root the device for that or not. I'm going to try it if to root is no needed. |
01-16-2020, 02:43 AM | #2129 | ||
Rep 45
But when I try to connecto with the HU, I can't connect to it. I follow your guide, and it say to follow the first step of this https://forum.xda-developers.com/sho...&postcount=740. There, it says if it can connect it's needed to download a terminal emulator on device and run two following commands: setprop persist.adb.tcp.port 5555 setprop sys.rkadb.root 1 The both report me an error, no one works in the command terminal. |
01-16-2020, 03:25 AM | #2130 | |
Rep 1,048
Kri |
01-16-2020, 09:09 AM | #2133 | |
hardware modder
26
Rep 31
If i got time i will look into this after work, first i need to setup my environmeht to unpack the rom images, cause as i saw in a quick check they are now packed in an ext4 file format |
01-16-2020, 10:25 AM | #2134 | |
Rep 1,048
I found alot of odex files, so probably this is active. Unpacking the image with URTool is quiet simple, i made a fork for us here. You just need to put your update into the same folder, rename it to android 9.zip and start the unpack_system_android9.bat batch file to get to the main apps. unpacking the apk via apktool should be nothing new for you then Kri |
