02-06-2015, 07:47 AM | #1 |
Rep 914
Alignment after winter tire swap? (pulling to right)
I just swapped out my winter tires for the OEM all seasons (393, square).
The catch is that the past shop did not mark the original position of the OEM setup, so it's possible that the LF wheel is bolted on the RR side and etc. Is an alignment needed? I only ask since the winters were a used set with uneven wear on the front axle. PS: Look out in Member Classifieds soon for a set of winter tires+rims.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 04-21-2015 at 10:45 PM.. |
02-06-2015, 10:31 AM | #2 |
Curmudgeon and Pedant
690
Rep 3,488
A little early to be changing back, isn't it?
I wouldn't bother with an alignment unless the tires you just took off showed uneven wear from the time they were on (not previous wear), or if you hit some potholes during the winter. |
02-06-2015, 11:55 AM | #3 | |
Rep 914
2020 i3 Rex: Capparis White, Giga World |
02-06-2015, 02:49 PM | #4 |
Rep 1,063
I was just about to say...I want to be living in a place where winter is over now.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
02-06-2015, 04:56 PM | #5 |
Rep 914
I forgot to mention that I've had consistent pulling to the right since day 1. After 3 alignments by three dealers (all under 2k alignment warranty), it still pulls.
Most SoCal dealers are quoting $188-$250 for alignment, but one is quoting $550! Claiming 3 hours of labor since my car has DHP. :
02-06-2015, 09:18 PM | #6 |
Rep 627
Where in SoCal are you? I had the same pull when I got my car.
Took it to the dealer where they moaned and groaned about alignment not being covered.. They finally budged but problem wasn't fixed. If you're near SGV I HIGHLY recommend Temple City Auto Repair to do your alignments. They fixed my problem! |
02-06-2015, 10:07 PM | #7 | |
Rep 914
02-07-2015, 12:19 AM | #8 |
Rep 627
Toe adjustment is $60, toe and camber adjustment is $100
FYI - make sure you opt to sit in the driver's seat when they're aligning so you can level the wheel to your liking! Tell them Kevin referred you and John/Henry will take care of ya They also have tires for the cheapest prices I've ever seen |
04-21-2015, 10:45 PM | #9 |
Rep 914
Small update...
The car has been through three alignments since my last post and there is still a slight right-pull, albeit improved. I just want to check my sanity and see if my expectations align with reality.
Assume you are driving straight on a smooth, decently level road, at constant speed. There is some road crown, but not extreme. Should a car pull to the right when the steering wheel is let go?
04-25-2015, 10:00 AM | #10 |
Rep 914
Any thoughts?
The car has been though 6 alignments across 4 shops and I'm confused why the car cant track straight with no input from the steering wheel.
