04-02-2016, 11:12 AM | #1 |
e90noob
1597
Rep 1,873
Help - Which aftermarket HID kit? ...
So the plan is ...
buy empty pre-LCI f30 headlight units from ebay with the original projectors and angel eyes And install an aftermarket HID kit with it Code for xenon ... and pray that it works fine But browsing through HID kits... there are so many different types anyone have a strong recommendation for what brand/model? do i get a D1S bulb type HID kit? any help appreciated
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 Last edited by XKxRome0ox; 04-04-2016 at 02:06 AM.. |
04-06-2016, 04:16 AM | #2 |
e90noob
1597
Rep 1,873
04-06-2016, 12:14 PM | #5 | |
e90noob
1597
Rep 1,873
which i would connect to the halos and the high beam
Production date - 2008-04-22 |
04-06-2016, 12:19 PM | #6 | |
Rep 700
Or buy these if he still has them. |
04-06-2016, 01:43 PM | #7 |
e90noob
1597
Rep 1,873
ahhhhhhhh wtf
then ... i should be looking for original xenon ballasts and parts from the f30?
04-06-2016, 07:20 PM | #9 |
Rep 312
You're looking at about 3-4k in parts, labor, and coding to get this to work. Your other option is to get a pair of eagle eyes aftermarket housings, and put some LED's in them, or a good HID kit, and code out all errors. This route will cost you about $500.
04-06-2016, 08:53 PM | #10 | |
Rep 700
04-07-2016, 01:39 AM | #11 |
e90noob
1597
Rep 1,873
Someone is willing to sell me complete f30 xenon headlights for under $1300
I hope the guy comes through and does not flake If that does not happen, then I will piece together the parts like Adamr has been doing Or just settle for the eagle eyes and add hid kit |
04-07-2016, 07:55 AM | #12 | |
Rep 700
The retrofit will require rewiring and coding if you're looking at going that route, but that's a good deal for complete lights, the driver modules are $350 a piece brand new, and they are the last things I need to get, so that will put me around $2000 to be completed. |
04-07-2016, 12:00 PM | #13 | |
e90noob
1597
Rep 1,873
$2000 and that's with you piecing the parts together? i'm aware of the need to re-code ... but re-wiring, too?
04-07-2016, 01:22 PM | #14 | |
Rep 700
I was going to get the Umnitza LED headlights, but after I got to thinking about the "what if's" of aftermarket lighting, I just decided on doing the OEM route, so of something were to happen, at least I can replace what ever brakes. |
04-07-2016, 03:31 PM | #15 | |
e90noob
1597
Rep 1,873
i did see the moving of pins and adding ground wire in the extensive DIY guide posted good luck with getting that last part
