04-19-2019, 05:15 PM | #1 |
Rep 43
Will 370mm rotors fit in place of 340mm
Hey guys so i have a 2015 335i msport package without msport brakes. I was wondering if the 370mm rotors will fit my current calipers. The rotors i have now are 340mm. Some one told me they are interchangeable just wanted to double check.
04-19-2019, 06:31 PM | #2 |
Rep 3,644
The 370mm rotors are only interchangeable in the sense that they mount up to the same holes as the 340mm rotor. Your caliper can't support the 370mm rotor. It would need longer mounting pylons/ears to do so.
d1mitrov66.50 |
04-19-2019, 06:51 PM | #4 | |
Not stock
477
Rep 614
I am really not sure why people are confused about the 340/370/380mm rotor thing. The 340mm calipers mount 15mm inward of a 370/380mm caliper. The reason a 370mm caliper can work on 380mm rotors is because 380mm = M3 upright which have longer mounting ears, so they space the 370mm caliper out 10mm by means of where they attach to the strut housing.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
d1mitrov66.50 |
04-19-2019, 07:27 PM | #5 | |
Cheapskate
4521
Rep 5,003
04-19-2019, 07:28 PM | #6 |
Not stock
477
Rep 614
Yes that is correct, however moving the pad further from the center of the disc makes for a great amount of torque even though the friction surfaces are the same.
04-20-2019, 09:42 AM | #7 | |
Rep 483
kern4174520.50 alohasurftoad3318.00 |
04-20-2019, 12:12 PM | #8 |
Rep 5,801
Switching the fronts from 340 to 370 is negligible in terms of braking improvement. It's more for show by using the larger 370mm rotor in front. They both use 4-piston Brembo calipers.
(Note that either the 370mm front rotor or the 345mm rear rotor means an 18" road wheel is required. So if you have 17" wheels, you can't upgrade to either of these unless you are upgrading the size of your road wheels at the same time.) The brake mod that will give the biggest performance gain is if you switch out the rear 1-piston calipers for Brembo 2-piston calipers on 345x24 rotors. Instead of nose diving during hard braking the car squats on all four wheels very controllably even if you are standing on the brake pedal. It is a huge difference. Add some stainless steel brake lines (about $106/ set of 4) and Hawk HPS 5.0 pads (about $115 for rears) and the overall improvement from stock braking is dramatic. I've seen the rear (blue) calipers with the 345x24 rotors going for roughly $600 used. Toss any OEM pads that come with them for the Hawk 5.0's. You can change the color of your calipers right on the car by brushing them with G2 Caliper Paint (about $42 at TireRack). (G2USA.com) It's a two part epoxy type coating that evens out when applied at the right temperature range so it looks like it was sprayed on. Doing these all together is a great brake system modification in terms of bang for the buck! Hope this helps! |
04-20-2019, 12:37 PM | #9 |
Rep 10,618
@d1mitrov, could you share more details about your goals? Better visual appearance of brakes? More braking power? Will you take your car to the track?
04-20-2019, 02:01 PM | #10 | |
Rep 5,801
BMW really confuses things in terms of brakes by using similar terms like "M Sport" to mean different things depending on which model car and whether you are talking about calipers, rotors or pads, or various packages. Turner Motorsport has some great articles to explain this stuff on their website but they are buried several levels deep and difficult to locate. Google "Turner Motorsports Brake Package Differences" and it will list an article for the 328i and another for the 335i. These are great resources! |
Pittcrew34.00 |
04-20-2019, 02:33 PM | #11 | |
Rep 2,181
Stand corrected: https://f30.bimmerpost.com/forums/sh...90&postcount=9
04-20-2019, 04:20 PM | #12 | |
Rep 43
https://www.ecstuning.com/b-ecs-part...0/014586ecskt/ |
Logicoeur997.50 |
04-20-2019, 08:50 PM | #13 | |
Rep 10,618
If you are interested in learning more, both Brembo and AP Racing make exceptional brakes which provide more braking power than one may ever need. |
04-20-2019, 09:50 PM | #14 | ||||
Rep 5,801
StopTech has some black hat drilled rotors for half the price. I also recently learned about adamsrotors and r1concepts. Check out rotors on their websites. If you want to make your brakes "pop", change the color. Check out G2USA.com for their caliper paint. (TireRack $42) it's a 2-part epoxy type paint that brushes on with the car on jack stands. Paint levels out and looks like it was sprayed on. I painted mine black to match the car, added Brembo decals and even painted stock rotor hats silver to get rid of rusty look. Would be easy to change rotor hat color if you wanted a certain look. The photo is of your same stock front gray caliper painted in G2 Black with a white Brembo decal. (My second color choice was red but I have a stealth theme going with this particular car.) The side of the rotor hat that you see (not top where it is against the road wheel) is painted G2 Silver so it always looks brand new now. |
04-22-2019, 09:50 PM | #15 |
Rep 43
That does look pretty good. Im having a local shop paint all four for $150 tho. I actually got 4 rotors for $400 with pads and sensors from cquence brakes. Theyll look like this
04-23-2019, 06:23 AM | #16 |
Cheapskate
4521
Rep 5,003
I agree you don't do this upgrade if you want more braking power. Brake pads will be a far better option that will stop better and handle the increased heat better.
I remember in my Volkswagen days, SPM experimented by selling a bbk spacer kit. Basically it spaced out the OEM 1-Piston calipers to accept a larger rotor. They had to stop selling it shortly after due to a lot of fuss about it not really increasing performance. |
johnung4945.50 |
