08-27-2021, 03:09 PM | #1 |
Rep 246
X delete... will it solve this?
Guys, since ive put the 20s on my car ther is a slightly juddering acceleration
tire sizes are good @ 245 35 20 and 285 30 20.. but between front and rear profile there is a 3 mm difference Since the x drive is something i dont need in my life... will the X delete also remove that problem of the acceleration juddering? On the 19s with 4 x same profile everything was perfect.. |
08-27-2021, 05:10 PM | #2 | |
Rep 383
08-31-2021, 10:36 AM | #3 |
Rep 246
09-03-2021, 07:29 AM | #6 |
Rep 246
09-03-2021, 11:36 AM | #7 | |
Rep 5,799
IMO don't assume that was the cause. XDelete may be covering up some issue in your XDrive drivetrain( located in the front half of the car) that should be investigated. |
09-03-2021, 06:28 PM | #8 | |
Rep 4,555
Drives: 2015 328d xDrive
Onizukachan1448.50 |
09-06-2021, 12:01 PM | #9 | |
Rep 246
Plus i dont give a $#^#^#^$ about xdrive... i think its overhyped, especially on the lower powered models.. with my m550d and 935nm of torque it was a different story |
11-17-2021, 10:39 PM | #11 |
Rep 1,934
Almost two years of usage. Turn off in the summer. Xdrive on in the winter. No issues.
MaseinMA16.50 |
12-31-2021, 12:22 PM | #13 |
Rep 4,555
Mechanically speaking I don't think there are any potential issues (that I know of), but I question how well the rest of the car copes with the change. For instance, my launch control won't work properly when the front wheels are deactivted which shows that xdelete doesn't completely recode/fool the car into thinking it's rwd. That then makes me question how functional the other awd related systems are such as the stability control is (if it's reprogrammed for rwd or left as is). Wondering if that would pose a safety issue should you start to hydroplane/spin or something. I ended up turning xDrive back on because I just don't trust it.
01-01-2022, 09:44 PM | #14 |
Rep 149
I twisted a driveshaft in half, doing a launch. Totally driver error.
02-08-2022, 03:20 AM | #15 |
Rep 7
