04-18-2022, 01:34 PM | #1 |
Rep 200
Brake pad change while keeping same rotors
The time has come that I need to replace the pads on my DB11. The rotors still have a lot of life in them. I am planning on switching from the OEM pads to pads that:
1. last longer 2. are cheaper 3. perform "better" I need to review the research I did last summer (with the help of some people on this forum!), but I believe I had settled on going with Pagid RSL1s. So my two-part question is, how do you determine if the new pad compound is compatible with the existing friction layer on the disc and if it is not, would any potential issues be addressed/alleviated by performing a bedding procedure? |
04-18-2022, 05:25 PM | #4 |
Rep 2,157
This is usually why they suggest driving gently for a period before beginning a bed in procedure; it helps mate the new pad to the worn disc, and also uses mechanical friction to essentially scrub any old pad deposits from the rotor. This gives you the 'clean' surface on which to then bed the pads in properly.
Itogliano106.00 |
04-18-2022, 10:28 PM | #5 | |
Rep 200
